What does "no associated network mean"
I bought a new wi fi router, and set it up. I also downloaded the app on my smart phone, but when I put my user name and password in on the app, it says "no associated network"
anandg27
  • 1272 Answers
SOURCE: connecting my ipod touch to my wireless router through wi fi
Check for the password on the router configuration page to make sure tat you are using the correct one:
1. Open the browser(Internet Explorer or Mozilla Firefox).
2. Access the router usually http://192.168.0.1 else try http://www.routerlogin.com
3. Login to the router (User Name = admin Password = password unless you have changed it).
4. Click on Wireless Settings'(under Setup) from the left menu.
5. Check if 'WEP (Wired Equivalent Privacy)' or 'WPA-PSK (Wi-Fi Protected Access Pre-Shared Key)' is selected under 'Security Options'.
6. If WPA-PSK is selected, copy the code entered in the passphrase.
7. If WEP is selected, copy the code entered in the Key that has a black dot before it.
This is the code required for connecting the wireless computer to the routers' wireless network.
Enter the same password on IPOD to connect to the wireless network.
Rate it,if it helps.
Posted on Jun 26, 2009
ragufiles
  • 105 Answers
SOURCE: unstable wi-fi connection to D-link DIR-825
check the connectivity again by assigning static IP Address to your DELL.. if problem occurs, clean install the drivers and dell Wifi software to your laptop.. Virus problem also results in this type of problem..
Posted on Jun 17, 2010
SOURCE: Kindle 3rd Generation -- Linksys
I don't have a solution -- I'm having the exact same problem and I'm looking for a solution. Called Kindle tech support, and all they could recommend was to go to McDonald's to see if I can connect using their wireless. They DID say this Linksys WRT54G router is a compatible router with the 3rd Gen Kindle.
Posted on Jan 23, 2011
ricbellen
  • 53 Answers
SOURCE: can you help me setting up a password for my wi-fi
How do I secure my network?
Log into your router using the "How do I log into my router?" instructions earlier in this article.
  1. From the left-hand menu, select Wireless Settings from the Set Up section.
  2. In the Name (SSID) field, enter the network name you want to use.
  3. Under Security Options, select a security encryption level. NETGEAR recommends WPA-PSK + WPA2-PSK for the best protection.
  4. In the Passphrase field, enter your chosen network password.
  5. Click the Apply button to save your changes.
For more details, see Securing Your Network: WPA+WPA2 (Recommended).
How do I change or reset my wireless network password?
Log into your router using the "How do I log into my router?" instructions earlier in this article. From the left-hand menu, select Wireless Settings from the Set Up section. Enter a new wireless network password into the Passphrase field under your security selection and click the Apply button to save your changes.
Posted on Jun 05, 2011
Testimonial: "good job!"
Tom Marvolo
  • 708 Answers
SOURCE: trying to connect my ipad
Before you start :
Make Sure the Wireless Switch on your Computer is turned Off (If you are using a laptop to connect to the router )
Make sure that the Light on the Router is Solid Green
Step 1 : connect a computer to the router (Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 in the address bar of Internet Explorer
Step 3 : Once you are at the router setup .. on the left side underneath Wireless you can find Wi-Fi Protected Setup
Click it
Step 4 : If it is asking for a password .. leave the password field blank and click submit
Step 5 : Disable Wi Fi Protected Setup and click apply changes
Step 6 : Now on the left under wireless click Security
Step 7 : If it is asking for a password .. leave the password field blank and click submit
Step 8 : Change the Security mode to WPA-PSK (you can also choose WPA-2 but sometimes it doesnt work )
Step 9 : Type a password (8 Characters , It is Case Sensitive)
Step 10: Click apply Changes
Step 11: On the left , Under Wireless Click Channel and SSiD
Step 12: Change the SSiD to a Different name , Change the Wireless Channel to 11
Step 13:Click Apply Changes
Turn On the Wireless Switch on the Computer (If you are using a Laptop to Connect between router)
Now try to Connect to this new network on both your wireless Computers and Ipad
Let Me Know if it Works
Posted on Aug 18, 2011
I have a Roku in my bedroom & when I try to watch Netflix it just spins & spins & takes forever to load. Once it starts, it stops & starts spending again.
First step, of course, is to unplug the Roku for 10 seconds then plug it back in again and let it connect.
Assuming a Wi-Fi connection is what you are using, it is possible (likely) that your Roku is too far from the Wi-Fi router. Your best solution is to relocate the Wi-Fi router closer to your Roku, or to get a signal booster to extend the range of your Wi-Fi signal.
On a more technical note, your Wi-Fi router may be broadcasting on a channel that has lots of conflict with other Wi-Fi signals in your neighborhood. Changing the broadcast channel requires that you have an administrator login to your router and can make changes. You might have to call your service provider and have them make the changes for you (if you smile right over the phone, they may give you your router's login information, but don't count on it). Best channels to select are generally 1, 6 or 11 to avoid overlap with other channels.
If you have a smart phone and can download an app, look for a Wi-Fi Analyzer app (free). This will show you the other signals around you, what channel they are broadcasting on, and the strength of the signal.
Sep 06, 2017 | Computers & Internet
I just switched to a different internet provider. Alexa says she is having trouble connecting. What should I do?
You probably need to connect to your new wireless router.
Open the Alexa app.
In the Alexa app, open the left navigation panel and then select Settings.
Select your device and then select Update Wi-Fi. If you're adding a new device to your account, select Set up a new device instead.
On your Echo device, press and hold the Action button for five seconds. The light ring changes to orange, and your mobile device connects to your Echo device. A list of available Wi-Fi networks appear in the app.
Note: The Alexa app may ask you to manually connect your device to your Echo device through your Wi-Fi settings.
Select your Wi-Fi network and enter the network password (if required). If you don't see your Wi-Fi network, scroll down and select Add a Network (for hidden networks) or Rescan.
Optional - Save your Wi-Fi password to Amazon: Any Wi-Fi passwords saved during setup automatically appear when you connect a new Alexa device to the same Wi-Fi network. The password is also remembered if you switch between saved Wi-Fi networks. For more information, go to Saving Your Wi-Fi Passwords to Amazon FAQs.
Optional - Connect to a public network: Enter any required information if you are connecting to a public network that requires a web browser to sign in, like a school or hotel. The information could be a pre-shared password, room number, or just a button to accept conditions for using the network. This information cannot be saved to Amazon. Contact the network owner for more information.
Select Connect. After your device connects to your Wi-Fi network, a confirmation message appears in the app.
Jan 25, 2017 | Internet Computers & Internet
Wii-fi will not turn on
Let me know the device you are using
Jul 13, 2015 | Google Android
When i connect my samsung galaxy express to wi-fi my computer's wi-fi stops working
Hello Ricardo.
How are You? I Guess you need to
1- Check your wi-fi router model.
2- Check your wi-fi settings.
also please check how many devices are connected to your wi-fi at same time. because some routers can only support upto 5 device. you can check this in the settings and also routers manual.
Please let me know, once you done with it.
Regards
Nov 22, 2013 | Samsung Cell Phones
I just bought a Lg optimus L7 l don't know how to
Turning Wi-Fi on and connecting to a
Wi-Fi network
1 Touch > Apps tab > Settings >
Wi-Fi from the WIRELESS & NETWORKS
2 Set Wi-Fi to ON to turn it on and start
scanning for available Wi-Fi networks.
Tap Wi-Fi menu again to see a list of
active and in-range Wi-Fi networks.
• Secured networks are indicated by a lock
icon.
4 Touch a network to connect to it.
• If the network is open, you are asked to
confirm that you want to connect to that
network by touching Connect.
• If the network is secured, you are
prompted to enter a password or
other credentials. (Ask your network
administrator for details)
Feb 03, 2013 | Cell Phones
What does need a data connection mean
To use Google maps or some other programs (like games), you need to be connected to a Wi-Fi network, not the cellular network. You will need to be in an area with an open wi-fi network or have a wireless router in your home. Find your password for the router's wi-fi network (it should be password-protected) and the SSID; you also need the encryption type (WAP, WEP, etc.).
Press Apps on the Home Screen. Then press Settings and then Wi-Fi. Select Scan to locate available networks. While on the Wi-Fi tab, press Add Network. Enter the SSID with the keyboard, then touch Security type to select the encryption for your router. Then enter the password and finally press Save. (Some wi-fi routers will want the MAC address before you can add a device to the network. Go to the Menu - Advanced from the Wi-fi tab to get the information.)
If the wi-fi network has been set up on the Tab, press Apps on the Home Screen. Then press Settings and look for the Wi-Fi On/Off icon. Toggle this to on. (You can also access this by touching the time on the Home Screen. Then touch Wi-fi on the Quick Settings list.)
I hope this helps.
Jan 16, 2013 | Samsung Galaxy Tab 2 7.0
I cant get my tablet to connect to wifi
Android tablets, unlike Android phones, don't require mobile phone service or a contract with a mobile phone company, and several models use Wi-Fi for network connectivity. The Android 3.0 operating system, known as Honeycomb, is designed specifically for tablets, and has the same features for Wi-Fi connections that are available with earlier versions of Android. Android tablets support wireless connections encrypted by both WEP and the more-secure WPA.
Tap the "Apps" menu on the tablet screen. Touch "Settings." Touch "Wireless and Networks" and select "Wi-Fi Settings." Tap the "Wi-Fi" box to turn on Wi-Fi. The Android tablet scans for available Wi-Fi networks and displays them on-screen under "Wi-Fi Networks." Tap an available Wi-Fi network. Touch "Connect" if it is unsecured, or enter the password or passcode for the encrypted connection.
Tap "Connect."
Jan 14, 2013 | Polaroid 7 in. Internet Tablet
How to install broadband to android tablet pc?
Share 01 Feb
2011 How to configure IP address of wi-fi connection on a Android Phone (Samsung Galaxy Tab) Posted in: Gadgets Tagged Under: Android, Galaxy, Samsung, Tab 7 Comments samsung_galaxy_tab-small-1.png
By default Androids phones (including Samsung Galaxy Tab) are set to automatically configure IP address, Gateway, Netmask and DNS address of wi-fi network.
But if you want to manually assign IP address, Gateway, Netmask and DNS address of wi-fi, here is how you can do. Method below is described for Samsung Galaxy Tab, but it will work for all Android phones.
  1. On Home screen, press Menu key.
  2. Tap Settings
  3. Tap Wireless and network.
  4. Tap Wi-Fi Settings.
  5. Press Menu key again.
  6. Tap Advanced.
  7. Enable "Use Static IP".
After you have enabled "Use Static IP", you will be able to manually assign and configure IP address, Gateway, Netmask and DNS address of wi-fi network.
Sep 23, 2011 | Android Apps
I purchased a new IPOD and I can not access the wifi from my Linksys wireless router.. I reset my Linksys router to try to solve this problem. And at first when the light was amber I was able to have...
Resolution If you know there is a nearby Wi-Fi network, but you are unable to locate it on the Settings > Wi-Fi screen:
  • Move closer to the Wi-Fi router or hotspot.
  • If you are using a personal Wi-Fi network, verify the Wi-Fi router is connected to power and turned on.
  • Wi-Fi networks configured as "closed" or "private" do not broadcast the network name to Wi-Fi devices.
    • Join a "closed" or "private" network by tapping Settings > Wi-Fi > Other and entering the Wi-Fi network name, security, and password.
After joining a Wi-Fi network, if you notice the signal strength is low or intermittent
  • Check for any sources of potential interference.
  • Remove any cases or attachments on your device that could interfere with a Wi-Fi signal.
If you are unable to access the Internet while connected
  • If you are using a commercial Wi-Fi network that requires a special login or subscription, see this article for more information.
  • If you are in a location with multiple Wi-Fi networks, verify that you are selecting the correct network.
  • Verify that the Wi-Fi network settings are correct:
    • Tap Settings > Wi-Fi.
  • You can configure network-specific settings, including IP address, DNS, and Search Domain settings.
  • Use "Forget this Network" to reset settings for this particular Wi-Fi network, including the password. This is also useful if you identify a network issue and want to prevent the device from automatically using this network in the future.
  • Use "Renew Lease" to acquire new IP address, DNS, and Search Domain information from the Wi-Fi network.
  • Note: If the Wi-Fi network uses MAC address filtering, you will need to add the MAC address to the access list for the Wi-Fi router. The MAC address for your device is listed as the Wi-Fi Address in Settings > General > About.
If you are still unable to join a Wi-Fi network, or are unable to access the Internet while connected, try the following
  • Restart the device
    • Hold the power button until "slide to power off" appears. Slide to power off your device. When it is off, press the power button to turn it back on.
  • Reset network settings by selecting Settings > General > Reset > Reset Network Settings. Note: This will reset all network settings, including passwords, VPN, and APN settings.
  • iPhone only: If you continue to experience issues, consider turning off Wi-Fi and using the cellular data connection instead of Wi-Fi.
Additional Information If using a Wi-Fi router at home, refer to your user manual/documentation to assist you with some of these suggestions.
  • Check the manufacturer's website for your Wi-Fi router for firmware or software updates.
  • Verify the Wi-Fi router can broadcast an 802.11b/g signal. If using a 802.11n Wi-Fi router, consult the manual/documentation for how to configure the Wi-Fi router for 802.11b/g compatibility.
  • If you are using multiple WEP keys on your Wi-Fi router, try configuring your Wi-Fi router to use only a single WEP key.
  • Try or resetting (or turning off and then on again) your Wi-Fi router. Note: If your ISP also provides cable or phone service, check with them before attempting this step to avoid interruption of service.
  • Disable wireless encryption or security on the Wi-Fi router to rule out encryption issues. If this resolves the issue, try using a different encryption or security protocol.
Mar 22, 2010 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
