Question about Refrigerators
Ge refrigerator cfsp5rkbc setting keeps changing and beeping
For some reason, my refrigerator keeps running trhough different settings - water cubed crushed and the temp settings change. All on their own - no one touching. It beeps with each change. Does it a few times and then stops by itself.
peyton32034
  • 410 Answers
SOURCE: GE ESS25XGMC WW Side by Side
its possible that your water tank has frozen up, try turning the refrig off and leave the doors open for about 10-15 mins and try it again. if that works just reset temp controls a little lower..
Posted on Dec 16, 2007
  • 1073 Answers
SOURCE: GE GSH22SGRE - water dispenser not working but ice cube maker working fine
check the water valve on the back of the ref. it sends water to the ice maker and water in the door one can work and the other one not
Posted on Apr 30, 2008
tborn6
  • 700 Answers
SOURCE: beeping
basically its telling you that it's not maintaining the temperature that you have it set for. if indeed you do have this particular model number contact me and i have the service manual for it.
Posted on Feb 04, 2009
tborn6
  • 700 Answers
SOURCE: Change water filter for a maytag plus refrigerator
press the light switch button inside of the refrigerator five times.
Posted on Apr 03, 2009
jeffbvegas1
  • 520 Answers
SOURCE: LG ice maker only dispenses crushed ice not whole cubes
Very problematic issue with this model .Try unplugging and plugging the fridgerator which resets the board.The board is located on top under a removeable panel where the power cord enters....there is a reset/diagnostic button on the board itself.Contact LGUSA.com for any possible warranty and complain like crazy to avoid spending $300 on this board which can be purchased from andrewselectronics.com who is a factory authorized parts provider.Keeping that ice maker going will make you pull your hair out which is unfortuante for such a stylish and expensive fridge.good luck
Posted on Jun 28, 2009
The ice maker of our GE GSH25JSXSS is only producing crushed ice even when it's set to cubed. Is there a way to fix this issue?
Check that the shifter bar on the bottom of the ice bin is moving to shift from cubed ice to crushed. With the ice bin out you should see movement in the back wall of the freezer with the light switch button held in while changing the dispenser controls from cubed to crushed. GSH25JSXASS Parts
Ice Bin Parts
Appliance 911 Sea Breeze
Nov 03, 2015 | GE Refrigerators
Icemaker dispenses crushed ice when you select cubed ice
GE has a problem with the flap on the door which lets the ice out , not closing due to a rusted solenoid behind the panel . If this flap does not close , frost will get inside the ice bin , not letting the bin flap open to let cubed use come thru, only crushed . You can defrost the ice bin front and replace the door flap solenoid easily . If this is the problem , repost about replaceing the flap solenoid for further instructions if needed .
Jul 27, 2010 | GE GSL25JFPBS Side by Side Refrigerator
GE PROFILE PTS22LHPARWW ICEMAKER NOT WORKINNG
change or remove filter
change control valve
change valve on copper water ine
change copper water line
check input pressure to unit
25? 25? anybody know what is the minimum water pressure supposed to be entering the refrigerator icemaker?
Oct 23, 2009 | GE Refrigerators
Ice maker only dispenses crushed ice, won't dispense cubed ice anymore.
I have a GE TFX25ppbaaa refrigerator. The ice maker corkscrew motor would run and provide crushed ice only. The corkscrew motor would not run when the switch was moved to the cubed ice ( half moon) setting.
I replaced the large Light/ water/ crushed ice/cubed ice switch , ( product service number GEH WR55X129 ) ( part number GE 162D6372 PO17 )and it fixed the problem. Cost was about $43.00.
Apr 17, 2009 | Refrigerators
GE Profile Arctica - Frig Freezing Food
Replace the damper assy, in the Refrigerator section. The damper door is stuck open. Very common problem on these refrigerators.
Nov 24, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE ice maker model #THH30PRTBAA
could have a sticking water solonoid valve.if not,it gets more complex.(Dip settings on the board.)
Aug 09, 2008 | Whirlpool GS6NBEXR Side by Side...
Ice dispenser only dispenses crushed ice
You may not need to replace the solenoid.  If you hear the hum, and not a loud click and don't see then rod move, it may be frozen with ice.  Test it manually with your hand, it should be free  to move up and down.  If not, then it is frozen with ice.  Remove the ice dispenser and let it thaw and dry out.  You should then be able to move to rod and it will work fine, at least until it freezes again.  Anyone know how to prevent it from freezing up? Its a continual problem for me
Apr 06, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice & water control buttons
sound like a bad(shorted) dispenser user interface INTERFACE DISP ASM WR55X10415
Apr 03, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
