Question about Dryers
Dryer won't start
I have a whirlpool dryer that won't start. I've checked the circuit breaker and all is well, it's plugged in, it closes properly. I've checked the basics but nothing seems to work.
  • 11 more comments
  • Jon Fisher Nov 05, 2007
    Kenmore electric dryer stopped during cycle; would not restart. There were no noises or other problems leading up to the failure.
    Replaced push-to-start switch and timer ($80.00). Still will not start or make sound of any type.
    Door switch is suspect, but light in dryer still comes on when door is opened. How do we tell if door switch is defective?
    Other ideas?
  • gscout Nov 05, 2007
    Sounds like I have a similar problem. My Whirlpool dryer GEW9878LW will start temporarily when the start button is pushed but once I let go of the button, it stops. Is this a problem that someone figured out exactly what it is?
  • crusaders Dec 30, 2007
    We have this Whirlpool LGR4634jq2 gas dryer that suddenly will not stop. We have also reset the circuit breaker but to no avail. When we push the start button, it makes a sound like it will start up but it will not. If we hold it for more than a half dozen second, it starts to click...any solutions out there?
  • samking Dec 31, 2007
    I have GE DBXR463 dryer which starts and runs untill I hold the start switch to on position. As soon as I release the switch it stops. I have checked all the circuits and everything is O.K
  • BBRB Jan 05, 2008
    My dryer just went dead and will not start?? It worked yesterday and not today. Fuse? switch? ????
  • djacobson Apr 06, 2008
    I was drying a load of clothes, the dryer quit before the clothes were dry and will not start again. It is plugged in, circuit breaker is fine and door is completely shut. what do you suggest I do?
  • blakerepka Jul 17, 2008
    My dryer just quit. We went to turn it on and got nothing. already checked breaker and power cord.
  • Kay Hyer Schwartz Jul 28, 2008
    I have a Cabrio Dryer that heats up but won't turn. Can anybody tell me what to check or replace?
  • Anonymous Aug 07, 2008
    the kenmore dryer wil not start. model 62974 when you push the start button, nothing happens.
  • dawgkrazy Aug 07, 2008
    kenmore model 62974 will not start. when you push the start button nothing happens. it is getting power, the breaker is good.
    do i need too replace the motor ann heater rely or thethermal fuse?
  • longhorns76 Aug 09, 2008
    When I push the start button it hums, if I push for a few times nothing
  • nancysue Aug 25, 2008
    When I turn the knob to start, all it does is hum.
  • Anonymous Oct 24, 2008
    dryer won't start
    New Friend:
OK first thing for you to do to know if this could work for you is check were the power cord connects to your dryer... if you have and it reads 220 or better then you can proceed.start by taking the back panel off and locate your blower housing(it will be on left of dryer).There will be a white barcode looking strip with two wires coming out of it.Take the dissconnect dryer take a strip of tin foil and bridge the two togarher plug dryer up and it should run.If it does the you just need a new fuse or do what I did get one off an old Dryer no one else is using!
GOODLUCK!
William B.
Posted on Nov 04, 2009
There is a fust on the inside of the dryer beside the blower motor. It is called a thermal fuse.rated at about 197 degrees F. check with a continuity tester. If it is bad, you will not get a reading. Fuse cost me about $13.00 to purchase at local parts supplier and it was up and running in about 20 minutes. Also be sure to clean all of the dust and junk that the filter did not catch.
Posted on Apr 16, 2008
  • 291 Answers
Well I would first for power at the back of the dryer makeing sure you have 220 to dryer, check lid switch, also in the back there is a fuse white with two wires to it oblong or triangle depending on year.. may be blowed
Posted on Aug 28, 2007
    Novelist:
    Champion:
  • 244 Answers
All dryers use an interlock switch which when u close the door it opens the circuit for the power try banging on the front off the dryer it may start if it does then you have a lose connection to the interlock u need to get the lid of to get to the interlock switch if it doesnt start then u have a mains filter which is next to your motor about 4in in length cyclinder with at the most 4 wires going to it possible 2 wires this will having lettering and numbers on it this needs replacing its on the inside at the bottom of the casing ,8
    New Friend:
  • 3 Answers
Ummm... mine wasn't starting either. pressed the start button and heard a click/hum. read all these posts, and checked the door switch first, and that tested fine with a multimeter. then, i pulled the dryer away from the exhaust tube with the intention of testing the heat fuse, and found a surprise.that would make Bullwinkle cry !! ...jammed up in the dryer vent receptacle, and against the drum was a roasted and mangled squirrel. was not a pretty picture, and some flies flew out. seems he chewed his way into the external vent cover screen. Nasty !! rubber gloves, and lotsa paper towels later, i hooked everything back up, and the dryer started. soooo, check for a blocked vent first before you pull everything apart.
Posted on Apr 22, 2012
I had this problem too (dryer was about 2 yrs old). I needed to replace the switch. There is a site (somewhere, sorry) that you can download a pdf repair manual from whirlpool. The pdf shows in detail how to take off the cover, and replace the switch. Cost of the switch was ~$30. There are a sequence of buttons you push to diagnose problems. In this case, all the fault codes will show  is that the dryer thinks that the door is open. From what you describe, a faulty switch sounds like your problem. I am suspect of the 'loose connection' diagnosis above. Those connectors have a very tight connection.
Posted on Oct 25, 2007
SOURCE:
Jimster
  • 240 Answers
SOURCE: whirlpool electric dryer keeps tripping main circuit breaker
First off, be sure the pigtail is wired correctly to the back of the unit. Black and red to the outside terminals, white to the middle, green to the frame or cabinet (should be a green screw close-by). If that is ok, you probably have an issue with possibly a bad pigtail, bad outlet, wiring issue, or possibly a bad circuit breaker or breaker box. Probably going to be more of a electrical problem than a appliance problem. Good Luck!!!!
Posted on Feb 02, 2008
  • 1894 Answers
SOURCE: Dryer won't start
have you left the unit unplugged for one night and tried to start??
doe sit make any humming noise when trying to start
Posted on Aug 25, 2008
  • 77 Answers
SOURCE: dryer kicks off circuit breaker, pf code is on dryer. now won't let me do anything
pf is for power failure. sounds like You may have a short somewhere. Be careful of electric shock.
Posted on Apr 21, 2009
fastboyz
  • 674 Answers
sounds like you have a bad capacitor this is what starts your motor by giving it a burst of energy
with model and serial number i could give more info
TheMobilian
  • 8220 Answers
SOURCE: my whirlpool dryer model number LER4634JQ1 is not getting hot
You need a 30 amp breaker in my neck of the woods. South Alabama, US
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jul 28, 2009
My Whirlpool gas dryer is not working
Instructions
Check that the dryer door is closing completely. Remove anything that blocks the dryer door from closing.
Ensure the "Start" button is pressed firmly to start the dryer cycle, the dryer is not overloaded and the clothing is not balled up. Any of these things can prevent the dryer from operating and/or drying the clothes.
Use a level to confirm your Whirlpool dryer is sitting flatly and evenly on the ground. Adjust the dryer as necessary for it to be level as the dryer will vibrate and make unnecessary noise when sitting unevenly.
Examine the inside of the Whirlpool dryer drum and in the space around the drum for loose change, pens, hair ties and other items that could have been left in the pockets of clothing. These items will cause noise and potentially cause the dryer to become inoperable.
5
Examine the Whirlpool dryer's lint trap for excess lint. Remove any lint from the trap and place it back into position. Always clean the lint trap between dryer cycles. Inspect the area around the dryer and in the ventilation and exhaust systems. Remove any built up lint and clean the area thoroughly. Built up lint is a fire hazard and can cause operating issues.
6
Check the gas shutoff valve if your Whirlpool dryer is gas powered. Ensure the shutoff valve is turned all the way to the "On" position.
7Check the electric plug and ensure it fits securely in the outlet.
8
inspect both the fuse box and circuit breaker for any electrical problems. Replace any blown fuses, if necessary, and reset the circuit breaker if it has been tripp
Jan 09, 2013 | Whirlpool Dryers
Dryer not heating
If your dryer won't heat up, it's possible that it is not being supplied with the proper voltage. Here are three ways to make sure power is getting to your dryer: First, make sure your dryer is plugged in. Next, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Finally, check to make sure no fuses in your fuse panel are blown. Any of these could explain why power is not getting to your dryer.
Thanks.
May 16, 2012 | Kenmore Dryers
No power
Proper Voltage from the House
Your dryer may not be receiving adequate voltage to start. Make sure your dryer is plugged in. Also, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Or check to make sure no fuses in the fuse panel are blown. Try plugging something else into the same outlet. If it won't work either, then there is likely something wrong with the power outlet. Any of these could be the reason power is not getting to your dryer. Also, refrain from using an extension cord to plug your dryer in.
If your dryer's door switch is defective, it will not allow your dryer to start. Test your dryer's door switch. If it is defective, replace it.
check the thermal fuse in the back of the machine,, remove the back you'll see it
Jun 05, 2011 | Dryers
My Whirlpool dryer is plugged in but will not turn on
I would start by checking to make sure the circuit breakers are not tripped. An electric dryer runs on 220 and will have a double circuit breaker - a gas dryer runs off of 110 and will usually not have a dedicated breaker. Once you have determined the power is on, the next most likely problem is the door switch. This prevents the dryer from being activated with the door open. You can "jiggle" the switch while attempting to start the dryer, or check the continuity with an ohmmeter.
Jul 20, 2009 | Whirlpool Dryers
Dryer wont start
your dryer may not be recieving adequate voltage to start.
also check the circuit breaker panel to make sure all circuit breakers are in the right position.
check fuse box for blown fuse.
try plugging in something else in the same outlet.
also refrain from using an extension cord.
Mar 04, 2009 | Whirlpool GEW9200L Electric Dryer
Whirl pool dryer LEC9000PW0 will not turn on
Has a household fuse blown or has a circuit breaker tripped?
There may be 2 household fuses or circuit breakers for the dryer. Make sure both fuses are intact and tight, or that both circuit breakers have not tripped. Replace the fuse(s) or reset the circuit breaker(s). If the problem continues, call an electrician.
Is the correct power supply available? (Electric dryers only)
Electric dryers require 240-volt power supply. Check with a qualified electrician.
Is the dryer door firmly closed?
Your dryer door may not be fully closed. It may look shut, but may not be latched. Push on the door to engage the latch or latches. Some models have an upper and lower latch. Both latches must be secure for the dryer to run.
Was the Start, Push to Start or Hold to Start button firmly pressed?
Large loads may require the Start, Push to Start, or Hold to Start button to be pressed and held for two to five seconds.
Is the Cycle Control knob set on a Sensor Dry or Timed Dry cycle? (on some models)
The Cycle Control knob must be set in a Automatic Dry or AccudryTM or Timed Dry cycle. The dryer will not start if set on the Wrinkle ShieldTM option.
Is Controls Locked status light on? (on some models)
Press and hold the Cycle Signal button for three seconds. This will turn off the Controls Locked feature.
Did you recently install a power supply cord on the dryer? (Electric dryers only)
The power supply cord may be incorrectly installed. If the power cord is incorrectly installed, the dryer may not start or heat. Review the Installation Instructions to check that the power supply cord is properly installed.
Dec 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Dryer will not start
Nov 13, 2008 | Whirlpool GEW9250 Electric Dryer
Whirlpool dryer will not heat properly
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Oct 17, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Dryers Logo
7,936 people viewed this question
Top Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
