Question about GE Monogram ZIC360NRRH Bottom Freezer Refrigerator
Temperature problem
I have a 7 year old ZIC360N in which the freezer registers -24 degrees and the fresh food section is 50 degrees. Any idea what needs to be replaced
Sea Breeze
  • 4655 Answers
SOURCE: freezer temperature working fine fresh food
I need you to confirm that your model number is ZICS360NR and I will help you, Sea Breeze
Posted on Nov 13, 2009
jmgldsmth
  • 2005 Answers
SOURCE: refrigerator freezes fresh food section and always runs
Please read it appears that there are two defrost timers for your refrigerator one for the freezer one for the refrigerator
http://www.partselect.com/PartDetail.aspx?Inventory=310858&SourceCode=4#RepairStory
Posted on May 04, 2009
louislevel_2
  • 374 Answers
SOURCE: the freezer works fine but the top is warm
hi there,
there are several factor to be consider in this problem
thermostat is not functioning properly- check if busted replaced
capillary tube clogged- check capillary tube if there is ice
develop in part of capillary tube if clogged up-purge the
system.
Under charged on refrigerant-check by clamp ammeter
this solution should be done by certified ref/ac technician.call in to your service center.have a nice day
Posted on Jul 04, 2009
woodchuck789
  • 4070 Answers
SOURCE: variance in freezer compartment temperature
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost heater, defrost thermostat. If the heater and thermostat are ok it’ll be the control board.
Posted on Sep 04, 2009
  • 256 Answers
SOURCE: Freezer temperature fluctuating way up.
Your problem could stem from an issue with the defrost timer, the compressor or its attachments (e.g.: relay, capacitor, etc.), or the freezer/evaporator fan motor. Contact an appliance service company.
Posted on Feb 11, 2010
How frequently should the compressor run on a fridge?
Hello;
My name is Peter. I am a retired field service refrigeration technician.
The model number provided does not register. Your model number is located on the inside wall of your fresh food section.
Your freezer is your only source of cooling. It will meet its setting before meeting the refrigerator temperature.
The normal setting are -2 to +2 degrees F. for the freezer and 35 -40 degrees F. for your fresh food section.
Your freezer will go about 10 degrees F. above the set temperature. Then when it reaches 10 degrees F. below the set temperature the compressor will kick in.
You have condensing coils either under your unit or a canister in the back which gets ride of the heat. When the condensing coil is plugged up with dust, this could affect your cooling by as much as 40 degrees.
I do not think this is your total problem.
Feel the face of your separator wall between your freezer and fresh food section. Is it hot?
Your problem is your condenser fan in the lower right back of you unit is burned out.
So, you can not dissipate the heat.
Remove the lower back cover. Take a common household fan to blow air under your unit.
Your compressor is running to make up for the heat that the condenser fan can not dissipate.
Feb 27, 2015 | Electrolux Refrigerators
We just got our new frig anf freezer is blinkinf h1 what does this mean
Hello;
H1 is really HI. Your freezer is too cold. You only have one source of cooling and that is your freezer. You freezer also cools your fresh food section. Your freezer will meet its temper setting before it meets your fresh food section.
The normal setting for the freezer is -2 to + 2 degrees F. and the normal setting for your fresh food section is 35-40 degrees F. Adjust to these settings. Wait 24 hours for your system to stabilize.
If the error code does not go away or your freezer and fresh food section are reasonably within the above settings, then you need to contact the store where you purchased it.
It is not uncommon for a new unit to be delivered one day and I am there the very next.
Feb 26, 2015 | Frigidaire Refrigerators
What could cause the fresh food section of my refrigerator to be too warm?
UR COLD CONTROL THERMOSTAT, UR AIR FLOW VENT, UR THERMISTORS, A EVAPORATOR FAN NOT WORKING OR OBSTRUCTED
Feb 24, 2015 | Refrigerators
The alarm light is flashing what do I do to stop it.
Hello Mrs. Mavis;
My name is Peter. I am a retired field service refrigeration.
The alarm light is a good thing. It is telling you that something is wrong. Generally, the alarm goes off when there is a temperature problem in either the freezer section or your fresh food section.
You only have one cooling source and that is in your freezer. Your freezer will satisfy its own temperature before it feeds your fresh food section.
Ok, Your freezer temperature should be between -2 & + 2 degrees F. Your fresh food section should be between 35 & 40 degrees. F. Adjust you temperature settings accordingly. Wait for a few hours to see if the alarm goes off.
Another problem with maintaining temperature control; people tend to over pack their freezer or fresh food section. Check to make sure your food product does not over extend the shelves. Also check the racks on the doors. Check to see if food product does not over hang the racks.
You also need to maintain your refrigerator. You have a cooling coil like the radiator in your car, it gets rid of heat. You must keep this clean. A dirty condenser coil can effect your temperature by as much as 40 degrees F. This coil is located either under in the front of your refrigerator or a canister looking item in the back of your refrigerator behind the lower cover.
Look at the back of your freezer wall. Is there a lot of frost or ice?
This could be either a defrost heater or freezer fan motor.
Call me. Lets talk about this more. 443-306-1362.
Nov 04, 2014 | Refrigerators
What is the ideal setting for fridge on Bosch KGN34VW20G
Hello John;
My name is Peter. I am a retired Sears service technician. The freezer temperature should be between -2 & + 2 degrees F. The fresh food section should be between 35-40 degree F.
Pick up a inexpensive temperature gauge with a steel shank. Place the temperature gauge in the freezer center. Do not make contact with any food product. Allow 20 minutes and read the gauge. Be quick the temperature on the gauge will drop quickly when you remove. Adjust the temperature control knob according until you reach the desired setting. Repeat this process as necessary. Do the same for the fresh food section.
You only have one source of cooling; the evaporator coil and fan in the freezer. The freezer will meet it's temperature setting first before it opens the fresh food section damper.
A balanced system will save on your electrical bills. The compressor will kick in only when demand is met. Your compressor should not be running continuously.
Oct 23, 2014 | Bosch KGN34VW20G White 280 l Fridge...
What is the correct temperature for a daewoo fridge freezer
Your freezer should be in the range of -2 degrees to +2 degrees. Your fresh food section should be in the range of 35-40 degrees.
You only have one cooling source and that is the evaporator coil in your freezer. The freezer will attempt to satisfy the freezer temperature setting first. Having met that it will open the air damper to your fresh food section. Such a high freezer temperature will cause freezer burn on your food. It is also a waste of electricity, where the compressor is always running to meet the high demand
Oct 17, 2014 | Daewoo FRAU20ICB Black 561 l Fridge...
Ge refer model psc25mstass fresh food section not cold enough freezer cooling fine
I realize this is an old post but information is always helpful if it is correct. I have a GE Model TFX22ZRB, Main tools needed are a refridgerator thermometer, a cheap multimeter, 1/4" hex driver, phillip screwdriver and regular blade scewdriver, above all, alow time for tempeture change when measuring tempeture. The freezer is running at -8 degrees C or aproximately 28 degrees F. I don't care about 1 or 2 degrees at this point in the freezer, the defrost system is working ok, The freezer is cold enough. The fresh food section is running at 48 degrees F, the damper is wide open between the freezer and cold food section, I manually removed the damper door and controls since I am only interested in seeing if I can drive the fresh food section colder. Looks like the fresh food thermostate controls the compressor and not the damper to shut off the cooling process when the tempeture gets cold enough. Since the fresh food section does not get cold enough (this should be in the uppers 30s F) there is no need to move the fresh food thermostate out of the normal range setting (mid point in my case) with the operator control. Defrost heaters ok, this unit uses 2 heaters hooked in series with a evaporator coil thermostate also in series with the heaters. Heaters aproximately 25 ohms total risistance, coil thermostate open at room temp and closed when below 32 degrees. Only other item in circuit is the defrost timer, this can be manually advance to open and close the defrost circuit, in my case, when in the defrost mode, the evaporator fan stops and the heaters heat up. The defrost timer in my case has a 12-16 hour cycle time and a 30 min defrost time, so in a 24 hour period I may get only one defrost cycle. One item of importance. make sure something has not fallen in the lower back or the fresh food section of the refridgerator to block the air flow return, this will effect the coo;ing process. Now with the damper wide open, the defrost circuit working ok I am going to look at the evaporator fan itself for speed, shifted blades or the air circulation between the freezer and the fresh food section, I have cleaned the condenser coils but I am leaving the condensor and compressor out of the equation since the freezer is cold enough but at this point I am considering the possibility, I may need to replace the fridge if the compressor is not working to par.
Jul 18, 2012 | Refrigerators
Freezer turns of in cold weather
Many residential refrigerator / freezers are designed to work at temperature considerably above above freezing. Most modern refrigerator / freezer have a single electric thermostat - located in the fresh food compartment. This lone thermostat will control the compressor to keep the fridge (fresh food) section at the desired temperature (usually between 34 - 38 degrees F). The freezer will get colder regardless of how cold it is already whenever the fridge thermostat turns the compressor on.
Now that you see how the thermostat works, let's look at what happens when the fridge is placed in an unheated space - like a garage. In winter time, the temperature can drop considerably below 38 degrees. If the outdoor temperature remains cold enough, for long enough - it will affect the thermostat in the fridge. The temperature inside the fridge could drop below 38 degrees, preventing the thermostat from telling the compressor to turn on. Meanwhile, the temperature in the freezer compartment slowly rises from the normal -10 to 0 F degrees. It will continue to rise until it is the same temperature as the fresh food compartment or until the thermostat in the fresh food compartment tells the compressor to turn on again. This means the freezer contents will thaw.
If the temperature in the garage is even in the 40 to 50 degree range, the loss of cold in the fridge may not happen often enough to keep the compressor coming on often enough to keep some freezer items frozen solid - such as ice cream. Remember, water freezes at 32 degrees F, other products may require lower temperatures to remain frozen, and could thaw at 28 or other temperature.
Feb 13, 2012 | Refrigerators
Freezer side cold fresh side not GE GSH22KGMD
Find the return air It can't come in if it can't get out. also if you were checking it with the freezer door open you will not feel the air. Just in case i have done that myself. if all air ducts are open and it's getting o I should be 20 in fresh food with the control on 9.
Sep 22, 2009 | KitchenAid Superba Architect KSCS25INSS...
Top mounted freezer on refrigerator not working
Move the refrigerator to a room that is at least 50 degrees F.
Temps on most refrigerators are regulated by the fresh foods temp. If your garage is let's say 35 degrees, the fresh foods temp will most likely never raise enough to turn the refrigerator on. With the refrigerator never running, the freezer compartment will warm to 35 degrees, resulting in everything melting. Even if garage is a bit warmer, say 45, the refrig will not run long enough for the freezer to maintain a low enough temperture. If the garage temp falls to below freezing, say 20 degrees, the food in the fresh foods compartment will freeze. (outdoor beverage dispensers have internal heaters to prevent product from freezing !) Please don't rate this if not a Fix-Ya for you, as anything else lowers my score.
Jan 22, 2009 | Frigidaire 5 cu. ft. / 142 liter Chest...
GE Monogram ZIC360NRRH Bottom Freezer Refrigerator Logo
35 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
