Question about Radio Communications
Marine radio 550 will transmit but will not receive
  • Radio Commun... Master
  • 16,010 Answers
What is the make
Posted on Jul 21, 2013
I can't transmit on my rs82 radio although the station can receive
Simrad RS82. Ok, can you switch to 1 watt and see if it transmits on low power? If it does, check all wiring and your power source (battery or power supply) for enough voltage. Marine radios often get corrosion on connections. Later, check your external antenna and connectors. Of course, you can never transmit on the pre programmed weather channels.
Oct 01, 2015 | Radio Communications
Transmitting and Receiving fault
Ray marine has an extensive library on-line. I have usually been able to find what I need there. May take some digging though.
May 10, 2014 | Raymarine Ray218 Vhf Radio
Ic m505 not receiving
turn the squelch down? the RF gain down too
do you have an attenuator turned on ?
Apr 01, 2014 | Icom IC-M505 - VHF/DSC Marine Transciever
My radio will not transmitt but it receives just fine
Most problems with radios that receive but do not transmit are antenna or antenna wire/connector issues. It's easy to receive with a marginal antenna but transmitting requires a good working antenna. If you have a SWR meter or can get your hands on one, install it in line with the antenna and test for reflected power. Of course, make sure your TX light comes on when you depress the mic switch. If not, switch mic and try again.
Hope this is helpful! Reply if u can.
Oct 06, 2012 | Uniden Solara DSC VHF Marine Radio
My radio transmits fine. Until recently it received fine. Now it transmits but it does not receive. I've played with the squelch and volume. No luck. Can you advise.
Your finals are fried. Take it to a shop and they will fix the finals. Before you do that be sure to put in an extension speaker just to be sure. Most CB shops are inexpensive.
Aug 29, 2011 | Uniden Solara DSC VHF Marine Radio
Need a service manual need to modify a MR f55 radio to transmit on 161.600 mhz can you help?
You want to be able to transmit to the Coast Station on this frequency I assume. The Coast Guard monitors channel 16 at all times. This would be the primary channel in the United States. Your radio is VHF Marine Radio and has a built in frequency range of 156.050 MHz to 163.275 MHz. There is no need for a modification. This is a duplex frequency. What that means is you will transmit on one frequency and receive on another, while on channel 20. You will not need to transmit on 161.600. Turn your radio to channel 20. When you transmit, you will transmit on 157.000. And when the Port responds to you your radio will automatically receive their signal on 161.600. So if you are trying to figure out how to communicate with the port authorities then for that frequency turn your radio to channel 20 and you will be able to communicate with them.
Regards, Tony
Mar 31, 2011 | Cobra MR- F55 Base CB Radio
My uniden ltd 715 receives from my handheld but when I transmit to handheld it just buzzes.
Just to clarify something, you say that your hand-held VHF can receive a clear transmission from the Uniden, now which of the radios are buzzing, the Uniden or the HH?. If it's the hand-held buzzing try transmitting on the low watt on the Uniden, get some distance from the radio, because if the hand-held are to close to the on the Uniden on high watt you will get a buzzing, the signal are overpowering the receiver of the hand-held, try getting the minimum of 30 feet away. Good luck.
Mar 24, 2011 | Uniden Solara DSC VHF Marine Radio
Cobra marine band radio will not transmit more than a quarter mile is it blown?
Before changing out the radio try the radio on a ANTENNA RADIO TESTER or try it on a different antenna. Good luck.
Jan 05, 2011 | Cobra Marine Vhf Radio
Weak Marine Radio transmission.
Your radio set, it just could be not enough power to get out.
Nov 21, 2009 | GPS
Radio Communications Logo
15 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
