Plaw10 My technika plaw10 powerline adapter has stopped working. It works when I pug in and reset but stops after 2 minutes. the top two green lights work but the data light doesnt.
SirHanz
  • 145 Answers
SOURCE: Error code 1 2
I found this list of codes
Error Code Probable Cause
12 No error detected
22 Recovery from momentary Reset
32 Lamp Cover open
33 Air Filter Cover open
34 Lamp abnormality
35 Chassis Fan failure
36 Exhaust (Back Cover) or Lamp Ballast Fan failure
37 Engine (DMD or Lamp) Fan failure
38 Excess Lamp Temperature
39 Excess DMD Temperature
41 Short Detected
44 DVI Cable (between Chassis and Engine) disconnected
Posted on Feb 12, 2008
  • 53 Answers
SOURCE: HP Officejet 6310 All-in-one Just stopped
re install software that came with it.
Sounds like it took a powerspike.
try the software reinstall first.
goodluck
44hink
Posted on Jun 12, 2008
Sandy4u
  • 107 Answers
SOURCE: hp deskjet 3550 problem
Green light blinking is indicated that u r one of the cartridge (or both cartridges ) are faulty .please check u r printer with tested Ok cartridges ...it should be resolved
if this information is useful for u please Rate me .........
u r Rating is Important for me.
Posted on Jun 26, 2008
munnabhai
SOURCE: Epson C48 red and green lights flashing alternately
Only Solution is Re-burn printer firmware.
Mahesh DG, Pune
Posted on Sep 21, 2008
SOURCE: Reset light comes on, unit stops operating when tank is full
I was up all night with this since I just purchased it yesterday and I wanted to be certain that there wasn't some simple alternative to returning the humidifier since the reset light keeps going on immediately after I turn the unit on AND I've already followed all the directions to the T. Believe me - I was ready to return it cause ain't no 38.99 worth me doing all this tinkering and trying to figure out why they couldn't make the unit correctly cause apparently A-LOT of people have this problem. If it wasn't for my three children being so ill including myself getting sicker going out to purchase the humidifier and I was trying to avoid going back out to further compound my illness----I WOULD have just returned it. MAYBE I still will return it. ANYWAY, here's the deal: the water in the tank SHOULD flow into the boiling chamber where of course steam rises from there; however, the WATER VALVE in the CAP to the water tank does not allow any water to flow into the boiling chamber because it is so tight. The reset light goes on as if there was no water in the tank because of course, the heater is on, but no water is getting boiled because the water can't get in. There are a few things you can do. First: the water valve is a little stick and a spring within a piece of rubber that can be slipped out of the cap (this is what I chose to do). Now the water flows easily and even with the unit set to high, there is no problem. It just works. Second: You could remove ONLY the stick and spring from the water valve's rubber piece. This would work if the hole in the rubber piece happens to allow steady water flow (mine wouldn't). Third: you could probably do some cutting til you were satisfied with the results.
Posted on Feb 01, 2009
Recently my pls300 adapter stopped providing my computer internet signal and all the lights are flashing on the unit though only one computer is plugged in, i tried everything even with technical support...
I had the same problem few weeks ago.
After purchasing a new powerline adapter (from another brand), I decided to open the PLE300 to see where the problem is.
It is important to say that, before the adapters stopped working, the POWER ON light had faded until it turns off on both devices.
I didn't care so much also because the link between both PLE300 and PLS300 continued to work.
The Linksys uses a particular configuration (using a TNY174PN integrated circuit) to obtain the proper voltage for the internal components.
I'm quite sure that a damage in the internal power supply is the cause of my problem and, so, I started to check all electrolytic capacitors near that component (in the data sheet [http://dalincom.ru/datasheet/TNY176PN.pdf] is reported that the capacitors are used to limit the output current).
Without the schematic diagram is hard, but i hope to find the solution.
Jan 04, 2011 | Cisco Linksys PLS300 Powerline Adapter...
Turned my ethernet adapter off on the upstairs one and back on to find that there is no green lights anymore, just a red light on status. Then did the same with the downstairs one and they both have a red...
Powerline adapters are generally not durable. You can try to reset the power adapter by pressing the reset button located on the device itself. If it still gives you a red light than call the manufacture and get it replaced.
Jul 15, 2010 | Powerline Ethernet Network Adapter
My wii stopped working all of a sudden and i don't know whats wrong with it. I've reset it and unplugged it and it still won't work. The light is just off and I didn't do anything to it! Is there another...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} One of two common possible problems. Either 1) Your AC adapter needs to be reset or 2) Your AC Adapter is bad.
Most power issues with the Wii can be fixed by resetting the AC adapter. You can easily reset the AC adapter by following these steps:
Unplug the Wii AC adapter at both ends (from the back of the Wii system and from the wall outlet or power strip).
The AC adapter must remain unplugged at both ends for a full 2 minutes.
After you've waited 2 minutes, plug the AC adapter into the Wii system and directly into a wall outlet, not a surge protector or power strip. If the power light comes on and stays on, then it appears resetting the AC Adapter worked.
If it's not working, you can get a *new* NINTENDO brand AC adapter at the following
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} store.richspsxparts.com/wiiredvddr.html.
Beware of cheaper knockoffs around the internet.
May 26, 2010 | Nintendo Wii Console
The middle ight keeps blinking and it wont work how do i fix it
Blinking middle light indicates an issue with the powerline used between the powerline adapters. To isolate the issue plug both the poweline adapters in the same room and check the lights on them. If they work fine in the same room then the issue is with the powerline. You may have circuit breaker, surge protector between the powerline adapters and that will prevent you to get a connection.
Hope this helps.
Regards
Anand
Mar 12, 2010 | NetGear XE102 Powerline Ethernet Adapter...
Belkin powerline adapter doesnt connect to internet
try resetting the adapter
if not working try updating the firmware
if not working make sure ur adapter is pluged in the same power(electricity) phase of ur house with the router
the house will have different power phase so make sure of it
both the router and the powerline adapter must be in same phase of electricity
Jan 18, 2010 | Belkin Powerline F5D4050 Network Adapter
Netgear WGX102 stops working after some usage
As the device works fine when connected in the same room. the issue does not seem to be with the powerline adapters but with the powerline itself.
If you still suspect the powerline adapter to be faulty then try connecting another powerline adapter at the same place and check if it works. This will help you for a speedy resolution
Jun 12, 2009 | NetGear WGX102 Repeater
I have 2 comtrend dh-10pf powerline adapters. one of the adapters status is a red flashing light and the AP light and the Ethernet light are blank. the second powerline adapter has a solid red status...
To start you need to factory reset both adapters,
plug them both into a wall socket next to each other, press the config/f reset button, hold in until ap light goes off, repeat on the other one.
Now you should have a red status light on both.
Press the config/f reset button on one for about 5 seconds, wait until ap light stays on, this one is now your access point (ap) that should be plugged in to your router when you have finished config.
Now press the ap adapter config button again for about 5 seconds until ap light flashes, then press the config button on the other adapter until ap light flashes, wait until they both stop flashing, wait a few seconds, the status light on both adapters should be green, and one adapter should have an amber ap light.
Hope this helps.
Jan 28, 2009 | Computers & Internet
Commtrend powerline ethernet adaptor
You can find out by clicking on Start, Run, type "cmd" hit enter, a black window will open, in that window type: ipconfig , hit enter, you should see 3 address's IP, DNS,Default Gateway. if not their could be other issues causeing the prob. or the hardware is faulty and needs replacement.
Nov 03, 2007 | Powerline Ethernet Network Adapter
167 people viewed this question
jasbo
jasbo
