Question about Black and Decker USA CHV7202 7.2-Volt Cordless Wet/Dry
REPLACE battery black and decker CHV7202 vac
How to replace battery
Need a replacement battery for chv1210 dustbuster 12v
SORRY we do not source things for people search google Google
Nov 29, 2017 | Vacuums
Black decker problem
Sounds like it could be a bad battery pack that's not accepting a charge.
Jul 14, 2014 | Vacuums
Black decker dustbuster pivot is not recharging
Black and Decker Auto Pivot Vac #PAV1200W is only for vehicles as this operates off your battery via cig lighter. You have to remove the cig lighter. Also, it will not use A/C outlet even if you have cig socket version in A/C outlet. Did not even vac or have power. I thought that I could use it for inside house and in cars, but it's only for cars. Haven't tried it in my car yet. Thought this would of been good for deep down in couches and stairs, but I guess not. Just saying. It's now off the market I see.
Apr 11, 2012 | Vacuums
My phv1800 18 volt hand vac's battery seems to be running down. is there any way to revive it? if not; can i purchase a new battery to replace it? thank you!
If you are handy with a soldering iron, and don't mind spending a few hours building a new battery pack using 1.2 volt "sub c" cells, you can disassemble the PHV1800, and rebuild the pack yourself. I just did it tonight, and the vacuum works like new.
However, I'm not going to do this again. The PHV1800 doesn't use a single battery pack, but 2 packs that have to be assembled with very little room for error. You can purchase a combination battery pack/motor assembly for $75 (US currency, price currect as of 10/2011), unscrew the screws that hold the vacuum together, and replace the battery/motor unit as one.
Jan 24, 2011 | Black & Decker PHV1800 Bagless Handheld...
Is not charging - no red light
Yes, it can be replaced. Can be ordered from Black & Decker. Some people would say it's worth fixing others would not. Don't know cost of battery -- probably under $20.
Apr 29, 2009 | Black & Decker CHV9600 Handheld Vacuum
CHV7202
HI
Youve either mis fitted the cup or the seal around it is no good
Feb 18, 2009 | Black & Decker CHV7202 Handheld Wet/Dry...
No problem. Just bought a new Black & Decker Corded Hand Vac and want to register @ BlackandDecker.com/New Owner
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=553450
Generic problem for all Vacuums
Posted by jmrowe on Apr 28, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
I checked the website and if you go to the BlackandDecker.com website you can register on line clicking on the contact us tab @ the top of the page and then scroll down to register your product on line, feel free to contact the factory with the information listed below:
http://blackanddecker.com/
Contact Us -- Customer Service and Produce Support
1-800-544-6986 (M-F from 8am until 5pm, Eastern Time)
Black & Decker
101 Schilling Road
Hunt Valley, MD 21031 USA
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 28, 2008 | Vacuums
How long am i suppose to charge my vac?
If your battery is not holding a charge, then you will need to replace the battery. Unless the charger isn't working, but usually it is the battery.
Jan 28, 2008 | Black & Decker CHV9600 Handheld Vacuum
REPLACEMENT FILTERS
I suggest calling customer service.
http://www.blackanddecker.com/CustomerCenter/
Incidentally, the model number you gave is a 3.6 volt vacuum.
Dec 15, 2007 | Black & Decker CWV3630 DustBuster Wet/Dry...
CGV9600 Batteries
http://www.dewaltservicenet.com/Products/ProductDetails.aspx?pid=28044&tid=6872
I hope the above link works. Replacement parts are available through DeWalt.
Also note, they now have a 12-volt version of the same vac. The price is about twice what you will pay for the replacement battery for your 9.6V model, but it may be worth it for the extra power.
Dec 02, 2007 | Black & Decker CFV9600 DustBuster Bagless...
Black and Decker USA CHV7202 7.2-Volt Cordless Wet/Dry Logo
145 people viewed this question
Top Black and Decker USA Vacuums Experts
Are you a Black and Decker USA Vacuum Expert? Answer questions, earn points and help others
