Make sure that your software, that you view your pictures with, falls into the 'box format' of 640x480, 1024x768, 1280x1024, etc. Background pictures are typically streched to fit the wider screens. You can change that by right clicking on your desktop.. in XP it is the 2nd tab, on the right side, you can choose stretch or ? Some will give you black bars but no skewing. Then you can adjust your monitor's resolution downward to enlarge your pictures, or leave it at a higher resolution if you don't mind the borders.
-DellTech1
This sounds like a resolution problem. Change the resolution in Windows to something that is a little wider and your picture will probably go back to normal.
There also may be a "reset" button on the monitor. If so, push it.
Hello
This is an issue because most television programming is produced in a 4:3 aspect ratio. The minority of programming is high definition, which is produced in a 16:9 aspect ratio. Because televisions are made in either a standard (4:3) or widescreen (16:9) format, there is always a conflict with an image being stretched vertically or horizontally. In the case of widescreen televisions, the stretching is horizontal.
Picture Modes
Luckily, most if not all widescreen televisions have a picture mode that allows the user to toggle between a wide (16:9) and standard (4:3) mode. This means that a person can watch non-HD programming in the 4:3 picture mode, and then go to widescreen when watching HD programming. Some TVs have a picture mode that will automatically adjust to the correct aspect ratio. Other people will watch all programming in the wide picture mode, and learn to adjust to watching a stretched picture.
A stretched picture is when a 4:3 image is pulled on the sides to fill the entire screen. People and images end up looking fatter/wider and shorter.
So, what's the big deal?
Some people don't like a 4:3 picture stretched or distorted because it does reduce the overall visual and picture quality. Some people don't like the bars on the side of the screen when a widescreen is in a standard (4:3) picture mode because it looks different.
Solution
There is no fix-all solution for this issue, unless you own a TV that will automatically adjust to the intended aspect ratio. The stretching of the picture is a side-effect, the price we are paying for the better resolution that is digital and high definition. This is definitely something to consider when buying a television, but keep in mind that there is no right or wrong within this issue. It is just the way it is, and there is no way around it unless you buy a 4:3 aspect ratio television.
Hope these lines will clear the issue, if so do rate the solution
Hello
You can set the picture size by remote control itself.
You can vide 480i format programmes in three picture sizes. 4:3, 16:9, and ZOOM
You can change the picture size by pressing the PICTURE SIZE button on the remote control.
4:3 Picutre size
To fill the screen, the top and bottom edges are extedted more widely, although the center of the picture remains near the former ratio.
If receiving a 4:3 programme, the image size is displayed in its originally formatted proportion.
16:9 picure size
This image displays the size of standard 16:9 with black bars at the top and bottom.
If receiving a 4:3 programme, the image is displayed with black bars at the top and bottom and stretched wider.
NOTE: If a fixed bar remains on the screen for a long period of time, the image can become parmanantly engrained in the screen and cause subtle but permanent ghost images. Never leave your TV for long periods of time while it is displaying these images.
Zoom picture size [for 16:9 formats]
The entire picture is uniformly enlarged --it is stretched the same amount both wider and taller (retains its original proportion). The right and left edges of the picture may be hidden.
OK.
Hi, this sound like you have a (Resolution) problem. First; (right) click on an empty area of your Desktop Screen, next click Personalize; click Display Settingsfrom here you can adjust the resolution of your screen.You can repeat these steps until you are satisfied with the results. Thanks paul7of9
The reason why everything is too small is because you can now see your screen on a wider/bigger view of the graphics (it's like looking down from a tall building or looking down from an airplane. The difference is that looking at your screen is not that far. The Resolution is higher than before, graphics, pictures/images, video games, movies are all displayed fine. Having a high resolution screen is a GOOD THING! If you are not comfortable with this kind of high resolution then you can switch back to lower resolution but of course the consequences would be other softwares/programs may not work. It's just your personal perception.
You may have to match up the video card settings with the monitor settings to get the correct resolution setting. Try adjusting the resolution of the graphics card to match the setting for the monitor. If this does not work you can call, Envision customer support at this telephone number : 1-888-838-6388. They should be able to help you get the correct setting for you set-up. I hope this information helps you with your problem.
