Question about Home
Bad shower head
Shower tube swells up by shower head help is needed my friend
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 45 Answers
The hose wall has weakened. If it's just a compression fitting in the base of the showerhead, you should be able to simply cut off the bad spot (and maybe a little extra to be safe) and reattach it, but odds are you need to get a new one. Sooner or later the hose wall will crack open and you'll have a mess on your hands.
Posted on Jul 14, 2013
  • nathanielrice Jul 15, 2013
    I found out it was the shower head thanks anyway!!!
  • 14 Answers
SOURCE: Grohe 24'' Relexa Shower Swivel Hand Shower Holder broke!
Try going to this web page and looking up the nearest parts carrier in your area.
http://www.groheamerica.com/t/25_3859.html
sanray
Posted on Dec 29, 2008
  • 659 Answers
SOURCE: Need assembly diagram for original Waterpik Shower
You just need to figure out which one you have and the manual should be on this site. If its not then give them a call.
http://www.waterpik.com/customer-service/instruction-manuals.html
Posted on Apr 03, 2009
  • 297 Answers
SOURCE: The shower hose leaks from the connection between shower hose and
have you tried teflon tape? wrap it around about 7 times and you will be fine.
Posted on Jul 16, 2009
SOURCE: How to turn on shower head of Delta monitor
I'm at my cousin's place and he has a delta monitor. Similar to what you guys are talking about.
To turn on the shower, I had to pull down on the faucet head, not the shower head.
To turn off the shower, I had to push the faucet head back up.
Hope this helps anybody out.
Posted on Jan 31, 2010
jyackle5
  • 8197 Answers
SOURCE: Removing flow restrictor from Moen Brantford posi-temp shower he
How I remove them is take a drywall screw and screw in to the flow restrictor. Then grab it with a pair of pliers and pull out.
Posted on May 16, 2010
My husband in stalled in shower vavle body. When bathtub is filling, water comes out shower head any ideas.
It's possible you installed the valve upside down, all values should be labeled in some way marking either hot and cold or it will say the word up where the riser tube port for the shower head is. If that's not the case remove the tub spout and check for any obstruction sometimes during tile or constructing debris can get into the pipe for your tub spout. Lastly the diverter on the tub spout could be bad. Try a new tub spout
Mar 05, 2016 | American Standard Home
How do install delta shower
If you are looking to replace only the shower head, you'll need two plumber's wrenches, a cloth, and Teflon tape.
First and foremost, read the install instructions that come with the new shower head...
After you clearly understand what the instruction's say, shut of the water supply lines for the hot & cold water.
Take one of the wrenches and apply it to the neck of the water supply tube coming out of the shower wall (a.k.a. goose neck or supply nipple, or arm, depending upon the design). It'll have male threads (the threads are on the outside of the fitting). I would place a cloth of some sort around it before placing the wrench on it so you don't mar the finish of the water supply tube.
Place the second wrench on the shower head assembly (which has the internal, female threads). and unscrew it by turning the shower head assembly counter-clock-wise (to the left) while holding the water supply nipple with the other wrench.
You need to do this, so you don't snap or deform the water supply nipple coming out of the shower wall- and/or possibly causing leaky damage to the fittings behind the shower wall.
To replace the shower head, you reverse the removal process- the only difference is, you wrap Teflon tape around the male threads of the water supply nipple before spinning on the new shower head.
Somethings to be careful of, and I can't stress this enough, DO NOT cross thread the new shower head onto the water supply nipple. You should be able to screw it on the new shower head by hand- where it is hand tightened- then using the double-wrench method that you used to take off the shower head, turn the new shower head an additional half to three quarter turns with the wrench, clock-wise; and I mean gently.
Here's a nice short video on the subject, illustrating my instructions: http://youtu.be/fiv4Zq9v4co
Jul 27, 2014 | Delta Faucet Home
Why would water comes from the shower head & the nozzle ???
looks though the ceramic ball valve needs replacing on the unit
Jul 16, 2014 | Home
Little water comes out my shower head when I take a shower, should I call a plumber, or is this something that I can fix myself?
remove the shower head. and if the water flows normal, its a clogged up shower head. if takeing a shower and the diverter valve goes bad. water will come out of the spout. check out shower head to see if its clogged. sometimes you can soak the head in a good cleaner and it helps it. but if its the showerhead thats plugged. you can always put a new one on also. good-day !
Jan 10, 2012 | Home
I have replaced the guts to my delta shower two years ago. It now is holding a lot of water in the spout before it hits the shower head. Is there a problem with the shower head or do the insides need to be...
Lets start by removing the shower head from the chrome pipe on the wall and check the screen filter to make sure you are getting full flow. if this dose not cure problem then lets look at the diverter valve.is it a push button on the wall plate or a pull down spout diverter? if it's the push button it may have a bad paddle and needs to be replaced. If it's on the spout i am leaning towards the shower head. hope this helps. Let me know if you need more information.
Dec 22, 2010 | Delta & Single Handle Shower Faucet
My mira sport shower is only 2 years old just over and is leaking from the shower head I have taken the head off, is it the washer or do I need a new shower head? Sorry I am unable to give you the brand....
firstly clean all the shower holes with a needle tip. you can also apply some descaler on the shower. Cut an old cycle tube piece round to the size of shower head. Make a hole in the centre of the cutted piece.Apply some grease on the patch & place it between the shower & head. Tight it up.If there is not enough space for rubber just apply grease on the head & tight it.
Aug 13, 2010 | Home
1/2 water through shower head 1/2 through tube
patmac make sure the clear hose is a overflow first. then make sure all connections are correct,sounds like an areator problem,some after market shower heads don't come with one you can purchase one at your local plumbing store.
Apr 05, 2009 | Home
Mar 24, 2009 | Delta T13420 Chrome Classic Single Handle...
Our Aqualisa power shower lacks water pressure power
more than likely you have some debris near the shower head
take an adjustible wrench( crescent or channel lock
wrap a rag around the eustaceon( chrome tube coming out of shower wall srap around tube to protect the chrome hold it firmly with vicegrips or channel locks, take adjustible wrench or chanel locks and remove the chrome nut holding the shower head on to the eustaceon(turn counter cockwise be careful not to drop the tools that wil damage the tile or fiberglass
after removing showerhead
turn on shower to force and debris out and place shwoer head into stream of water to clean out any deposits the head may have some type of screen to strain the water
this should work if the flow has not incresed then there is a need to adjust the flow valve at the control
to reinstall the shower head reverse procedure
if you have any teflon tape wrap it around the threaded portion of the eustaceon
good luck
hoe this works
Dec 27, 2008 | Home
Home Logo
63 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
