Question about Dishwashers
How do i reset e4 on kelvinator kd14ss - Dishwashers
4 Suggested Answers
SOURCE: Kelvinator kd14ss
This is a common problem with this machine. Per the manual E4 indicates that the machine is overloaded but this is incorrect. The machines has actually become water logged due to a design fault whereby some water is allowed to pool at the bottom of the machine rather being efficiently drained. Note that the area where the water pools is not rust resistant. To temporarily overcome the E4 error, tilt your machine backwards and the excess water will drain out the back corners. Remember to put some towels down to avoid a big mop up operation afterwards. I live in a coastal area so drain the machine this way once a month and then open up the back of the machine (don't do this if still under warrantee) to dry it out completely to minimise the rust.
Posted on Oct 19, 2009
SOURCE: Kelvinator Dish Washer Model KD14SS
mine is doing the same what can it be
Posted on Mar 05, 2011
caroldon
  • 17129 Answers
SOURCE: Kelivinator KD14SS - I'm getting
The error code seen is due to the system tipping or hanging due to a fault of the input into the processor. So remove power and press down all pads and when it is plugged keep holding the start button. If this wont reset check with the manual to confirm.
Now it is best to identify the working so that we come closer to the fault. It is possible that the machine does not start off the cycle because there are errors or back feedback from the inputs. For the program to start up the main program controller must initiate the INLET valve to open up and allow water to flow into. If this does not happen then the voltage at the inlet valve must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor .
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the drain valve/pump activated so as to drain off all the water .
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.espares.co.uk/advice/dishwashers/a/3
For spares click On:
http://www.espares.co.uk/search/dishwashers/p/1083
Posted on Jul 20, 2011
Where can I find the reset swich on a kelvinator refrigerator
I don't know of a reset switch. Check to see if the condenser coils underneath or in back are free from dust or blocked. Also is the door closing real tight. Don't know how old your fridge is. If it is real old It may not be worth repairing.
Jun 09, 2015 | Kelvinator Refrigerators
E4 error showing on a kelvinator kd14ss
good day
my dishwasher give e3 and e4. what is the problem and how can we solve the problem.
Nov 04, 2012 | Kelvinator Dishwashers
Error E4
E4= paper jam. Check all your feed areas and make sure they are clear. Then reset your printer and begin you print again. If all areas are clear and your still getting an E4 reading you may have damaged a sensor clearing a previous paper jam. If a reset wont clear your error then your printer may need to be repaired. It would probably be cheaper to simply replace your old printer for a new one. Hope this helps Shannon
Mar 07, 2012 | Canon PIXMA MP150 All-In-One InkJet...
Kelivinator KD14SS - I'm getting error E4, what does this mean? What do I need to do?
Jul 20, 2011 | Kelvinator Dishwashers
We got this panasonic fp-7718 for free and have tried to get it to copie but the e4 code keeps and i have no idea how to reset this code or any of the other codes.
There will be more to it than just E4..........it will say E4-01, E4-10,11, OR 12.
If its e4-01...that means the machine is not warming up and may have a problem with the Fuser unit.
If its E4-10,11 or 12 it relates to a problem with a Fan motor.
Thats the best I can do given the information you have provided.
Feb 26, 2011 | Office Equipment & Supplies
Error code Df and e4
E4 Outdoor activation of low pressure switch/ less suction pressure.
Check back pressure, which should be 60 PSI when ambient temp 98 degree.If not Short of gas- find leak and arrest. And do gas charging. Even due to indoor coil dust blocked also e4 arise. Clean the coil and reset it.
Nov 25, 2010 | Napoleon NHPS12 Air Conditioner
Kelvinator kd14ss
May 26, 2008 | Kelvinator 24 in. MDB222RB Built-in...
E4 error code
Exact same problem. E4, sent uniden an email thru their website though I doubt Ill hear any response. Very disappointed as the 9485 was working great until all of a sudden E4 showed up.
Nov 29, 2007 | Uniden TRU9485 Cordless Phone
Dishwashers Logo
29 people viewed this question
Top Dishwashers Experts
Owen Barnes
