Question about GPS
Hummingbird 898 gps receiver wire repair...
Can i reconnect GPS receiver wires at PUCK. son pulled wires out
    Top Expert:
  • 12,223 Answers
Yes you can. However you must see if the power cables is o.k and everything is good.try again.
God bless you
Posted on Jul 13, 2013
5 Suggested Answers
  • 20 Answers
SOURCE: kna 4100 gps kenwood
Incidentally, I assume you're talking about the Kenwood KNA-DV4100? Also, I assume this unit has come into your hands through legitimate sources. It is NOT an accusation when I mention that electronic equipment absent of an operator manual CAN have dubious origins. Again, this is NOT an accusation. Rather, it's always good to know where such a unit came from. When an owner's manual is missing, it raises a flag - unless, of course, you know and trust the person selling it to you. At any rate, you can simply download a manual at Kenwood's website, below. Simply copy-and-paste into your internet browser's address bar: http://www.kenwoodusa.com/support/simple.aspx?men=2&M2=69
Posted on Jul 24, 2007
SOURCE: Gqrmin 350 GPS Receiver wont turn on
i have a 350 garmin and it when i put in a name of a place it says no matches found??? how can i fix that???/
Posted on Sep 10, 2008
physicistFL
  • 34 Answers
SOURCE: furuno gps wiring diagram for usb
Hello!
I have the connection diagram for the GPS unit below.  It should be simple to wire up.  You will need a USB to RS-232 converter, which is available in a number of computer shops/Radio Shack.
Hope this helps you out,
Posted on Jan 07, 2009
TechnoMarine
  • 132 Answers
SOURCE: wiring of seatalk instruments
OK, you are confused. Seatalk is a bus system, using 3 wires , (power +, power-, and Data.) red, bare and yellow repectively. So Red and Bare are 12V and ground. Since the 125 shows a green light, it is getting power and outputting data. but is it seatalk?? to make a 125 Seatalk, you must hook red and green together to 12 V, so check that first. if green is grounded or not connected, that is the problem (or one of them)
Next divide system to its' simplest terms, so hook the GPS straight to the display ST60, and see if it works red to rd, yell to yell and bare to bare (sometimes black) One by one hook the others into the chain until they all work or failed device takes down Seatalk network. If you are missing 12V on a seatalk leg, check 5A fuse in course computer. If you have a pilot, you have a course computer, unless it is ST4000 wheel pilot, and then the brain is the display (course computer is built in to ST4000 display)
Posted on Jan 17, 2010
Plugged humminbird ns25 gps antennae to my 898cxi humminbird but no gps signal
The NS25 uses a much different god receiver than what is available now and will not work with your 898. What you will require is a AS GRP receiver. https://www.humminbird.com/Products/AS-GRP/
Source: mikesreelrepair.com & Humminbird.com
Jan 11, 2014 | Humminbird NS25 GPS Receiver
I HAVE A HUMMING BIRD DEPTH FINDER, MODEL HDR610. I WOULD LIKE TO HOOK IT UP TO MY IH HAUL TRANSPONDER. IT IS A COAX CABLE. THE NEW HUMMINGBIRD IS A THREE WIRE CONNECTOR --CAN THIS BE DONE??
Hello
It is not possible to connect. Out three wires comes from Humming Bird, Black one is Negative, Red one is for 12VDC supply and the other is for buzzer. So it cannot be connected with Coax-Cable. OK.
Jul 09, 2011 | Hummingbird GPS
Nuvi® 255W Car GPS Receiver: I received the Garmin nuvi 255W for Christmas but ...
Microsoft Streets &Trips might not recognize your GPS unit. I found that my latest S&T version only recognizes Microsoft's own GPS puck.
May 18, 2010 | Garmin nuvi 255W GPS Receiver
Humminbird Matrix 12 sonar/gps problems
Make sure the 'North Up' is set to 'True' in the settings.
Best of luck
Mike
May 03, 2009 | Hummingbird Humminbird 1155C GPS Receiver
Loosing position on GPS
I hate to be the bearer of bad news, but it sounds like your internal module is on the fritz. I am pretty sure you can buy a external puck and a harness and it will work perfect. I did that with my hummingbird 997.
Apr 29, 2009 | Lowrance Lms 522c 5" Screen Color Internal...
I have a hummingbird matrix 67 gps chartplotter fish finder. It developed a problem with the screen. The outer edges are legible, but the center is damaged. Is it worth repairing. Are there any other...
Hummingbird will refurbish that one for around 150US dollars, better then 500+ for a new one. If the screen is subjected to direct sunlight and heats up it can go out. This is why they discontinued the 67 model and replaced it with the 767.
Apr 21, 2009 | Humminbird MATRIX 67 GPS Receiver
Plenio vxa-2000 antenna pinout
If you are looking at the external connection end with it in a "V" position, on the right - the upper one is green & the lower one is red. On the left - the upper one is yellow & the lower one is black (or the big bunch of copper wires). Be sure you are reconnecting an exact pin set up - an s-video is not the same (unfortunately). If you found a replacement antenna or a correct replacement part, please let me know where. I have to repair mine too.
Oct 27, 2008 | Digital Video Systems Plenio VXA-2000 GPS...
Hummingbird gps ns25
Hi!
here's a user manual/installation manual for your sounder:
NS25
If the depth sounder portion works, I would suspect the settings are off (check first) or the gps circuit needs repair.
Best of luck!
Mike
Sep 02, 2008 | Hummingbird Humminbird 1155C GPS Receiver
Tom Tom GPS X ONe
Any shop that specializes in installing car audio equipment should be able to hard wire the unit to the car's electrical system. Be sure you choose a reputable shop. But be aware - hard wiring may make it possible to see that you have a GPS unit (visible wiring, etc.) and they are very popular items to steal. If a thief were to see any sign you own one, they may break into the vehicle looking for the unit, even if you have taken the unit itself with you. Good luck.
Apr 14, 2008 | Tomtom ONE GPS Receiver
GPS Logo
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
