Question about Air Tools & Compressors
Coleman mod.vp0200406 no pressure
  • Air Tools & ... Master
  • 17,093 Answers
The are valves on the head on the compressor and they are stuck. You can get a rebuild kit for the head.
Posted on Jul 21, 2013
Single flash, coleman mod #dgat070bdd
Possible problem with the gas valve?
Dec 07, 2016 | Coleman Heating & Cooling
Coleman Powermate VP201 will not go above 40 lbs.
Hi mjschulte815
Here are a few things to check, you may have already checked some of these.
Electricity...Compressors will run best with full 115Vot 15AMP/Or 220V electrical supply from a circuit, over the shortest electrical cord as possible.
Air Leaks..Place your ear close to the compressor and listen for air leaking, if you hear air that is not normal and means you have to locate and repair whatever it is that is leaking.
Check the air unloader valve... The air unloader valve will blown out air when you turned off the compressor, that is normal.
But it should not have air leaking out of it all of the time. If so then it is faulty and in need of repair/replacement.
Valves...If either the intake or exaust valves fail, breaks, or fails to seat, then your compressor will run 24 hours a day and never build up to the correct pressure for shut-off.
Gaskets...Check to see if your gaskets have failed.
You could have a gasket failure between the pistons and you will never know it because it shows no external air leak.
If this situation happens then the air will only cycle between cylinders and never build up the correct air pressure.
One way to check the gasket is remove the air filter, then put your hand over the intake.
Please take time to rate me
Bud
If correct then it will **** you hand against the intake.
If the valve or valves have failed then you will feel the air sucking in and blowing out.
Piston Rings and Cylinder...The piston rings could be stuck,broken, or worn and not allowing the correct pressure to build up in your tank.
A worn cylinder will also contribute to the problem of pressure build-up.
Pressure Switch...Check for air leaks at the pressure switch, it has a rubber diaphram that can fail and leak air out of the system.
Bud
Oct 17, 2012 | Coleman Model Vp0200406 Powermate...
Do you have a manual for mod # 130A ser# u-20150
The Coleman Model # 130A , Above Ground Pool and Spa Heater was manufactured by Raypak for Coleman and several other companies, using the same Model Number. With that said, here is a link to the Owners Manual for Model # 130A. You can download and print it for future reference.
http://www.raypak.com/uploads/6100.59G.pdf
Hope this helped you.
Mar 29, 2011 | Coleman Heating & Cooling
I have a coleman inflatinmat model VP0200406 - it doe not pump any higerthan 60 psi and takes a vry long time to do so. I have replaced th 7 amp fuse twice due to it blowing while inflating
your in take valve is not closing alowing air back to the piston. its mownted on the tank. the line from the pump to tank at tanks end. replace it frist
Oct 11, 2009 | Air Tools & Compressors
Coleman Powermate Inflationmate portable 4 gallon compressor. Model VP0200406. See image at http://www.yotatech.com/f5/how-fix-compressor-111315/ . Coleman lable on back says 120 v, 15 amp, single phase,...
Use a 15 amp 'time delay fuse'. Any time you start a motor, the inrush current will blow a regular fuse. Motors pull high current to start then drop to normal after 1 or two seconds. The time delay will fix it up!
Sep 20, 2009 | Air Tools & Compressors
Not cooling as well as should be
THe low side should be 34 degrees f. Which is about 65psi.
May 09, 2009 | Heating & Cooling
Evcon coleman furnace
I have a Evcon mod.# DGAH077BBSB with 4 light flash code
Jan 23, 2009 | Tools & Hardware - Others
Air Tools & Compressors Logo
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
