Hotpoint wf240 flashing lights on the on button and the timer button but the machine dont wash
Dropped one of the plastic pieces holding stabiliser in place down the back of the machine - its a hotpoint - any ideas on how to get it out
Posted on Oct 23, 2007
  • Anonymous Oct 23, 2007
    dropped one of the plastic pieces holding stabiliser on back of machine down the back - machine is now vibrating - any ideas on how I would get it out  Thanks
SOURCE:
How do i fix a noisy spin cycle on hotpoint wf250
Hi.
A noisy spin cycle is usually because the bearings are rumbling and/or collapsed.
Unfortunately this is not a simple job and would require a service call and probably a workshop.
Good luck.
Nomess
Sep 28, 2014 | Hotpoint Repair Pcb / Module Wf240 Wf250...
Machine stopped mid cycle and green light flashing under green start button
Many modern washing machines display error codes if they detect a fault, but not all washing machines display a readable error code, some indicate an error by flashing, or lighting some of the lights.
Hotpoint, Indesit, Zanussi error codes
Hotpoint, Indesit washing machines and Zanussi washing machines are some common appliances that display coded error codes. On their more expensive models, they display readable error codes but basic models (without digital displays) use flashing lights to convey the error fault code.
If your washing machine malfunctions and you can see some of the lights flashing, or one or more option lights have lit up, then make a note of which lights are flashing and which option lights are lit. NOTE: the error code list engineers have only shows the option lights by number and not by name. Therefore you need to report the lights as LED 1 and 3, or 2 and 4 etc. and NOT "delay timer" and "extra rinse". Count the lights from the left (or from the top if in a column) and report as "led 1 and 3" etc.
No Option lights?
With basic washing machines that have no option indicator lights, count the number of flashes. For example, the door locked indicator may flash 7 times, pause, and flash another 7 times in a constant cycle which would indicate error code 7.
This information is vital, and needs mentioning when reporting a fault.
Jan 18, 2011 | Zanussi FJS1225W Front Load Washer
Door will not open door light just flashing on and off
washer not spining mini load button flashing on/of buton flashing
Apr 27, 2010 | Hotpoint Aquarius WD640 Front Load...
Hotpoint
Check level of machine as may be leaning slightly forward. Use front feet to adjust to level or slightly lifted at the front. This will compensate for any slight buckle in the plastics on the drawer compartment.
Feb 07, 2010 | Hotpoint Aquarius WF000 Front Load Washer
We've scrubbed off the wash info on the front of the machine!
In your main browser bar, type in-----------HOTPOINT.CO.UK
In the drop down menu, click on----------After sales.
Enter the model number of your washer in the box, and download the instructions.
Please rate my solution.
Thanks.
Nov 10, 2009 | Hotpoint WF430 Front Load Washer
Hotpoint aquarius wd440. Flashing lights
press and hold on off button till the display panel lights up.Then press and hold the on/off button and the start /cancel button together.You will now reset the washing machine settings.And just pick your cycle again
Oct 04, 2009 | Hotpoint Aquarius WD63 Front Load...
Wont emtry
can you hear the motor spinning.
May 12, 2009 | Hotpoint Aquarius WF220 Front Load Washer
LOOSE HEATING ELEMENT CAUSED BAD LEAK
dont risk it new heater only 20 quid
May 01, 2009 | Washing Machines
Error code on my Hotpoint Aquarius WF240
my hotpoint Aquarius wf340 when switch on 5 secs later on/off button flashing along with mini load lights. could u tell me the error codes for this machine?
Apr 04, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Washing Machines Logo
565 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
