Question about Health-O-Meter Health o Meter BFM588DQ-81 Body Fat and Hydration Percentage Fitness Scale, Champagne,
Batteries it show an l in place of 0
    Problem Solver:
  • 5 Answers
I'm just guessing at this point, the "L" probably stands for "Low" as in "Low Battery". Don't discard the old one,just switch it out with a new one and see what happens.
Posted on Jul 16, 2013
NC10 battery always shows 0%
Try replacing the battery as it may be exhausted.
Jan 17, 2016 | Samsung NC10 Netbook
Why is The scale is not measuring anything?
Did you remove the transport protection?
Perhaps you should remove the battery and reinsert it again?
Jun 27, 2014 | Taylor 3831bl Digital Scale 6.6...
HYOSUNG GT 259 R 2007 CHANGED BATTERY AND SOLENIOD BIKE WILL NOT START JUST CLICKINH NOISE FROM SOLNIOD
If you can get to the solenoid,, take a screwdriver and jump the two large threaded terminals .... the engine should turn over.
BE CAREFUL - SPARKS WILL FLY!!
If you jump the terminals and nothing happens - one, the battery is bad (shows 12 volts but has 0 cold cranking amps) - two, you have a wire that is not in the right place!
Check this and repost to me.
Apr 10, 2014 | 2006 Hyosung GV 250
How do you adjust the tanita 1479 scales
what do you mean by adjust it? to calibrate it follow below
Switch off.
2. Press and hold OFF key.
3. Quickly press ON/ZERO key three times then release both keys together. The timing is rather critical, so if it doesn’t work first time, try again.
4. Display shows [ 0.-0- ], followed by [ 0.-1- ].
5. Place 50gm weight on plate.
6. Display shows [ 0.-2- ].
7. Place 100gm on plate.
8. Display reverts to weighing mode.
Mar 12, 2010 | Tanita Health & Beauty
Error code 20000
...Actually it probably says error code 020000...flash test.
Other error codes: 6 digits in codes:
left to right digits;
1- Battery Test 0= Pass; 1= Fail ( batteries have to be good and in place even if using power supply (100000)
2=Flash Test/ Flash Charging 0=Pass; 1= Fail (020000)
3= IR Sensor Test 0= Pass; 3= Fail (003000)
4= Camera Mod Test 0= Pass; 4= Fail (000400)
5= Memory Test 0= Memory o.k. or no sd card; (000000) 5= Memory Full (000050) 6= SD card locked (000060) 7= SD card damaged (000070) 8= Comms Error (000080)
6= Clock Test 0= Pass; 9= Fail (000009)
ALL SYSTEMS OK= 000000, GOOD
WHEN PERFORMING THESE TESTS, FOR THE FLASH TO TEST OK YOU HAVE TO COVER LIGHT SENSORS small glass items each side of lens.If you still have error, install good batteries, power on, drop batteries out, turn unit off, reinstall batteries and turn on again....if all this, you still have error, you probably have bad flash unit.
Feb 03, 2010 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Taylor 7532S, battery replaced, error message 0-Ld
Try to reset the unit. Use the following steps
- Open the battery compartment on the bottom of the scale. Push the tab on the door and lift the cover.
- Remove the battery from the compartment. Close the battery compartment door.
- Sit the scale right side up on a hard surface floor.
- Step on the scale and stand still on it for five to ten seconds. Step off the scale.
- Turn the scale over and open the battery compartment. Re-insert the battery. Close the battery compartment cover.
- Place the scale right side up on the hard surface floor.
- Press one foot on the scale until the display shows zeroes or dashes. Remove your foot.
- Wait for the scale to shut off by itself. When you step back onto the scale, it will be reset.
Hope this solution has been helpful?
Jan 26, 2010 | Taylor 7532 Ultra Thin Glass Digital Scale
Health-O-Meter Health o Meter BFM588DQ-81 Body Fat and Hydration Percentage Fitness Scale, Champagne,  Logo
117 people viewed this question
Top Health-O-Meter Health & Beauty Experts
Shehu Pro
Shehu Pro
Red721
Level 1 Expert
richie46
Are you a Health-O-Meter Health and Beauty Expert? Answer questions, earn points and help others
