Question about Yamaha HS10W Monitor Speaker
Yamaha HS-10W Subwoofer Blown?
I am looking to repair blown sub myself. Any suggestions/manuals that will help me? Thank you.
  • 238 Answers
SOURCE: Yamaha YST-SW150 Subwoofer
hi, is it a humming noise ??? check if the connector is plugged in properly,check the earthing, if its a three pin mains plug, if its a two pin, then the CPU SMPShave a proper eathing. let me know
Posted on Jan 12, 2008
  • 236 Answers
SOURCE: Yamaha RX-V1200 subwoofer connection to Mirage BPS-150i subwoofer
just connect your subwoofer mono RCA to your amp sub single out rca connector. you do not need to megre all those 4terminals into one. in fact internal circuit of those 4rca are merging inside to one since the sub uses only a single amp. 4inputs was meant for sources with multiple sub out
Posted on May 03, 2008
  • 3567 Answers
SOURCE: yamaha yfs 200 blaster manual
You might find a free pdf service manual on this site, they have a ton of them.
http://www.carlsalter.com/motorcycle-manuals.asp
or try your local library. Often guys will donate manuals to the library.
Please rate this solution. Thanks wikusnagel!
Posted on Apr 06, 2009
dunnbiker
  • 8546 Answers
SOURCE: Bose Acoustimass 15 subwoofer is completely dead.
Clarify, did it ever work for you? Were both receivers used properly configured for the subwoofer? Did you also test the other speaker moduels running off the subwooferto see if they work?
Speaker Receiver setting
• Left and right LARGE
• Center LARGE
• Left and right surround LARGE
• Center surround* LARGE
• LFE/Subwoofer ON
With an Acoustimass 16 Series II system or upgraded Acoustimass 15 Series IlI system only.
Posted on Apr 28, 2009
tech240
  • 169 Answers
SOURCE: need schematic diagram of YAMAHA P7000S
Best find your local dealer as cd are not usually supplied to end users.
Posted on Sep 20, 2009
Im getting sound through my wired speakers but no bass through the woofer itself, does this mean i have a blown fuse or something more serious?
1. Check audio wiring.
2. Check subwoofer power cable.
3. If you have any way to substitute for the subwoofer this can confirm wiring.
4. The crossover in the amp may not be working, sending no low range to the subwoofer.
Jul 22, 2014 | Sony SA-W10 Subwoofer
I can't get my reciever to play my subwoofer
The sub channel will be switched off. You need to find the speaker settings, locate the sub channel settings and switch it on.
Jun 16, 2017 | Yamaha RX-V663 Receiver
I GOT A YAMAHA SUBWOOFER SW 315 FROM USA WITH 120V RATING. BY FAULT I PLUGGED IT INTO 220V . NOW THE POWER LIGHT IS COMING BUT NO SOUND IS COMING FROM SUB. HOW CAN STANDBY LIGHT COME IF I BLOWN THE...
chances are that you have blown part of the circuitry insode the power supply. The power supply is recieving power, hence the standby light but not giving any actual output. If you are competant with electronics and can work on the power supply safely, take a part the power supply and look for any components which look to have scorching around them and test for operation. Obviously make sure that the units is UNPLUGGED from the mains supply before attepting this.
May 02, 2011 | Yamaha YST-SW315 Subwoofer
Subwoofer
Without being able to access the receiver in person, the best advice I can give you is to sit down with your user manual and follow the instructions. You'll find, starting on page 85, the necessary settings for hooking up a subwoofer to the receiver. If you don't have the manual, you can obtain a pdf file at Yamaha.com: http://www.yamaha.com/yamahavgn/Documents/YEC/AV_Receivers/Manual/RX-V663_U-1.pdf
May 16, 2010 | Yamaha RX-V663 Receiver
Athena AS-P4100 Sub Woofer - blown main fuse - who repairs these?
Sorry I can't solve your problem. I think the main fuse on mine is blown too. Can you tell me where it is located?
Mar 09, 2010 | Athena AS-P4000 Subwoofer
Looking to fix my engine to do the work myself Is there a DVD that shows how Thank You
look for "chiltons truck and van manual"-for your year covers all makes and bumper 2 bumper repair-also can look for make specific chilton repair manual smaller book/dvd or haynes automotive repair manual book/dvd
Oct 21, 2009 | Mitsubishi Mighty Max Cars & Trucks
Subwoofer is crackling - maybe blown? Was
Crackling is usually a sign of a blown speaker or a misaligned coil.
Both can be very difficult to fix themselves.
However you may be able to buy a new speaker .
You would have to dismantle the sub and remove the broken one first.
A goo hi-fi shop or even musical instrument shop may be able to help you with that.
You would need to know the impedance of the blown unit along with its frequency range. That information would usually be in your user manual.
Its not a difficult job but if it is a powered sub then be aware of electrical hazards and ensure it is disconnected from all sources before attempting any work.
Oct 08, 2009 | Boston Acoustics MicroMedia Computer...
Blue convergence is bowed
The Convergence circuit probably has failed and unless you are familiar with the circuitry I
would suggest getting a professional repair facility. If you are, replace the convergence IC's and also look for any open resistors for the Blue Sub-Yoke
Hope this helps,
Skyassoc
Jun 24, 2009 | Hitachi 50GX30B 50". Rear Projection...
What amplifier should I use for 2 650W Subs?
HI DUDE .. I JUST GIVE suggestions Boss Car Audio D5504 "Diablo Series" 4-Channel Car Amplifier 2200 Watts ITS REALY GOOD FOR SOUND SYSTEM DUDEaaf1faf.jpg
Jun 10, 2009 | Pioneer GM-6300F Car Audio Amplifier
Subwoofer pushing out problem
it sounds like one channel in your amp had shorted and letting dc go to the speaker...a speaker is an electromagnet and requires ac to make it pulse..the amp has a blown channel and would have to be repaired and a factory service center...there is no quick fix..
May 27, 2009 | Lightning Audio B1.10.4 Car Subwoofer
Yamaha HS10W Monitor Speaker Logo
98 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
