Question about Honda Garden
Where's the crankshaft timing mark on honda fg 110
Went to start tiller and it wouldn't start. after checking the usual spark and fuel I noticed the pull start seemed easier than normal. I removed the valve cover and the exhaust valve sticking open. found light rust binding the rocker shaft. got that cleaned up so it moves freely again. i could find TDC with a dail indicator, but I would really like to know where the TDC mark is on the crank/flywheel. anyone know where they are?
jmgldsmth
  • 2005 Answers
SOURCE: Honda fg 1oo won't start
It can be fixed take it to a small engine (lawnmower) shop
Posted on May 20, 2009
  • 16 Answers
SOURCE: I have a Honda F501 tiller. It quiy on me so I
Sounds like somthing may have been disturbed when removing the flywheel if the engine revved fine prior to dying on you.
Theres a guy on ebay selling workshop manuals for Honda, see if he has an F501 manual? Heres a link to one of them I got recently
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=110441313372&ssPageName=ADME:L:EOISSA:GB:1123
Posted on Oct 13, 2009
MOTORWIZJ
  • 1383 Answers
SOURCE: 4' king kutter makes grinding noise at times
USE SAY A BROOM STICK AND ON THE OUTSIDE ON THE DECK YOU CAN USE IT LIKE A STETHOSCOPE AND PUT IT TO YOUR EAR AND LISTEN TO DIFFERENT SPOTS ON THE DECK TO HELP YOU ZERO IN ON THE CULPRIT .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
Posted on May 26, 2010
SOURCE: where is the timing mark on the crankshaft on a
You have to pull the flywheel off of the crankshaft to see the woodruff key. The key should point up towards the camshaft. there are two marks on the plastic camshaft gear that also must align with the two marks on the housing.
Posted on Aug 05, 2010
  • 306 Answers
SOURCE: 2007 MTD Tiller with a 5hp Honda engine
I got to think there may be a loose connection in the ignition circuit. That is where I would be looking.
Posted on May 22, 2012
Honda FG garden tiller 110, stoped running, took it apart, the timing belt loose, what do I need to fix it? Or is it worth fixing?
I'm not aware of them having a timing belt. Do you mean the drive belt? if so, it is supposed to be loose. in the disengaged position. and tight in the engaged position. and to answer your question it is almost always worth fixing. unless you have a lot of money and want a new one. I've seen tillers 30 and 40 years old work just as good as a new one.
Jun 22, 2016 | Honda Garden
model was launched 1998
replace the timing belt sounds logical
take photos of how the crank and valve cam cogs line up before replacing the timing belt
Honda FG110 ROTOTILLER USA VIN FAAA 1000001 TO FAAA 1199999 Parts Diagrams
How to test the starter system on a honda 40 hp 2003 tiller outboard which won' t start
while cranking test for spark if not spark check for kill switch being in place. if spark is there then check for fuel . if no spark then prossbily power pack has failed
Dec 08, 2014 | Honda Garden
Cannot get full throttle out of honda fg100 tiller engine
I have the same FG 100 tiller with the same problem. I did replace the carb with a brand new one and still can not get full RPM. It does try to go to full RPM, but drops back. I even checked the transmission and clutches very thing works very well.
Jun 26, 2010 | Honda 25cc 4-cycle Mini Tiller
I have a Honda mini tiller FG-100. Haven't used
You need to check your engine oil on a very level surface.
Its all too easy to over fill these engines with oil and the results can spell disaster if not rectified. On a level surface, with the machine level (not tipped forward) the oil should just be reaching the top of the threads for the bung. Any more than that and you have to much in.
This symptom can also be caused of incorrect storage .ie the machine being left on its side allowing oil to fill the exhaust box.
Check your oil level first then run the machine until the left over oil in the exhaust box has been burnt off. I would then advise either replacing the spark plug with a new one or cleaning your existing one and checking / replacing your air filter
Oct 10, 2009 | Honda 25cc 4-cycle Mini Tiller
FG110 Mini-Tiller stalls once it is warmed up. After about 15 minutes of use it when stall and restart but won't run under load. Once this happens it needs to be inactive for about a month before you...
The problem is that the fuel cap does not allow enough air to get into the fuel tank as the fuel is used. A vacuum is created and it stalls the engine. If you look at the cap from the inside you will see two small slots on each side of the black center piece. I took this apart and opened up those slots a little bit with a hack saw blade. This allows enough air to get into the tank to prevent a vacuum and the resulting engine stall.
Apr 06, 2009 | PDP Systems Dethatcher Attachment for...
Dethatcher pins on my accessory for the honda FG 110 are broken
MANTIS TILLERS USE THE SAME ATTACHMENT CALL THEM @1 (215)355-9700
Jan 29, 2009 | PDP Systems Dethatcher Attachment for...
Fg 110 mini tiller by honda
I have had the same problem.
The first time the solution was to replace the rubber membrane underneath the primer bulb. Take off the bulb, then remove the plastic part underneath the bulb. There is a rubber membrane underneath that. The ethanol in the gasoline tends to deteriorate the membrane. The honda dealers sell them for about 14 dollars.
The second time the problem was caused by the gas cap, not properly venting. In this case the engine would start and run, but when I gave it full throttle, it would quit.
It got so bad that it wouldn't even run. I noticed when I loosened the gas cap it ran great.
So I took off the cap, removed the inner parts, and got a diaper in and pushed it though the holes in the plastic part underneath the cap, and through the rubber plug in the center. I did this a few times and check with my mouth to see if I could pull some air through the cap. When it breathed satisfactorily, I put the cap back on the gas tank and it ran great. Now it runs better than new.
Jan 13, 2009 | Honda 25cc 4-cycle Mini Tiller
Garden Logo
251 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
