Cars & Trucks Logo
Dunn Posted on Jul 13, 2013
Chrysler Concorde 99' radio fuse constantly blowing
So... somewhere I goofed yesterday installing and amplifier. Everything in my audio system is stock and wanted to enhance the sound but only a little. Once I got the amp hooked up, powered on the radio and only my from speakers had sound. Played around w/the gain and frequency on the amp and now I have no sound in any speaker and worst of all, my radio comes on but no sound. Checked the fuse panel, fuse 18 blown. I went to buy more and soon as I put em in, they all blew the second I turned the car on and its a yellow fuse that burns to turn bright orange/red. Please help
  • Dunn Jul 15, 2013
    I appreciate all the answers everyone gave. Defeat was apparent but I pushed to figure this out and yup, Shadycheeba came the closest. What happened is the factory amp blew so no sound. Bought a new radio (JVC) and had to do a bypass for each speaker (6 total)... it worked!!!!! this project of mines is to be continued. I've got another question to post (smh)
lamont
Level 1:
New Friend:
Problem Solver:
  • Contributor 9 Answers
  • Posted on Sep 13, 2013
lamont
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
9
Questions
0
Helped
619
Points
12
Everything isn't stock. The amplifier isn't stock. Is the radio stock? If so what are you using for remote "on" to the amp? Start there.
5 Related Answers
Anonymous
  • 8 Answers
  • Posted on Dec 30, 2008
SOURCE: Anyway to bypass my Bose Amplifier
not too sure what you are trying to do but just buy a aftermarket deck..for example for 100 bucks jvc has a nice deck with remote that plays mp3 and even has a jack right on the faceplate for a mp3 player.then throw your subs in the trunk hook up the amp and bingo banging beat.if u have the aruroa with the battery under the back seat its even easier
Anonymous
  • 290 Answers
  • Posted on Mar 26, 2009
SOURCE: needing wiring diagram for 1991 dodge dynasty le
here is what I found:
http://www.the12volt.com/installbay/stereodetail/715.html
kdm56
  • 48 Answers
  • Posted on Apr 22, 2009
SOURCE: No sound out of left side speakers, front and back.
easiest way to see if the left outputs have gone is to swap the right and left speakers over. if the left works out of the right channels you know if the set has had it.hope this helps
Anonymous
  • Posted on May 14, 2009
SOURCE: Car Door Speakers wont work after installing new Stereo
check you Fade and Balance,sometime the ground is used for two speakers sometimes a ground is used more then once will cause your problem ........Good luck......
Anonymous
  • 97 Answers
  • Posted on Jun 18, 2009
SOURCE: 99 Chrysler Concorde electrical problem
probably a relay. relays control switching of power from one compound circuit to another. because you have multiple circuits that are not working, this sounds likely. get a wiring schematic and find out which relay controls that system, then try replacing it.
Everything works on my stereo system,but there is no sound
Car Stereo Head Unit Install ** No Sound ** Amp Not ...
? 10:41
https://www.youtube.com/watch?v=wQ9bSdJGMjg
Mar 23, 2014 - Uploaded by PSYCHOTICNORMAN
Video for those who installed their head unit correctly, but got no sound / factory amplifiers not turning on. ... Car Stereo Head Unit Install ** No Sound ** Amp Not Turning On ** work around. ....Did everything to the letter on a 2001 Chrysler Town and Country and while I do have audio, my audio is cutting in ...
Everything works on my stereo system,but there is no sound ...
www.fixya.com/.../t26059653-everything_works_stereo_system_but_no
1 hour ago - everything works on my stereo system,but there is no sound lxi 4cd canger - Chrysler 2001 Concorde question.
Chrysler Concorde radio works but no sound Questions ...
www.fixya.com > ... > Cars & Trucks > Chrysler
Chrysler Concorde cars & trucks radio works but no sound questions and answers. ... Fixya - Solutions for Everything ... My 2002 concord lxi when ... CAR STEREO HAS POWER BUT WILL NOT OPPERRATE ... Question about 2001 Concorde ... ...sound from radio thru speakers Is there any popping when playing a CD or ...
FUSE FROM BATTERY BLOWS WHEN IGNITION SWITCED ON
There is a short to ground somewhere.Look for a hot wire touching metal.
Installed a Sony Xplode into a 99 Blazer and everything on the radio works but will not play through the speakers
The Bose system is complex - it has an amplifier separate from the Bose compatible radio. This amplifier takes low level audio signals from the radio, not full driver outputs from a replacement radio, and by trying to use the replacement radio you may have blown the amplifier. If that is the case, you may not be able to go back to the original radio.
The only option you may have with the replacement will be to find the Bose amplifier and bypass the connections to feed the replacement radio outputs directly to the speakers. This may not be as simple as it sounds, as distribution to the various speakers comes from the amplifier, not the radio, and the wiring from the amplifier to the radio may not have all the wires you need. Before going on, you had better get a wiring diagram for the Bose system (service manual or Alldatadiy.com).
2answers
2000 Concorde - power locks, interior lights, radio not working
There is most likely a fault in the system and it will have to be reapired by certified tech
3helpful
1helpful
I change fuses, radio still not working, does the car have to be on to change fuses?
There are 2 (or 3) fuses for your radio.
One on the Constant (memory retention) and one for the ignition (on and off with key)
Fuse 18 (20A) (if equipped) is for the factory amplifier
Fuse 19 (10A) Constant power Fuse
Fuse 4 (10A) Ignition Fuse
CLICK HERE for the schematic to verify
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
2answers
I have a 99 chrysler concorde and the radio will not come on,
turn ur key to on and pull 10 amp fuses out and find a blowin one put a new 10 amp in
Panel lights go on and off while I'm driving
I HAD THE SAME PROBLEM BUT IT WAS BECAUSE I HAD ADDED SOME HEADREST TVS AND SOME L.E.D LIGHTS TO THE BACK OF THE RADIOS IGNITION. AFTER I SEPARATED EVERYTHING AND ADDED A FUSE PANNEL EVERYTHING WENT BACK TO NORMAL.
Top Chrysler Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Chrysler Expert? Answer questions, earn points and help others
