Question about Campbell Hausfeld PW2102 Gas Pressure Washer
Motor quits when pull trigger
I have a troy bilt pressure washer I had a bad pump so I replaced it with a new one. The motor starts when you pull the trigger it stalls the engine, it seems to have pressure but quits right away
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
It's the spark plug more than likely. If engine turns but won't stay running its more than likely spark plug. If that doesn't fix its the gas. Empty gas out get some fresh gas.
Posted on Jul 13, 2013
3 Suggested Answers
  • 10 Answers
SOURCE: pressure washer stalls out when wand nozzle is released
common for not starting unless trigger engaged as you are turning the pump as well as engine creating pressure,as for stalling pump has unloader valve which is probably in need of grease(use good silicone grease)this allows water to ciculate when trigger released.
Posted on Apr 20, 2009
  • 15 Answers
SOURCE: builds up to much pressure in hose and stalls engine
Sounds like the unloader is not working. try replacing it and see if that helps.
Posted on Apr 23, 2009
All outflow stops when I start the motor on my Troy-bilt 2600 pressure washer. What's up?
Could also be crack/leak in HP pump. If it were left in cold weather without antifreeze, I'd check there first. Part + labor might warrant new washer if more than a couple years old.
Sorry.
Aug 11, 2014 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
Power washer wont pump
Call us when you can be at the washer so we can trouble shoot it with you over the phone.
http://www.ppe-pressure-washer-parts.com/troy-bilt-020416-1-pressure-washer-parts
Mar 20, 2014 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
While using our troy bilt 2550 preassure washer it cut out and I could not pull the start cord. After a while I could start it when the water was not connected however when I connect the water it will not...
Try connecting the water but hold open the trigger. While holding open the trigger, try to start the pressure washer. That works for me.
Feb 21, 2014 | Garden
Change oil in Troy Bilt 020245 pressure washer pump
underneath base of motor look for a plug wuth a square slot,i normally use a 3/8" extension with ratchet.
Aug 20, 2013 | Troy-Bilt Troy - Bilt 020245 Pressure...
Change oil in Troy Bilt 020245 pump
if it,s a vertical motor it's at the base of motor look for a plug with a square slot.
Troy bilt G C 720 manual
I have a new troy built garden cultivator (modelGC720). It won't turn and the motor stalls when the trigger is pulled. Should I return it or is there a easy fix ?
Feb 13, 2013 | Troy-Bilt Troy Bilt Gc720 Trimmer Plus...
Troy bilt pressure washer will not build or reach high pressure
check the non-return valves in the pump block. if these are damaged or dirty you pressure will be greatly reduced. they are located behind the 3 lage brass hexagonal caps.
I hope this helps
Sep 04, 2009 | Karcher 2500 PSI Pressure Washer
Campbell Hausfeld PW2102 Gas Pressure Washer Logo
144 people viewed this question
Top Campbell Hausfeld Garden Experts
John Trevino
Mike Squire
Are you a Campbell Hausfeld Garden Expert? Answer questions, earn points and help others
