Question about Craftsman Garden
Craftsman 6.50 pushmower
Lawnmower used to have more power. What can I do to increase RPM?
    Master:
  • 969 Answers
Replace spark plug. Replace air filter. Fill oil. 30w. Automatic governor no adjustments.
Posted on May 29, 2014
The belt keeps falling off my lawnmower. Can't seem to solve the problem. Had to replace it 3 x now
Hi Patty:
Sounds like you're having more grief than you need.
My Craftsman has been excellent and believe me, it gets it's share of hard use.
I'd suggest that you double check the routing, and make sure that the tension idler spring is set so that maximum pressure is applied.
It's also a technique that minimizes wear to engage the blade at medium low rpm and then increase the rpm.
Also, check all of the idler mounts to make sure the bolts are tight.
Cheers.
Jun 06, 2016 | Craftsman Garden
I have a huskee 21inch 140cc pushmower that won't turnover. It's like the shaft or piston isn't even connected. What do I need to do to fix it?
broken main rod will cause this pull plug and check and see if piston blows air out if dont broken rod then replace lawnmower or the engine other motor junk if it has a poped valve seat to fix it is also not worth it replace mower
Sep 27, 2014 | Garden
My craftsman lawnmower is leaking oil.
Check the drain plug, maybe it loose
Jun 19, 2014 | Craftsman Garden
Cut grass clippings does not get picked up by riding lawnmower
When using a bagger, you need correct blades on mower or Worn blades will cause the deck not to get the vacuum needed for the bagger to pickup.
Aug 22, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Fuel leak on craftsman pushmower with Honda engine.
Sounds like you tilted the unit enough to cause the float in the carb to open too much and therefore, the needle valve inside is stuck.
Remove the bowl and let it resit itself and then re install the bowl. If that doesn't work you may need to purchase a new kit for the carb to get the needle valve. If you find a small minut ring around the face of the needle valve replace it. That's why it's gonna leak. Good luck
Aug 02, 2009 | Garden
Riding lawnmower older Craftsman 143406012 12hp searches for rpm/
the needle valve on carb is out of adjustment it should be turned all the way in & out 1-1/2 turns to 2 turns try that & let me know if i can further help ya
Jun 23, 2009 | Craftsman Garden
Whenever I start my pushmower or riding lawnmower it revs high and then low and then high again. I don't know what to do.
You need to check your air filter. Usually your engine will attempt to keep itself running, and if your filter is plugged up, it will cause the engine to rev up and down rapidly. If you have a sponge type of filter, use gasoline to wash it. Soak it, and then gently wring it out and let it air dry. Re-install and your good to go. If its a paper filter, just replace. Good luck.22
Jun 14, 2009 | John Deere 22 In. Rear Tire Chains
Crafts lawnmower
Replace the needle and seat inside of the carb.
Jun 11, 2009 | Craftsman 8.50 Torque Rating Dual...
Won't stay running
The carbeurator needs to be cleaned and probably rebuilt. Start with a spray carb cleaner by putting 3 or 4 shots in the carb. Run it for a minute then let it sit for two hours and run it again.
May 07, 2009 | Garden
Garden Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
