Question about Garden
Craftsman lawn tractor
My LT2000 starts and runs great while in neutral and will accelerate, while still in neutral when I let the clutch out it wants to stall. Why?
    Scholar:
  • 61 Answers
Really need to know if it acts like it wants to stall or if in fact when you let the pedal up it does stall ? Because they're closely related yet 2 different types of problems. One could be a safety switch problem the other could be one of a few different issues. Can you let us know if it does stall or are you pushing the clutch/brake pedal down before it does ?
Posted on Jul 13, 2013
wadembly
  • 448 Answers
SOURCE: Craftsman lawn tractor model new battery drains quickly...
it could be the stator in the engine check the voltage with the volt meter when its running if its low check connections on battery & voltage if its below 12.5 volts then its the stator but the only thing is the engine should run with-out the battery so there is something else going on there is a fuse in the electrical system if theres a short that fuse will blow & engine will stall
Posted on Jun 08, 2009
  • 376 Answers
SOURCE: gear of starter motor won't engage in flywheel to run the tractor
Look under 'My Profile' (Longhorn294 in the top right corner of this page)on page 5 at this post and solution. "craftsman riding mower starter will spin but not engage". Dwain
erpaalai
  • 999 Answers
SOURCE: LT2000 had been working fine, but trying to start
Make sure there is no corrosion on the battery terminal connections and check the fuse and safety switches clutch, brake,seat.
Eric
Posted on Jun 29, 2009
  • 13 Answers
SOURCE: How to remove blades on craftsman lt2000
There usually bolted on from underneath you must have a wrench are set of wrench to take off. Most models are some times kinda hard to get to
Posted on Sep 29, 2009
  • 252 Answers
SOURCE: Craftsman lawn tractor, LT2000, 18
hi there
here is web site for manual and parts diagram
http://www.hammerwall.com/Download_Manual/12377/
have the valves been adjusted correctly ? or could have a tight valve clearance
and when gets warm holds valve open - looses power
your engine will be 31p777 intek ohv avs
run the piston to tdc on compression stroke , then turn piston past tdc & set piston is 1/4 inch down the bore on power stroke this eliminates decomprssor lift from the setting
intake should be 0.003 Thou
and exhaust 0.005t thou
then check the carburettor main jets and emulsion tube and pilot jets and air bleeds and progression ports for obstruction etc for restriction / blockage
check fuel flow from tank to carb , check that the fuel solenoid has got continual 12 volt supply
when switched on and does not go o/c cutting fuel supply to main jet
have a look let me know
cheers hope it helps
pauly 46
dont forget the thumbs rating
Posted on Jun 09, 2011
Craftsman lt2000 will not start
You should read 12 volts atleast. Try www.managemylife.com for a owner's manual.
May 08, 2012 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman LT2000 Automatic wont move forward or backward
when you took off the bag did you pull the lever that allows you to push it around the one that puts the hydro drive in neutral its on the back a couple inches away from the eyelet you can tow with it should be released forward
Mar 24, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Cuts out when I let out the clutch
try and find a relay, near the engine, which is connected to the safety switches attached to the seat and clutch/brake pedal. you may find that relay to be bad, or you need to replace or short the safety switches. If you short them, might be a safety issue as the engine and blades will run unattended. Seems to be a very common problem with craftsman lawn tractors.
Jun 23, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
HELPING A FRIEND WITH A CRFTSMN 18HP FRNT ENGINE LT2000 LAWN TRACTOR. THE ENGINE RUNS GREAT BUT WHEN HE RELEASES THE CLUTCH/BRAKE TO GO FORWARD OR REVERSE THE ENGINE DIES.
Put trans in neutral if trans is a gear drive and see if mower can be pushed, if it can you can push rule out stuck brake. If you have a hydrostatic trans you can put trans in bypass and push to see if brake is stuck. Remove drive belt at engine or at trans and try the cluch, if motor stays running there is a trans problem.
Mar 13, 2010 | Craftsman Garden
Eric
Jun 29, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
50 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
