Question about HP Hewlett Packard 4755a Ekg
Anyone know what to do about Error 51?????
Pagewriter II CArdiograph gives me this error when it tries to feed paper
  • 3422 Answers
SOURCE: hp psc 1315 paper jam
. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Posted on Jun 18, 2008
Ajkill
  • 2035 Answers
SOURCE: paper feed problems hp PSC 1510
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Posted on Oct 17, 2008
rey17
  • 66 Answers
SOURCE: 13.20.00 paper jam error
hi,
i think you having problem on your pickup rollers maybe it's worn out that's why you having that message always...try to replace the 2pcs, pickup roller to fix your problem..
i hope it would help you...
Posted on Oct 29, 2008
  • 4 Answers
SOURCE: HP 1280 Error message
OK, to make this clearer, I had the same problem on my HP C7180. It seems to be rampant throughout their Multifunction printers.
My Fix, combining several others:
1. Go to Printers and Faxes on your Start Menu. In the Printers window, select Server Properties from the File menu. Use the Forms tab of the Print Server Properties dialog box to view printer forms. You may also see lots of forms that you wish your printer could see, but don't worry, it'll see the one you create now. And be sure when you create your form that you use the narrower dimension for the width and the longer dimension for the height. Usually for envelopes you will print in landscape mode.
2. Select the Create A New Form check box.
3. Enter a new name for the Form in the Form Description For field.
4. Use the fields in the Measurements area to set the paper size and margins. *Use the narrower dimension for the width and the longer dimension for the height*.
5. Choose the Save Form button to save the form. The Save Form button only gets pick-able when you type in a different name than what's there already.
Now go to your document program, such as Word. Make sure the window for the document you want to print is the active window. Select File/Page Setup..., Paper Size Tab, and there select the form you just created from the dropdown list
Still in your document program, select File/Print... then Properties. Select the Features tab, which may be differently named. Under Resizing Options/Size dropdown, select More... and there you'll find your newly created form down at the bottom, under Custom. Pick it.
If you're printing envelopes or other things where the way you view it it's wider side-to-side than it is tall, be sure and select "landscape" in both "page setup..." on your document program and in File/Print.../Properties/Features?Basic Options.
When I did all this methodically, I was able to print my Christmas envelopes. Yay!
Posted on Dec 18, 2008
SOURCE: HP COLOR LASREJET 3500 41.3 ERROR
hi ray, it's chris. i called your cell phone, but figured you might see this. replace the registration clutch. after some research, this seems to be the solution given that should solve the issue in that printer, and it's an independant part from the paper pickup assembly...
RK2-0247-000CN
chris
Posted on Jun 11, 2009
My scx-4725fn printer doesn't print. and gives the error message what should i do?
what is the error message that it gives you ? the most common on these printers is the paper feed error the machine will not pick up paper. the feed tire is right below the toner system and the feed tire gets dirty and wont feed paper. if this is the case the feed tire needs to be cleaned. you should take it to a dealer for this cleaning because it is hard to get to the whole tire with out knowing what to do.
Feb 02, 2015 | Samsung SCX-4725FN All-In-One Laser...
Brother 420
error 51 = The purge cam switch does not come ON or OFF even after the purge cam has been driven by the specified number of pulses.
Fix is
Switching arm assembly not engaged correctly If the switching arm does not move smoothly, clean it.
Ink cartridge/purge switch harness not connected correctly
Correct the connection.
Purge cam switch broken Replace the purge cam switch.
Gear(s) on the maintenance unit broken Replace the maintenance unit.
Paper feed motor broken Replace the paper feed motor.
Main PCB defective. Replace the main PCB.
Cleaning of these print heads rarely if ever is successfull, they are electronic devices unlike other brands of printers
Dec 04, 2007 | Brother MFC 420CN All-In-One InkJet...
H5-01 error on sharp AR-M450N
Sharp AR-450 H5 01 Papersensordefective in the fusing unit 02 Fusing unit temperature error C1 00 MC unit malfunction C2 00 TC unit malfunction E7 00 Image Processing Unit error 01 Memory back-up battery dead 02 Laser unit problem 03 HDD defective 10 black level calibration error 11 white level calibration error 13 CCD calibration error 90 Image Processing Unit error F1 00 Lost communication with the Sorter 01 Sorter registration problem 02 Paper transport motor overloaded in sorter 04 Bin position error in sorter 05 Bin position error in sorter 06 Shift sort motor overloaded 08 Stapler position error 08 Stapler overloaded 11 Sorter problems 14 Second shift tray jammed 15 Sorter drive problems 50 Sorter not installed properly 80 No powerin sorter F2 00 ID pattern reading error 02 Toner add mechanism malfunction 31 ID pattern reading error 32 ID pattern reading error 39 Drum thermistor error F3 12 Paper does not lift in the tray 22 Paper does not lift in the tray F9 00 Printer board problems 01 Printer board problems 02 Printer board problems 03 Network card error 04 Firmware error 05 Not enough memory 10 Printer board problems 90 Printer board problems H2 00 Fusing unit temperature error 01 Fusing unit temperature error H3 00 Overheated fusing unit 01 Overheated fusing unit H4 00 The fusing unit doesn't heat up 01 The fusing unit doesn't heat up H5 01 Papersensordefective in the fusing unit 02 Fusing unit temperature error L1 00 Scanner position error L3 00 Scanner position error L4 01 Main motor drive overloaded L6 10 Polygon mirror motor not up to speed L8 01 Zero cross signal error 02 Zero cross signal error U2 00 EPROM error 11 EPROM error U4 02 Duplex not working properly 03 Duplex problems U5 00 Communication with the ADF is lost 01 Registration sensor problem in ADF 02 Exit sensor error in ADF 03 Timing sensor problems in ADF 11 Paper feed drive overloaded in ADF U6 01 Paper lift problem in 1'st optional tray 02 Paper lift problem in 2'nd optional tray 08 Paper feed unit without power 10 PFU paper transport motor overloaded 22 Paper feed unit without power 50 Paper feed unit not installed properly 51 LCT not installed properly U7 00 Main board malfunction U9 00 Op panel problem 90 Op panel problem EE EU Low toner density in the developer EE EL High toner density in the developer FA 01 Memory back-up battery dead PC Key counter not installed
Apr 01, 2010 | Sharp AR-M450N Copier
Brother MFC-465CN printer Error code 51 unable to print
Usually this is caused by a foreign object or debris under the printhead path, or under where the printhead "parks."
Unplug the machine. Open the cover. Check the printhead path for little bits of paper, push pins, paperclips, staples etc. Note the location of the printhead.
If the printhead is at the far left, gently slide it towards the center (do not force it). Look carefully under where the printhead was stopped for debris. Use a flashlight if necessary.
Close the cover. Plug in the unit. Try again.
Jan 20, 2010 | Brother MFC-465CN InkJet Printer
Phillips pagewriter Trim1 not working
I have a proplem. When i press auto button then screen display error code 0204. thanks
Aug 28, 2009 | Philips Medical
My printer thinks it is out of paper when it
please try to set it to manual feed
with manual paper feed it wont search for a paper and wont give an error
Thanx and i hope this helps
PLease rate this solution
Jul 16, 2009 | Epson Stylus Color 777i InkJet Printer
I'm having trouble with the Javelin J330i printer. When trying to print cards it doesn't pull them through correctly and then gives an error that the ribbon is broken. I have tried resetting the printer,...
check the feed tires ,the ones that feed the paper/cards into the printer. they maybe slick with paper dust. I recommend taking a cotton dish cloth or rag with some 409 cleaner on it the the feed tires clean all the paper dust off the tires let dry then try to feed card again. sound like the sensor is covered with paper dust, and is giving a false error.
Jul 09, 2009 | Javelin Systems Inc Javelin Viper PC...
HP LJ II P plus
The laser PCA is bad.
I removed it and the printer functioned.
I thank you really after all.
Jul 25, 2008 | HP LaserJet IIp plus Printer
Sharp AR-5132 copier won't copy, no error message
okay start by loading a piece of paper on the glass and choosing maual feed and placing a sheet of paper in the manual feed tray and press the start key and see what happens. also on some of the sharp copiers there has been a problem with the print button itself, so i don't know if that may be the case.
Thank You,
Mikey
ps let me know how you make out.
Apr 06, 2008 | Office Equipment & Supplies
HP Hewlett Packard 4755a Ekg Logo
21 people viewed this question
Top HP Health & Beauty Experts
David Fischer
Martyn01202
Martyn01202
Are you a HP Health and Beauty Expert? Answer questions, earn points and help others
