Question about Philips Magnavox 51MP392H Rear Projection Television
Vertical hold I have an older model Magnavox TV. With dark backgrounds, the vertical hold malfunctions. Any suggestions?
    Champion:
  • 247 Answers
Replace the V-HOLD control its worn out
Posted on Jul 14, 2013
Thin vertical lines on plasma tv
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to both Plasma display & LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 21, 2015 | Samsung Televison & Video
Vertical line on screen
Hi, This is a problem that's far too common among flat-panel and projection LCD TV's?and it's generally known as "vertical banding." If the lines are there all the time or intermittent but in the same location it is an indication of a bad panel. The panel driver can also be the cause of this symptom. Samsung panels have had issues with the connector that carries the LVDS signals to the panel itself, this is not serious and can be resolved and little cost. These faint vertical bars (often most apparent when the screen is totally dark or displaying a solid background, like the sky) are defects that occur during the manufacturing process, and while the worst offenders are typically screened out, many more make it to store shelves. Since you've pinpointed the banding and it's driving you nuts,also its under warranty, call the manufacturer and demand a replacement; in most cases, they'll capitulate and send you a new set, although you'll probably have to go to the trouble of packing and shipping back your defective TV (make sure the manufacturer covers your shipping costs). Regards sreejith
Jul 30, 2007 | Philips Magnavox 42MF521D/37 Television
When turned on there is a dark background with vertical and horizontal stripes
Sounds like you might have corrupted your programming. See if you can do an update online by going to the EasyShare website and searching for updates for your model. You maybe able to download and reinstall the software.
Dec 19, 2014 | Kodak EasyShare Z612 Digital Camera
My magnavox tv has sound but only a white line
You have a bad ground or even a bad vertical IC. Have a tv tech pull the board out and inspect. It could be bad grounds and resoldering them may restore the picture. Also remember to check all capacitors in the immediate area of this IC, bad caps will heat up the vertical IC, and cause bad grounds. Replace the caps and Vertical IC as needed. Should be a standard fix in this case. Thanks for asking!
Apr 25, 2010 | Televison & Video
Hi Lost instructions. Would like to obtain how to program my Philips Magnavox remote. Don't know if the #2 MP#20C103-1 or the 1-0010 are the model #s. Thanks
Turn TV on, press and hold CODE SEARCH button until light comes on, press TV, the light will blink and remain on, enter the code, the light will go off, press POWER untill TV goes off....hope this was helpful...
Apr 23, 2010 | Philips Magnavox Learning Universal Remote
Troubleshooting magnavox television model 20mt1331-17
I have a model 20tm1331-17 magnavox tv and when i go to turn it on it will turn itself back off. Any suggestions as to the problem?
Sep 27, 2009 | AOMNI Corporation Magnavox 20MF500T/17 20...
I have a magnavox model 35R502-00AA help
you tv have a problem of vertical ic or cacacitor or resistor right around vertical section. that is make tv shut down in alot of magnavox tv. good luck!
Jul 27, 2009 | Televison & Video
Horizontal white lines across top of TV screen
Vertical hold circuit is failing.
Check capicitor in vertical hold circuit. You should have solid knowledge of electronics repair before attemping repair. TV's can emmit harmful radiation, and produce voltages up to or in excess of 30kV.
Oct 07, 2008 | Televison & Video
Mitsubishi vs 50707 50 inch projection tv problem
on the signal board replace the caps by the 5/9 volt regulators. c2p04 is the main culprit. 6 caps in total can be changed. I believe c2p05 also.
Dec 15, 2007 | Mitsubishi VS-50707 50" Rear Projection...
Tv has an advertisement that wont go off
Press the up and down volume buttons on the TV at the same time. This will turn off demo mode.
Aug 29, 2007 | Philips Magnavox 27MS343S 27" TV
Philips Magnavox 51MP392H Rear Projection Television Logo
20 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
