Question about Electric Lawn Mower
Neighbor mowed the extension cord and mower won't start
My neighbor borrowed my Task Force Model 25143 electric lawn mower and mowed over the electric extension cord. When he replaced the extension cord, the mower wouldn't start. Is my mower toast? Do I need to take it in for repair or would I be better off purchasing a new mower?
  • 1,087 Answers
Check the cord has been properly replaced. Check circuit with a meter (NOT connected to mains) The live pin on plug should connect to live pin on motor switch etc. (need to take off cover on switch unit)
Cutting through the cord should not have damaged the mower.
Posted on Sep 17, 2013
4 Suggested Answers
woobie dog
  • 1273 Answers
SOURCE: Cut extension cord
I have a couple of them too. Here's how to fix it:
Cut back the outer sheath several inches on each side of the cut. Be careful in doing this; you want to cut the sheath, without nicking the wires beneath it. This will expose the wires. The wires will have their own insulation covering the copper conductors. Cut the insulation back 1" on each wire, exposing 1" of copper. When you have cut them all back, pick two wires, one on each side of the break, with the same colored insulation. Take these two wires, and fan the copper out. Now, mesh the two wires together, like you were intertwining your fingers, and then pinch the fanned ends in towards the wire, and twist them around the wire nice and tight. Take electrical tape and begin winding the tape around the splice that you just made. Start the tape on the insulation, making a full wrap on itself, and wind the tape tightly across the splice, covering about 50% of the tape as you go with each turn. When you get to the insulation on the other side of the splice, make another full wrap around. Grip the electrical tape tight, and cut it off. Smooth it onto the wiring. Repeat this for each wire set. As you have more wires joined, it will be more difficult to wrap the splices with the tape on the roll, but the main thing is to wrap it tightly, with good coverage, since you are insulating the wire with the tape. You're looking for complete coverage, with no bare wire able to touch any other bare wire.
Once you get all of your wires covered, take your tape and start on one side of the sheath about 2" above where the sheath was cut back, and start winding the tape like you did for each wire, only this time you'll be covering all of the wires, and joining the sheathes with the tape. When you get all the way from one side of the splice to the other, and anchor the tape well to the sheath (full wrap), reverse direction, and wind it back to your starting point, overlapping each wind of the tape by 50% like you did before. Get back to your starting point, and make another full circle of tape on itself. Cut it off and smooth it out. You'll wind up with a bit of a 'hump' in the cord, but that is the nature of a homemade splice.
Ta-DA! You're done!
Best regards, --W/D-- please feel free to rate this solution..thanx!
Posted on Aug 03, 2009
Asbestos 56
  • 191 Answers
SOURCE: electric mower will quit after
I don't know what model or brand this is but once you make sure you have power at the end of the cord (bring something else to plug in to test it.) My next thought would be the switch. This seems to be the first to go on some of these. Look at the housing and see if it is cracked or distorted. Post brand and model # also.
Posted on Jun 16, 2011
BAMOUT
  • 2478 Answers
SOURCE: My electric Yard machine lawn mower don't start
Turn it over and clean the caked grass off, then
try it.
Posted on Oct 01, 2012
My 2 year old corded electric Task Force mower whch has had very light use suddenly stopped in middle of mowing and won't restart. Didn't trip any breakers and the cord is fine. Felt cool, not clogged
Sounds like electric motor has gone bad. If you can get past the switch and put a tester on and see if there is any power there that would tell whether your switch has gone bad. I had a new electric motor go bad after ten minutes use. I ended up replacing it.
Sep 28, 2014 | Garden
Tip
Safety For Electric Mowers
<span> <ul> <li>Use only recommended, grounded extension cords.</li> <li>Mow away from the cord.</li> <li>Never abuse the cord or use a frayed cord.</li> <li>Always turn off the mower when you leave it and unplug the cord directly from the outlet; never unplug by yanking the cord from the wall.</li> <li>Never use an electric mower when wet or raining</li></ul></span>
on Apr 02, 2011 | Garden
My 2 year old corded electric Task Force mower whch has had very light use suddenly stopped in middle of mowing and won&#39;t restart. Didn&#39;t trip any breakers and the cord is fine. Felt c
Stuck brushes,in the brush holders caused by corrosion,unplug the cord first,remove the cover and look for two carbon brushes that should be contacting the motor,if not stuck they may need replacement !
Electric Mower zapped?
They should replace it. They broke it. If it was just a cut in the cable it should work again, but they have probably burnt it out. Change the fuse first also as that would have popped.
Jul 13, 2013 | Garden
Electric Mower electrocuted?
wire disconnect in lawn mower.
Jul 13, 2013 | Electric Lawn Mower
I have a task force electric push mower and while mowing my lawn it started to smoke and shut off.. now it wont turn back on what could the problem be
it probably burn up if it smoked throw it away get a new one not worth sinking money into it to fix it
May 26, 2013 | Garden
Cub cadet 1515 won't start
I just had the same problem. I installed a new spark plug, sprayed some starting fluid in the engine and it started right up. I mowed my entire yard, and my neighbors yard with no problem?? I'll post more next mow and let you know if it has fixed the problem!!
Apr 29, 2012 | Cub Cadet Street Sign- tractor lawn riding...
Electric mower will quit after mowing for 10minutes. checked the extension chords and everything is plugged in.
Jun 16, 2011 | Electric Lawn Mower
Riding Mower will not start
You need to check a few things. The spark first, you need to check if it is running correctly, does it have spark, by doing this: take out the spark, put it against a metal surface and pull the pull start if it spark, your good if not you need a new spark plug. Clean out your airfiilter it migth help too. Buy some carb and choke cleaner squirt it up theough the airfilter hole, and start the engine, this will clen the carb. yOU MIGHT NEED TO TAKE OUT THE CARB AND CLENA I OUT THROUGHOULY!!! Try that and it whould work after all these steps!
Jul 05, 2009 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Electric Lawn Mower Logo
332 people viewed this question
Top Electric Garden Experts
Steve Oakes
dannydoesita
ray gallant
Are you an Electric Garden Expert? Answer questions, earn points and help others
