Question about Electrical Supplies
Cannot start the generator
Put fuel in tried to start, used the choke on various settings, still no joy
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,069 Answers
When was the last time it ran?
If you didn't run it out of gas the last time you used it and it sat for a few months, the Carburetor is gummed up.
You can thank the wonderful idiots that think Ethanol Gas is a good idea
Posted on Jul 15, 2013
4 Suggested Answers
SOURCE: Coleman Generator powerbase 4000 model #PM0543800
I have to leave a comment for cfa6094. Your pretty good at flexing your cyber muscles. I am a service tech in the repair field and deal with people like you all the time. If you are the owner of the equipment you should properly maintain your equipment. Sounds like you are not very organized. Sound more like crises management to me. Is mrfixit the only person you asked about this problem? One more thing, sound like you are a bit of a procrastinator to me. LOOK AT ME NO SPELL CHECK!
Posted on Feb 07, 2009
  • 136 Answers
SOURCE: I have a coleman 5000w generator that I have
check the condition of your air cleaner . you have to have one in order for it to run right or run @ all
Posted on Nov 06, 2009
  • 1267 Answers
SOURCE: My 4 year old Craftsman
Not that i am aware of, however, I suspect that as soon as you load it up it will die again as the load will call for greater speed, and too much fuel from the choke position will cause it to die again.
What I suspect is that your carburator is clogged up at the jets and is not metering the air fuel mxture properly. You may have to disassemble the carburator and clean it. Since the government has mandated that gasoline contain 10% alcohol, it has become a night mare for small engines that are not used very often. The alcohol is very hydroscopic (retains water) and during the off use period, the alcohol evaporates and leaves the water behind to mix with gunk and clog the needle valves.
Try removing the old gasoline. Refill the machine with fresh gasoline and add some "SeaFoam" (an additive) or any other brand additive that will help disolve the built up gunk in the carburator. Remove the air cleaner and try spraying a carburator cleaner down in the air intake while the machine is running, this way the air passages may clear while the new gasoline may dislodge the built up gunk. Note: The carb cleaner will stall the engine.
It is probably wise to run the gas tank dry before storage and only fill when the machine will be used. Stabil is an additive for storage, and it did it's job before the alcohol edict. I am not sure that Stabil will allow long time storage. (more than 3 months) SeaFoam can be purchased at WalMart, stabil is on the shelf of most small engine sales rooms such as Sears.
Posted on Jan 09, 2011
GUARDIAN 40G generator crabks but won't run.
Is on/off switch in "on" position - set choke? fill with gas? Is switch on gas line to carb in "on" position.
If does not start then you either have a spark or fuel delivery issue and you need to trouble shoot the various systems.
Ig as was left in carb last time used, it is possible that the gas jelled and clogged up the carb and now the latter needs cleaning/overhaul.
Aug 31, 2015 | Guardian Electrical Supplies
How to start the generator
Hi Joe, I had asked for a little clarification and have not received any information. I will answer this question based on the generator is in good working order and it is a recoil start. Open the petcock, (this is the fuel valve) and give it about a minute to fill the fuel bowl on the carburetor. If your generator has an engine an on/off kill switch, set to on. If the generator has an auto idle switch set it to off. If the engine has a throttle lever located under the carburetor, push it all the way down (full throttle). Pull the choke knob out completely, there is a detent on the choke for half choke, pull it past this for full choke. pull the recoil starter rapidly. As soon as the engine starts running push the choke knob to half choke, this will allow the engine to run smooth while it's warming up. Depending on the climate that you are in, warm up time will vary. After a minute or two in cold climates start pushing the choke knob in, if it starts to run poorly pull it back out too the half position and let it warm up some more. When you can posh the choke in without the engine faltering it is ready to go. In warmer climates you might be able to start the engine without the choke or in the halfway position. Robin Subaru makes some of the finest small engines available. I would choose a Robin over a Honda every time. I hope this gets your generator going, and once again this is based on the generator being in good working order. Good luck, Michael Burke.
Dec 03, 2011 | Coleman Powermate Subaru 5000W Portable...
Generator stored in garage, we run it once a year to make sure all is well. Hurricaine coming, got out generator put in new gasoline, set in choke position. Generator tries to start, but will not stay...
If there was old fuel in there before, you will need to clean the carb the jets are clogged. Or worst case you could have water in the fuel tank but try to clean carb first. Good Luck...
Aug 22, 2011 | Garden
What's the best choke setting for starting a cold generator
Full choke to start, open choke partially immediately the engine starts to where the motor runs smoothly, continue opening as soon as you can while keeping the engine running smoothly. Be sure to open fully before leaving the unit, running it with the choke partially on can cause a rich fuel condition which tends to wash the oil off the cylinder walls and it also dilutes the oil with gasoline.
lp
Dec 26, 2010 | Coleman Powermate Portable Generator...
I own a HondaEU3000I Handi generator and have the following problem It starts on choke and will only run if I leave the choke on. What would be the problem
Chokes are used to draw gas through the center jet to run. If the choke is not working properly and it is not closing all the way the engine cannot draw gas through the center jet and will not crank.
Your problem is just the opposite of that
Yours is getting too much air so that is why it runs only with the choke closed
You will see two set screws with springs attached to them. one is for fuel adjustment and the other for air mixture. Try adjusting the two in all the way and back off 1/2 turn each then try and start it. If not firing look at this website below and click on the video to view how to clean out the jet
http://www.lawnmowerman.tv/Videos.asp
Aug 29, 2010 | Honda 3000 Watt Portable Generator
Generator will not run unless i use starting fluid.
You have a fuel problem. Fuel filter clogged? Carbuerator may need cleaning. Is there a hidden fuel shutoff valve? I have left mine closed... it is embarassing but it happens. I assume you put the choke on initially...
Apr 26, 2010 | Coleman Sport 1850 Generator
Briggs and stratton 11hp generator giving spark and new fuel pull start but just wont kick over any tips
how long has it been since it last ran? I had a similar problem with mine so I put clean fuel in it with a mixture of sea foam gas treatment. Used a shot of starting fluid to get started and let it run for an hour or so. Just started it again yesterday with no problems. The fuel in carburetor is most likely old and needs to be gotten out of. If you try this and get it started let it run in half choke position for a few minutes so old fuel will get out of caburetor. Good Luck
Feb 17, 2010 | Briggs & Stratton 11HP 6200W Es Generator
Wont start
when you added fuel to the old fuel in the tank, i advice you to take all the fuel out, clean the carb, blow out fuelrestrictors in it and fill up with new fuel and try again. also check the sparkplug, and check if it sparks. good luck.
Feb 13, 2010 | Coleman Powermate Powermate 5000W...
ONAN GENERATOR STARTS THEN ONLY RUNS WITH CHOKE ON
This sounds like a problem with fuel settings or dirt in the jet.
If you can find the carb adjustment screws, with it runing on full choke - screw it in fully untill it stalls, then back out to original position, then restart.
Take off choke and adjust setting untill it runs well when warm with choke fully out.
You can then try and make it run leaner without stalling.
Feb 07, 2010 | Watts Onan Portable Generator - 4000 ,...
Briggs & Stratton 135212/0129 - Homelite HL2500
the choke should be in the off position when running. YOU put the choke on to start it then when it starts u turn it off. If the choke is on the engine will die when reving
Aug 02, 2009 | Electrical Supplies
Electrical Supplies Logo
61 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
