Question about Water Heaters
Water is not hot
My light comes on when unit is plugged up but water us not getting hot what do i do
  • Water Heaters Master
  • 5,089 Answers
Re-post question and include brand and model number of water heater and say if water heater is tank-type or tank, and if unit uses gas or electric power, and if heater is for pool or spa or household water consumption.
http://www.thetankatwaterheaterrescue.com/forums/forum3/
add a comment, and also include what you have tried so far
Posted on Jul 13, 2013
My hot water light wont go out,my central heating wont come on either but I do have hot water
I'll need to know what make--model--- age of this unit is and if it's electronically controlled to help you----your question is too vague do to the enormous variety types of heating systems----I'm going under the info provided that this is a boiler with domestic hot water coil----you say central heating so this throws me off---do you heat with hot water--hydronic-----or forced hot air----if hydronic---it sounds like your circulator in not functioning----a bunch of reasons circulator has failed---aquastat's "circulator control" has failed---thermostat has failed----broken wires----plugged lines----it goes on and on----this is the best I can do with this info sorry Happy Rabbit
Apr 02, 2015 | Water Water Heaters
Atwood water heater electronic ignition
Copy following link for possible troubleshoot resources:
http://waterheatertimer.org/Atwood-water-heater-resources.html
Might want to call service technician instead of messing with gas appliance.
Or sent to service center.
Install 20 gallon under counter electric water heater and connect to 120Volt... 1500 watt element will heat water pretty quickly. To have more hot available, turn up water heater thermostat, then that will give 2 showers because more cold will be added to very hot water, thereby stretching amount of available hot..
http://waterheatertimer.org/How-to-install-under-counter-water-heater.html
Add a comment as needed
Jun 02, 2013 | Water Heaters
Ge Smart Shield Water Heater will not light
I think this unit is A/C powered. Check for tripped circuit breaker. Make sure power cord is plugged in.
Jun 04, 2012 | General Electric GE SmartWater Household...
After water to house was shut off, my Noritz tankless water heater is on but won't produce hot water. On the unit, the light indicating that the burner is on stays off now.
you probably had debris get into the filter or flow sensor when the water was turned back on. I'd recommend checking the filter first and if that doesn't work, call Noritz Tech support to help you with the flow sensor.
the filter is a black plug located on the cold water line (labeled cold on the bottom of the unit). It points torwards the left.
Apr 14, 2010 | Noritz 7.1 Gpm Natural Ng Gas Tankless Hot...
Pilot light will not automatically light when hot water is turned on
This is a great unit! Try turning the flow nob to the half way point and the flame all the way to low. Run the hot water tap and slowly turn the flame dial until you hear the unit try to light. Every house is different regarding the restrictions in the plumbing and water pressure. Once the unit tries to light that is your minimum setting. It is best to leave it there.
Apr 05, 2010 | Bosch & Tankless LP Hot Water Heater
I have Atwood GC6aa-9e. Water isn't getting hot.
If you've checked at pressure relief valve ( careful, not to burn yourself just in case it is hot) by pulling lever and catching some water that comes out in a cup or whatever. If it feels hot out of there, check that by-pass isn't faulty. Not uncommon for valves to seize, and only partially open, or close, and end up mixing hot with cold.
Mar 12, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
Hot water heater does not light
burner and pilot assebly and orifaces need to be cleaned
Sep 16, 2009 | Fasco Bradford White Water Hot Heater...
Rheem Pronto Hotwater Heater Error
Unplug unit from wall. Disconnect remote wires from circ board, and let unit set for about 5 minutes. plug back in. run water and see if unit comes on.
Jun 16, 2009 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
No hot water
if the leak is behind the handle take the handle off and tightn the packing nut, do not over tighten, as far as luke warm water is this with just one facucet on, they way these tankless water heaters work they are by gpm, gallons per min, if you have more gallons of water going thru the unit then it is designed for then it won't get hot, if your water pressure is to high going thru it will push it to fast thru the unit and won't get hot, your house pressure should be no higher then 75lbs no lower then 65lbs
Feb 25, 2009 | Bosch AquaStar Indoor Natural Gas Tankless...
Water Heaters Logo
29 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
