Question about NetGear WN111 (DHWN111100NAS) Pre-802.11n Wireless Adapter
I have a netgear router wich is not vissable to otherdevices how do i make it vissable my father set it up but he unfortunatly has past away
    Problem Solver:
  • 12 Answers
Use the reset button to restore to factory defaults then log in using a web browser 192.168.1.1 in the address bar. Username and password admin admin or google defaults for that router
Posted on Jul 13, 2013
I have just changed from a Netgear DG834G V4 to a Netgear N150 (Supplied by Orange) Router and the signal is now virtually non existant in parts of the house (upstairs and further away downstairs rooms)...
Netgears products are terrible with non support what so ever. I'm sure you had change your router already, but if your ISP could provide you with a different brand, the problem will disappear.
Mar 30, 2015 | NetGear DG834G Router
I have lost the password and need to reset password
Unfortunatly there is no way of recovering your router password however you can always reset your router and set to default settings to do so simply press and hold reset button for 15 seconds or until router lights flash this will make your router unsecure. Depending on what type of router you have you can go to the direct website of the manufactor for example www.netgear.com to secure router once again.
www.linksys.com
Dec 13, 2010 | Nokia Computers & Internet
Lost password, not written down anywhere
Unfortunatly there is no way of recovering the password however you could always reset your router to default settings to do that there is a reset button in the back of the router. Here is a link to show you how to resecure the router.
http://www.columbia.edu/acis/networks/aptnet/netgear/index.html
Oct 02, 2010 | NetGear WGR614 Router
My father in lavv has got a laptop and vvants to use my router but i have lost my vvep key on a piece of paper hovv do i retrieve it my router is netgear
1. Log into your router by accessing either:
http://192.168.1.1/or http://192.168.0.1/
only one of the above will work.
2. Enter your user name and password that you set for the router. If you did not change it, use the default:
Username: admin
Password: password
3. Click on the Wireless Settings link.
4. Your WEP key will be in the wireless security settings. Key1 is the key you are looking for.
May 01, 2010 | NetGear WGR614 Wireless Router
How to turn Netgear WNR834B into a repeater
I don't think the Netgear WNR834B is capable of acting as a repeater but there is another solution. I would decide where I want to put the Netgear WNR834B for best coverage and then do the following. Go buy the Powerline Ethernet Adapters of your choice and put one at the main connection and plug a ethernet cable into a open switch port. Second go to where the repeater is to be located and plug the 2nd Powerline Ethernet Adapters in and connect to the Netgear WNR834B LAN port. Be sure to turn off DHCP on the Netgear WNR834B and assign a IP address that is not used. I normally use the highest address in the last octet so that I can remember for management. xxx.xxx.xxx.254. I hope this helps you.
Apr 28, 2010 | NetGear RangeMax NEXT WNR834B Wireless...
Running install disc, says does not support operating system
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Mar 03, 2010 | NetGear WGR614 Wireless Router
I had to move and I took my NetGear WGR614v9 Wireless router with me. How do I hook it back up? I have DSL, which is what I had at my prior residences.
Are you trying to set up the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
Then you need to connect the computer to the router and the modem to the router.
Click Here for step by step by instructions
Feb 16, 2010 | NetGear WGR614 Wireless Router
My netgear rangemax does not emit a steady wifi signal. if i plug in my computer, the internet is working fine. all of the lights are on on the router. The wifi network shows up for a few minutes, goes...
Intermittent wireless connection can be caused by different factors, such as:
1. Wireless interference within the network. For best results, place your router:
- near the center of the area in which your computers will operate.
- in an elevated location such as a high shelf where the wirelessly connected computers have line-of-sight access (even if through walls).
- away from sources of interference, such as microwaves, and 2.4 GHz cordless phones.
- away from large metal surfaces.
2. Wireless settings on the router are still set to default. This may cause conflict with other Netgear routers within your network range.
- change the router's SSID or wireless network name.
- change the router's channel.
- enable wireless security on the router.
3. If the wireless connection is still unstable after performing the steps above, it is possible that the firmware is corrupted. Upgrade the router's firmware.
Nov 27, 2009 | NetGear RangeMax WPN824 Router
My netgear router will not connect through wireless side only
Sorry I should have clicked on Full View befroe I submitted a comment.
Try resetting the Netgear back to the default settings. There is a reset button at the back of the Netgear rpress it untill the LEDs flash then release the button and then configure the router again.
Open a browser and enter this URL http://192.168.0.1
The login name is admin and PW is password.
Change the default password.
In the wireless settings change the SSID and turn off SSID broadcast.
Setup encryption use WAP2 or WAP
For added security enable MAC address filtering.
Then configure the computer's wireless card with the router's SSID and encryption settings.
Also check the wireless channels of the access points/routers in your area and set your router to an unused channel (or one that has the weakest signal strength) so you get less interference with your router.
Also move your wireless router away from walls and if possible raise it higher to improve the signal to your computers.
Sep 20, 2009 | NetGear WGR614 Wireless Router
NetGear WN111 (DHWN111100NAS) Pre-802.11n Wireless Adapter Logo
23 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
