Question about Desa International Remington 16 Electric Chain Saw
107704-02service manual Will any 16' chain fit my 107704-2 DESA elec. chain saw?
5 Suggested Answers
  • 188 Answers
SOURCE: I have a 16-in Desa International electic chain
I am not sure where you can get that part in TX. However; you can purchase the part from Master Distributors and they can ship the part very quickly to your door. You can contact them at www.masterparts.net or by calling them toll free at 800-446-1446. I hope this helps!
Posted on Jul 07, 2009
  • 188 Answers
SOURCE: Missing the chain tensioning mechanism
The part you will need is a 108640-01. You can purchase this part with Master Parts. You can contact them online at www.masterparts.net or calling them toll free at 800-446-1446. I hope this helps you!
Posted on Jul 08, 2009
  • 384 Answers
SOURCE: what type of oil do I need for my Desa 8
Anything works.
Posted on Sep 09, 2009
dontbother10
  • 2220 Answers
SOURCE: Please specify the chain (091375-02S) for the 16
I hope no expert will do as you ask. I will not! I will provide the necessary links and information so YOU can make an informed decision based on what you are given.
Replace Desa with Remington. The EL-8 is not listed, I think if you do a careful inspection of your saw you will find a model number 107624* or 170625* (*matters not). Both of these numbers input below provide the same 3 choices on the following table.
Oregon Bar & Chain Selector
http://www.oregonchain.com/pro/lookups/selguide.aspx?BusId=OCS&SellReg=USA&LangId=ENG
The above results are for an original or equivalent 16" bar. Only you can determine your level of expertise,how much risk you are willing to assume and choose one of part numbers listed. Once you make your choice the Oregon part number can easily be converted to other chain manufacturers (if your local outlet does not handle Oregon). I suggest a few phone calls to save you time and gasoline. Given the Oregon part number and your assurance of a purchase, if my store, your chain would be waiting when you walked in the door.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Mar 22, 2010
Need part that holds the chain saw to the pole
They used to be owned by DESA industries. But I beleive that may have changed
Feb 13, 2014 | Remington Electric Chain Saw
Misplaced the manual. Need to know what oil I should use for the oil lubrication.
The chain oil tank should have a non fling chain oil, the non fling addative is so the oil does not fly off the end of the bar and lubricates where most cutting is done.
Sep 16, 2011 | Desa International Remington 14" Electric...
What type of oil does a remington chain saw use?
Regular bar/chain oil available at home centers, hardware stores, and saw dealers. Hope this helps!
Aug 14, 2010 | Desa International Remington 14" Electric...
Where can I find a replacement bar and chain for my saw?
Remove the bar and chain from the saw. Take these parts to a saw servicing dealer who can match the bar and chain. Be sure to clean the area where the bar mounts. Run the saw for a few moments--the oil port in the side of the case should ooze out oil. Install the bar first, then thread the chain onto the sprocket, then work it over the bar. Pull the bar out until the chain is fairly tight, then fit the cover, but leave the mounting nut(s) finger tight. Turn the chain adjuster until the chain doesn't droop from the bar, but still be able to turn the chain by hand. Tight the mounting nut(s) and recheck tension. Run the saw at full speed with the tip near some cardboard--it should throw off a thin line of oil onto the cardboard. Hope this helps!
Jun 10, 2010 | Desa International 100089 06 Electric...
I have a 16 inch chain saw and want to buy a new chain saw blade does anyone know what other manufacturer's blade will fit
Oregon mfg. makes a full line of replacement chains and bars (blade). Check with home centers, hardware stores, and saw dealers. Bring full details of the saw with you, or the saw itself. Good luck!
Jun 03, 2010 | Desa International Remington 12 Electric...
Remington 14" Electric Chain Saw Assembled 1.5 Peak: I just wanted to know what type of oil to put in t...
I have been using regular chainsaw oil and I think it works ok. I inherited one of these and would like to find a spare chain and also a manual. Can you give me any info? Thanks
Tim
May 17, 2010 | Desa International Remington 14" Electric...
My adjusting block is worn, can I purchase a new one?
It depends on which saw you have. Are you aware they are no longer in production? Eventually a replacement part will not be available.
You do not give us the model number of your saw to verify this will fit.
Remington.com
http://shoppingcart.msservicecompany.com/Default.aspx
• Type "YourModelNumber" into the "Search for your unit by Model:" window, then click search.
• Click the "YourModelNumber" - Remington Electric Chain Saw "View Model" link.
• Click "View Owners Manual" or "View Illustrated Parts Diagram" link.
• Type "YourPartNumber" into the "Search for your parts by Part #:" window, then click search.
A tension repair kit is available here:
MasterParts.com
http://www.masterparts.net/Merchant2/merchant.mvc?Screen=PROD&Store_Code=MPD&Product_Code=108640-MD
Part number 108640-MD; DESA SPECIALTY PARTS: KIT, ADJUSTMENT SCREW FOR SPROCKET COVER (REM-18); $5.95.
Kit fits the following covers: 108640-01, 116675-01 and 108641-02 (note: for the 108641-02 the screw will adjust from the front with a screw driver, not with a thumb screw at the back) KIT INCLUDES: screw, clip & adjustment block. If not available here please reply (below) with that information. TIA
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
May 01, 2010 | Remington Electric Chain Saw
I have an 14" electric Chain Saw. What type is Oil do I use?
You can purchase chain oil, or if you like any 30 weight oil will do.
Jun 26, 2009 | Desa International Remington 14" Electric...
Electric chain saw chain adjustment. How loose should it be?
the chain should not be sagging from bottom of bar.when you tighten the chain push the nose of saw up so that all of the slack is out of the chain.chain should snap back in the bar if you pull the chain up and let go.when i adjust a chain i push the saw forward to make the bar go up and stay there while i tighten the nuts.hope this helps, let me know
May 11, 2009 | Desa International Remington 14" Electric...
Desa International Remington 16 Electric Chain Saw Logo
46 people viewed this question
Top Desa International Garden Experts
Roland W VanLue
Roland W VanLue
ray gallant
Tim Whalen
Are you a Desa International Garden Expert? Answer questions, earn points and help others
