Question about Refrigerators
My fridge is stuck between the wall.. Trying to get it out but I can't ... Need a solution to get it out??!! Thanks
    Top Expert:
  • Refrigerators Master
  • 12,223 Answers
Use the wd-40 WITH extension for to loose and help wait by 30 minutes and try it.
God bless you
Posted on Jul 13, 2013
  • 2 more comments
  • Isabelle Jul 13, 2013
    Thanks
  • ernesto cuadra
    ernesto cuadra Jul 13, 2013
    o.k
    My only problem there's no gap between the walls :-( have to find a way to slide it out any suggestions most welcome
  • ernesto cuadra
    ernesto cuadra Jul 14, 2013
    use wd-40 and wait 30 minutes. God bless you
Freezer working but not fridge
All cold air in fridge comes from the freezer behind the back wall. I'd first check to see if the fan is running and trying to circulate air to the fridge side. If it isn't then you'll need to replace evaporate fan. Fan is located in freezer behind back wall.
Note: If you have a bunch of snowy frosty ice buildup on the back wall in the freezer then you have a defrost issue and you should hire a professional.
Thanks and gl. Appliance Parts
Feb 04, 2015 | Fisher and Paykel Active Smart E522B...
How to Remove Stuck Refrigerator Jammed Between Countertop and Wall
try removing any panels or covers off the bottom of the front under the doors and then see if you can pull out or lift it from the bottom frame of the fridge. if you can get a rope around the center of the fridge you can maybe pull it forward. Slide the rope up and down the fridge to pull outward from the top and bottom as best you can.
Jun 26, 2012 | Maytag Refrigerators
Alarm sounds on fridge, not cooling
is it a bottom mount machine,freezer on the bottom?if the door doesn't close all the way and the alarm is on this could be your problem,the warm air gets in and freezes up the air ducts.look on the ceiling of the freezer and on the lite,if there's ice or like snow there the door was left open.also check the inside back wall of the freezer,touch it and see if there's any ice or like snow on the inside back wall,you could have a defrost problem or like i said before the door could be stuck open,look for frozen water droplets on your food packages or on the ceiling of the freezer,if so shut down the machine,pull out the food in the freezer and with a hair dryer heat the back inside wall of the freezer for like 15 to 30 minutes,turn it on,if you can feel cold air blowing into the fridge section you should be fine,you might have a package or i've seen people install the door draw in backwards and the alarm will go off because the door isn't closing correctly.let me know what you find and where the alarm is coming from,the freezer or the fridge side.good luck and happy holidays to you.
Dec 23, 2011 | Refrigerators
My fridge keeps freezing things in the fridge
What the most likely thing causing that is that the air damper that opens/closes to let air into the refrig. section is stuck open and too much air is entering into the ref.section allowing things to freeze, that is a fairly common thing with GE refrig's.
To fix that the air damper would need to be replaced..the exact location of it is,upper left corner of the ref. section on the left side wall at the top.
GENE
Sep 06, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
I have the refrig where the freezer is on the bottom, the bottom is working fine but the top is not getting cool.
a common problem with bottom mount freezers is the door gets left open,open the freezer door and look at the ceiling,is there ice on it and is there also frozen water droplets on the packages,if so the door was left open,you can shut the fridge down or unplug it,remove the food from the freezer,get a hair dryer and blow the hot air onto the back inside wall of the freezer mostly blow it into the open slots in the back wall,it will melt the ice that's in the air ducts,you'll see water dripping down,when it stops you can start the fridge and stick your hand in the top middle of the fridge section to feel if cold air is blowing in,all that it does is there's a fan in the freezer,all it does is blow the cold air from the freezer into the fridge section,if the door was open the warm air gets in and mixes with the cold air and it freezes up the air ducts and blocking them.if this isn't the problem open the freezer door,you should hear the fan blowing,if not you could have a bad fan motor,also put your hand on the back inside wall of the freezer,if there's like frost or snow on the back wall you have a defrost problem,a bad defrost heater,defrost thermostat or timer or board depending what the model is,but most of the time the problem is behind the freezer inside wall,or depending on your model there could be a damper in the fridge section,if it's stuck closed then the cold air won't blow into the fridge section.so first open the freezer door,listen for the fan,if it's blowing,check for frozen water droplets and ice up on the ceiling near the light and on the food packages,if you see this the door was left open,if the fan isn't blowing most likely it could be bad,then check the back inside wall for frost or snow on it,if there's frost on the back wall you have a defrost problem,most likely it will be a bad defrost thermostat or heater,you'll need to check them with a maeter,hope this helps,next time send the model number so i can look up your machine.
Sep 04, 2011 | Maytag Refrigerators
I'm looking for schematics for my fridge but can't find any. I just need to know if there are cooling lines running up the side walls of my compact fridge. A simple "yes" or...
You chose the free section so worry about any charge
Yes the condenser colils runs in the side walls and they typically will be warm
Aug 22, 2011 | Refrigerators
Idesit built in fridge, compressor running, fridge doesn't seem to be cold although there is a build up of ice on back wall, happened a couple of times , if i defrost works fine for a while then back...
simple thing first make sure the door is sealing properly, unlikely to be this.
push the back wall of fridge with your hand, it should be solid.
if it is spongey it means the insulation has broken down and you need a new fridge
if not the back wall more than likely a blockage in the system, you will need a pot man out to check the system.
if this is the case and your fridge is over 5 years old dont waste money on repairing, buy a new fridge. if under 5 years def contact indesit company
Jun 19, 2011 | Refrigerators
Fridge is warm, was collecting water inside. Freezer is working fine. Increased temp but not responding. It is a bottom freezer model
send the model number off of the fridge,if the freezer is working fine then no air is being blown up to the fridge section,all it does is blow cold air from the freezer to the fridge section so either the door was left open and this is very common with a bottom mount freezer or the evap fan isn't blowing or on some models there's a damper inside the fridge section,the damper door opens and closes to let cold air in,when it reaches temp. the door closes,sometimes the door gets stuck in the closed position or the open position and the fridge freezes or gets warm depending on where the door is.first thing open the freezer door,do you hear the fan blowing,if not you could have a bad evap. fan motor,next look at the ceiling and on the packages,do you see frozen water droplets,if so the door was left open and the air ducts are froze up from the warm air getting in from the door being open and mixing with the cold air freezes up the air ducts,also stick your hand onto the back inside wall of the freezer,if there's like snow or frost on the inside back wall of the freezer you could have a defrost problem,bad defrost thermostat,heater,timer or board depending on the model or last a bad damper,when you open the fridge door there are air ducts usually up top and in the middle you should feel cold air blowing in,this is your problem the air isn't making it into the fridge section.if the door was left open,unplug the fridge,remove the food from the freezer and with a hair dryer heat up the back inside wall of the freezer and blow the hot air into the air vent holes in the back wall to melt out the air ducts,keep heating it up until you don't see any more water dripping,you can see the water dripping through the vent holes.so let me know what you find,send the model number and we can go from there.look up near the ceiling in the fridge section on the right hand wall and you should see a tag with the model and serial numbers,send the full model number so i can see what you have in your machine.
Jun 12, 2011 | Maytag Refrigerators
I'm unable to set GE Profile Arctica ridge to recommended temp
OK, First let us check the compressor to see if running or trying to start. Pull away from wall and unplug from wall. Remove lower cover and feel the compressor top of the to see if too hot to hold hand there, cool or warm. look inside freezer and tell me if ice is building on rear wall. Answer that and I will be able to tell you what we need to do, Thanks, Sea Breeze
May 06, 2010 | GE Profile PSW26P Stainless Steel Side by...
Casing between fridge and freezer getting very hot
the condenser motor is hung up or has went out ,,, pull fridge from wall and set a fan behind the fridge to blow on system till you can replace the motor / thanks
Jul 07, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
