Question about Garmin Forerunner 201 GPS Receiver
Battery replacement for Forerunner 201
How do you replace a battery on a Forerunner 201 and what kind of battery does it takes? THANKS!
JohnE5
  • 34 Answers
SOURCE: Garmin Forerunner 201
Try a reset. Hold the reset and power button for 30 seconds.
Posted on Jul 11, 2008
  • 84 Answers
SOURCE: pulse meter died on forerunner 305
You may need to re pair the unit with the heart rate monitor. Settings/ General/ Accessories/ Heat rate monitor. RESTART SCAN. OR follow this link (Hope it works) https://buy.garmin.com/shop/store/manual.jsp?product=010-00467-00&cID=142&pID=349 Go here and click on owners manual. Go to page 46. Adding accessories.
Posted on Jun 08, 2009
SOURCE: Change battery on Garmin Forerunner 301
Hi - look at this solution for a forerunner 201, which has the same case design. I was just looking myself! R_nz Rank: Apprentice Rating: 96%, 8 votes I've made some progress here, I discovered that there is a small notch beneath the flat black pastic insert that holds the rubber button cover in. By gently prising this out, I can at least expose the pcb with the buttons on. I still can't figure out how to open the case though ****! Comments: Jan 29, 2008 - Well, I got there in the end! As above, I managed to prise the plastic insert cover off the rubber button cover, the peeeled this off as well. Underneath is a mylar printed circuit with the silver domeos of the buttons moulded in. This is siliconed down, but you can peel it up with a fingernail. The top left end (above the on button) is aatached inside the case, so start at the other end. Jan 29, 2008 - .ctd.. Once you have lifted the mylar strip, you can get at the case seam underneath and prise it gently open with a flat blade. The case is glued together with a light silicon or something. My problem was unresponsive buttons and by detaching and then re-attaching the small connector by the big silver block where the mylar attaches to the main board and then re-attaching it, it seemed to fix it! :-) Oct 22, 2008 - As an end-note; I glued my 201 back together with a light Silicone sealer. It seems to be at least rain proof anyway. Forerunner 201 battery replacement (Expert level): Opening the 201 was not easy and could not be done 100% clean, but thanks to R_nz (above) I got it open. My problem was dead (almost) battery, after 6 years of superb operation. I found the battery to be glued (double sided tape) to the back cover. To remove, push it up slowely and pull out. Beware of the short wires. 1. It is a flat battery, wrapped in shrinkable tube. Made by MDTechnology, P/N 043048 3.7V, 500mAh see http://www.mydbattery.com/EN/products.asp?ID=12 2. On the cover, the battery is soldered to the underside of a small PCB, hard to get to (by expert!). If you find a battery, suggest to cut the wires and solder wire-to-wire. Hope that helps
Posted on Jul 08, 2009
  • 84 Answers
SOURCE: My garmin forerunner 305 HRM suddenly stopped
I found this on the internet......
In the battery compartment there’s a gold contact that touches the top of the battery (+ve) which was in a position that would never make contact with the battery. I bent it out slightly, made sure the battery was seated correctly (i.e. flat) and as if by magic my heart rate appeared on the large Garmin display!
Also found this..........
I Have had the same problem couple of times (and forgotten each time how I solved it). I figured it out just now and this is what I did.
1) turn on unit and put on heart monitor (make sure battery is good and wet heart strap)
2) using the mode button navigate the menus to: Settings: General: Accessories: Heart Rate Monitor
3) Once in the Heart Rate Monitor option make sure "Yes" is selected and then use the arrow buttons to highlight "Restart Scan" . Press the enter button to rescan for your heart monitor. (I had to rescan twice)
Go back to the main monitor screen to see if you are recieving heart rate signals.
I am not sure why a manual rescan needs to be done every time but it would be nice if Garmin fixed this issues in a unit software update (my unit has software version 2.80
Posted on Nov 13, 2009
SOURCE: Garmin Forerunner battery replacement
It's not always the battery, I assumed it was and opend mine up to check it out but the battery was OK.
Problem was the unit wouldn't start without pressing mode + reset followed by the power button.
I lifted the internal watch contact strips to put a better connection between the two halves but that made no difference.
I found that I couldn't delete all the history and the watch had recently turned itself off on a run after giving a low battery warning => the history was corrupted and caused the watch grief.
The only way I found to delete the history was to load a v 2.80 (or earlier) version of the watch s/w (current 2.90 doesn't delete history and there is no tool to do it!)
Fortunately I had a copy of v2.80 but the old version is not now on the Garmin site (that I saw).
Moral of the story, don't run your battery low for two reasons, Li-ion batteries lose capacity if you run them below ~30% and also if the watch "low battery" turns off while recording it can corrupt the history and really upset the watch.
At least I now know how to open the watch and have found plenty of possible small mobile phone batteries that will fit (Samsung have a few possibilities). The ABSOLUTE max size of a replacement battery is 36mm H x 43 mm wide x 5.8 mm deep.
If you go 43 mm wide you have to trim a couple of internal plastic ridges in the case.
Good luck and try starting after pressing mode + reset if it won't fire up then try and delete all the history.
Also DON'T run the battery low if you want it to last, Li-ion work opposite to NiCad and NiMH which should be fully discharged before recharge. You try and keep them above 50%.
Steve
Posted on Dec 25, 2009
Garmin 201 forerunner no charge
That unit is probably 7-10 years old... it probably has a dead battery. either buy a new one or get out your special screw driver kit to see if the one inside can be ordered from someone like Batteries+ or Amazon.com
Aug 04, 2014 | Garmin Forerunner 201 GPS Receiver
My garmin forerunner 201 has no display
Did you just post about a dead battery? I think you did. Either replace the battery or get a new unit.
How to remove battery from garmin 205 ?
they are fixed in you have to take the hole thing to bits
Jul 27, 2014 | Garmin nuvi 205W GPS Receiver
The battery on my 201 forerunner is only lasting 5-6 hrs, how do I change batteries and is it worth it. Cheers Tom
It is actually meant to last for 15 hour per charge, and it lasting just 5-6 hours simply means it is either not fully charged or the battery is weak.
It uses a lithium ion rechargeable battery, and it can be replaced, you will have to open it up to be able to locate the battery.
If you are not familiar with such activities, i will strongly advice you get a repairman replace the battery for you.
Since taking a walk with it wont take up to 5-6 hours, it will be best you leave it that way, and try to recharge as soon as it drops, but if you use it for over that amount of time in a day then you can replace it. the battery is located right underneath the wrist band used in strapping the hand.
Take care
Oct 12, 2010 | Garmin Forerunner 201 GPS Receiver
I'm looking to buy a replacement charging cradle for my Garmin Forerunner 201 but the only ones I can find also come with an adapter and I'd prefer not to pay for something I don't need. Any suggestions?
Contact Garmin at 1-800-800-1020. You can order the cradle part for your Forerunner 201 for $6.54 plus $8.00 shipping. You can also get the complete charger on Ebay as low as $20.50 including shipping. Thats the best I could find.
Jun 11, 2010 | Garmin Forerunner 201 GPS Receiver
Where can I buy the 043048 replacement battery for the Garmin 201
Good question I am also faced with. Garmin Europe did not/could not help. I found this supplier in the US: http://www.ecrater.com/product.php?pid=5375133
but at this price you cannot expect quality and the battery may be even dangerous...
please post your experience/success here (if any)
instructions see under http://www.fixya.com/support/t2546458-change_battery_garmin_forerunner_301
good luck! swisscheese
Oct 14, 2009 | Garmin Forerunner 201 GPS Receiver
The screen on my Forerunner 201 is suddenly blank. Is charged. Wasn't dropped.
I left the unit on to run the battery down completely, then put it on charger and the screen was readable again.
Sep 02, 2009 | Garmin Forerunner 201 GPS Receiver
Jul 08, 2009 | Garmin Forerunner 301
Mar 11, 2008 | Garmin Forerunner 201 GPS Receiver
Garmin Forerunner 201 GPS Receiver Logo
373 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
