Question about Garden
Powerwasher pw1800u The motor turns on, squeeze the trigger and water comes out, but there's not any pressure... Help??
The water pump is pretty much shot! Did you crank the pressure washer without the water being on? Most times you see this when this occurs.
Posted on Aug 25, 2013
  • Michelle tindol Aug 25, 2013
    Also, it could be the uploader valve or pressure valve... To check this turn on the pressure washer pull the trigger once.. Now take the tip off the top of the gun and squeeze water out again now, put the tip on. If you have pressure then it's the valve if you still have no pressure could be the pump.
4 Suggested Answers
  • 5603 Answers
SOURCE: sometimes when I squeeze the trigger I will have high pressure
The bypass valve is sticking.
Posted on Sep 23, 2009
  • 21 Answers
SOURCE: low pressure from powerwasher wand when trigger
THIS POWER WASHERS ARE TRICKY, TO OPERATED YOU NEED TO OPEN THE WATER FAUCET CONECTED BY A HOSE TO THE POWER WASHER , OPEN THE TRIGGER AND THEN START THE POWER WASHER, OTHER WISE YOU WILL RUIN THE POWER WASHER PUMP.
Posted on Nov 01, 2010
  • 2428 Answers
SOURCE: My Briggs and Stratton Power
Ican see im going to have to wright this whole thing again . This sight is not good for people like me who know the answers . Something always pops up and loose my well thought massage . like the one i just wrote to you . Briggs olny makes the engine on your mechine you have 3 to 4 differant other companys that make all of the other parts this makes it diffelculy for anybody to get parts for the mechine . But there can olny be two things wrong with this mechine . The first is you have a problem with the valves on the pump body . Do you see brass caps on the valve body remove them one at a time . Check the valve you can remove them with a small pair of niddle noise pilliers look at the plastic cages around the valves they tend to break and jam the valve seats it olny takes one to cause this condution you describe . The other thing it could be is the unloader valve is stuck . This is the part under the pressure control knob and you will need to remove it . What it dose is allow the presserized water to recurlicate back through the pump body when the trigger is not open . This could also cause this condution . Most of the time it can be freed up with some WD40 and most are not servicable as a unit and lots of luck trying to find one .But the chances are good you can free it . In the winter time you should put antifreeze in the mechine disconnect the plug wire pull the cord until it comes out the other side this will protect it from the water freezeing and expanding and damageing parts aswell as corroition . Well good luck from what you descriped the valves but you should also turn that pressure knob in and out on a regular baicis to keep it free
Posted on Jun 08, 2011
Why doesnt my powerwasher pump out water
check for a blocked jet in the end of the wand ( squashed hoses or blocked hose to the wand)
the blocked jet has the same affect as not pulling the trigger and the pressure regulator bypasses the water back into the pump
Sep 08, 2015 | Annovi Reverberi RMV2.5G27D Pressure...
It starts turns on but water will not come out of nossel???
Many of these devices have strainers on the input (garden hose connection) of the pump. Remove the hose and check and clear debris from strainer. Reconnect hose and turn on supply water. Do NOT start engine / motor. Pop the nozzle from the end of the wand and squeeze water trigger. Hose pressure water (or less) should flow from the wand. Of not, youll have to see if water is leaving the pump by inserting the nozzle (or something that will if it) into the hose connector. If water still does not flow - there is an issue with the pump.
May 18, 2015 | McCulloch Garden
Why does my pressure surge
Common problem across brands. When you spray water the drop in pressure triggers the motor to take the hose pressure ~ 30 psi and boost it to ~ 3000 psi. Water coats these parts with calcium (hard water) or other junk and water contains bacteria which causes slime and scale. Once that pressure switch / valve is sufficiently clogged it doesn't move smoothly so it can fluctuate between sending a yes / no signal about whether you are squeezing the trigger or not. This causes the pulsing.
EZ test: take the the tip off the wand, start the unit, squeeze trigger - should run continously with no problem. If it does for sure you need to watch a video on dissembling and cleaning the valve body. It is not hard but you must work carefully to avoid losing parts especially springs and take digital pictures to record the order for reassembly.
Jun 04, 2014 | Dewalt DPD3100 Gas Pressure Washer
No Pressure
Same problem here. Machine still looks brand new. Absolutely no nicks in the hose. Electric power is just fine. I hear the motor, then when I squeeze the trigger, I get a weak dribble of water for about 5 seconds, then the motor is quiet for a while. This sound familiar to you? I just posted my similar problem. If you hear anything useful, please forward it to me : reb49@att.net Ron
Apr 30, 2013 | Task Force 2000 PSI Electric Pressure...
AT FIRST WITH JUST THE WATER ON (PUMP OFF) I SQUEEZE THE WAND AND WATER COMES OUT ABOUT 3 FT. THEN WHEN I START THE PUMP AND SQUEZE THE WAND ONE STRONG SQUIRT COMES OUT THEN GOES BACK TO ABOUT 4 FT. NOT...
Hi, W/D here.
Leave the water on, and hold the trigger down for about 5 minutes to get all of the air out of the system. Letting off of the trigger occasionally and then opening it up will help displace any air in the chambers. While still holding the trigger down, start the washer. Should put up your desired pressure.
Best regards, --W/D--
Feb 14, 2011 | Comet Axd3020g Pressure Washer Pump 27 Gpm...
Low pressure from powerwasher wand when trigger is squeezed
Nov 01, 2010 | Briggs & Stratton Garden
Karcher K2.36 motor cut out and won't restart
Yes, the water should be turned on first but if it only ran for a minute or two it should be OK. Most late model pressure washers have an automatic shutoff when the trigger on the wand is released. Turn on the water and then the machine and then squeeze the trigger on the handle of the wand and the motor should start as soon as the air is cleared from the line by the flowing water (about 10 seconds). If the unit was put away wet last season you may need to clean the nozzle with a piece of wire too.
Apr 16, 2010 | Karcher Garden
My electric pressure washer's motor will not start. the 110 plug has a test/reset fuse on it. when i plug it in the light comes on. i push test- it turns off but motor does not run. i push reset and...
With the water faucet turned fully on and the power switch on squeeze and hold the trigger for at least 10 seconds to let the water flow push the air out and then it should start up.
Apr 15, 2010 | Campbell Hausfeld PW1750 Electric Pressure...
No water coming out from powerwasher. Motor is running
check the filter at the inlet water pipe connection, a long nosed pliers may help to remove.
Aug 16, 2009 | Coleman Powermate DuraBuilt 1400 PSI...
I HAVE A BRAND NEW TROY-BUILT 2600PSI pressure washer. I have used it twice for about 1/2 hour each time. It worked perfectly. I tried to use it today with everything hooked up perfectly. The Honda engine...
Sounds like the governor is stuck. My pressure washer speeds up when it has to pump. Don't know if yours uses vacuum to trigger governor or direct linkage. Good Luck.
Jul 04, 2009 | Psi Blue Max 2200 High Pressure Gas Power...
Garden Logo
154 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
