Question about Dryers
Error code e62 on kenmore gas dryer
Kenmore gas dryer model 84152 gives error code 62. It will run and dry but constantly beeps. After approximately one minute it shuts off.
  • 146 Answers
SOURCE: kenmore dryer 417.84072300
Check you circuit breaker. Even if it doesn't look tripped reset it anyhow. This is a power interrupt code.
Posted on Dec 22, 2007
  • 156 Answers
SOURCE: Dryer runs & heats but shuts off after 3-10 minutes
the motor overload can caouse that problem in that case new motor is needed if the dryer turn right back on after it turns off the even heat control board in panel bad if it humms are no noise after turn off and you have to let cool down the motor is the problem
Posted on Feb 28, 2008
jyackle5
  • 8197 Answers
SOURCE: I constantly got E1 Error code on my Kenmore Elite H3 GAS dryer
E1 error code indicates an open thermistor or open thermistor circuit. A thermistor is a component that relays the temperature in the dryer to the control board. If the thermistor has failed, Error code E1 will be displayed.
You need to call a repair person to fix it.
Posted on Dec 18, 2008
jumptrout51
  • 3361 Answers
SOURCE: kenmore gas dryer model 97284100
The door latch is about $5. Replace it.
Any appliance parts store has them.
Posted on Mar 27, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: Blinking error codes?
Unplug the machine for 30 minutes , plug it back it, start it for 1 minute, unplug it again for 5 minutes then plug back it and it should work. If not then write back with the error codes so further diagnostics can be done
Posted on Apr 08, 2009
Kenmore Elite HE4 Gas Dryer Shuts off prematurely in the Auto Dry cycle and the Timed dry cycle
Gas Dryer no heat: or shuts down soon after heating CHECK:
Thermal Fuse
If the air flow in the dryer is restricted, the temperature in the heating chamber can get hot enough to blow the thermal fuse. If the fuse blows, it cuts power to the coils that control the gas valve. The fuse is usually mounted to the exhaust duct just inside the back panel. You can check its continuity with an ohmmeter. If, after disconnecting the fuse, you get any reading other than 0 when you touch the leads of the meter to its terminals, it has blown. There's no way to restore it -- you'll have to install a replacement.
Igniter and Gas Valve Coils
TEST with a multi meter: The igniter is an electric conductor that works like the element in an electric heater, glowing hot enough to ignite gas when you turn on the dryer. This conductor can burn out, and when it does, it may glow, but it won't get hot enough to ignite the gas. At times it may give a reading of continuity yet fail mechanically and not get hot enough to ignite flame though it gets hot and glows and even may show Ohms or continuity ( close circuit) ?
Occasionally, the Gas safety valve and the electric coils that control the gas valve are defective -- they can wear out when the dryer gets old. When this happens, the igniter glows, but gas never enters the heating chamber or does not stay consistant.
Performing a continuity test on either part will help you determine whether or not you need to replace it. But the coils should also be tested for amount of resistance as well as Ohms. As they may be showing ohms yet not putting out enough resistance to keep proper gas pressure flowing. Most coils should show at least 1300 ohms ( GIVE OR TAKE 150 OHMS). Anything significantly less Thus u get an ignition but then it soon goes back out. The flame does not stay lit.
Air Flow and Heat
The motor that drives the tumbler also drives a fan that circulates air through the heating chamber and the tumbler and expels it through the vent. If the air can't circulate, perhaps because of lint blockage, the heating chamber overheats, which prompts the cycling thermostat to turn off the gas. The thermostat resets when the chamber cools, but the chamber heats up quickly and the thermostat again shuts off the gas. The result is that the temperature in the tumbler doesn't stay hot, and your clothes take longer to dry, if they get dry at all.
Warning
There's a big difference between a dryer that doesn't heat up at all and one that just doesn't get hot enough to dry your clothes. In the first instance, the problem is usually a defective part, and things should be back to normal after you replace it. In the second instance, the problem is caused by restricted air flow, and you need to clear the lint filter and vents and take steps to prevent lint build-up. If you don't, you'll use more energy for drying than you need and the dryer may continue to malfunction. Worse, you may have a dryer fire.
Jul 19, 2014 | Kenmore Dryers
Frigidaire FEQB4000FS1 keeps beeping; error code seems to be 62 but cannot find what the 62 leads to :(
Good Afternoon Jennie, I am happy to assist you!
Typically, an E62 error code is an indication of a short circuit. Let's try resetting the dryer by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait approximately ten minutes and then turn the dryer on. If resetting the power does not correct the issue, your appliance could be experiencing a potential heater relay failure, control board issue or wiring problem. I would suggest contacting an experienced service technician to determine the precise cause.
Best regards!
Oct 19, 2013 | Frigidaire Electric Dryer
Kenmore model 84152/94152, 8 years old, started out with3 beeps over and over while running just fine otherwise. Now, 12 hours later, stupid thing started, while not running as in not in use, beeping once...
that isn't a model number and kenmore doesn't make anything so you have to send the full model number off of the dryer,open the door look around the opening where you put the clothes in and send the model number,if it's beeping and starting on it's own it sounds like you have a computer board problem with it but can't help you without the model number.
Dec 31, 2017 | Frigidaire FEQ1442ES Electric Dryer
Frigidaire dryer model LEQ1442ES0 beeps then shuts off after about 10 seconds. Four lights blink 3 times. Error code for?
Hi Robert, thank you for allowing me to assist you!
Constant beeping is often an indication of a possible malfunction. Let's try reprogramming the dryer by either flipping the household circuit breaker off or unplugging it. It is important to wait approximately ten minutes and then turn the dryer on. If resetting the power does not correct the issue, your appliance could be experiencing a communication error from the main control board, a potential wiring failure, faulty door lock assembly or the timer itself may not be operating correctly. This is not a normal DIY job so you may want to connect with a local servicer to determine the exact diagnosis.
Sep 01, 2013 | Electrolux EW1209i Front Load Washer /...
The dryer will run fine with no heat but when you try to dry with heat, whether its high or low, it runs for about 5-10 mins, with out getting warm and then shuts off and all the lights flash on it
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 15, 2011 | Kenmore 84152 Electric Dryer
Model 84152 beeps and won't start
probably the thermistor is bad. located on the blower housing in front of the motor nest to the thermostat. if you tilt the console back(remove the screws at either side, either visible or under snap off console ends) there is a tech sheet wiring diagram to trouble shoot the circut. unplug it first...
May 24, 2009 | Kenmore 84152 Electric Dryer
Dec 18, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore HE4 Dryer
rmcfarland I am going to make an assumption. You are using the Automatic cycle. If so then this is wet load detection. Open the dryer door and at the bottom on the front you will see 2 metal bars. This is you moisture sensor. Clean that sensor with a mult purpose cleaner. If detergent and fabric softner sheets build up a coating on this sensor, the control will think you put in a dry load and shut down the dryer. Hope this helps.
Jan 25, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
87 people viewed this question
Top Dryers Experts
