E301 0001 turn the main power on
    Top Expert:
  • 12,223 Answers
See this steps, use the VOM. God bless you
Make sure there's power getting to the print. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. Sometimes the power cord disconnects or burns at the printe301 0001 - c165ff15-26ea-425b-a263-c3c90075dae2.jpg, if this is the case, the wiring and the terminal block must be repaired or replaced.
Posted on Jul 13, 2013
Error code c4801 For C284e
You may have main board issues. Maybe Try error code reset.
Open front door and locate main power switch on the bottom left and turn off.
Press and hold the reset button , button on control panel.
Turn main power switch back on whilst pressing reset.
after 1 - 2 min a white screen with 1 button saying"error code reset will appear , let goo of reset button.
Press error code reset and then turn main power switch of for 20 seconds. turn main power switch.
If code returns contact me on my phone to discuss
Sep 02, 2014 | Konica Minolta bizhub Office Equipment &...
My canon MF4412 is power on but display is coming turn the main power on E202-0002
my mf4412 printer displaying a problem e202-0002 and red button continue burning
Jun 24, 2012 | Canon Office Equipment & Supplies
Canon MF4412 turn the main power on E000-0000
Apr 18, 2012 | Office Equipment & Supplies
How to connect floor monitor to mixer
You need to connect the speakers using an XLR cable into the Main output jack on the back of the mixer. If they are powered speakers you will need to connect them into a power source and turn them on AFTER connecting them. Once powered on you can control the signal going to the mixer with the Main Mix fader.
  1. Turn mixer on
  2. Ensure Main Mix level is at zero
  3. Connect from Main Output to Monitors
  4. Turn Monitors on
  5. Turn up Main mix to desired level
Sep 14, 2011 | Behringer XENYX 2442FX Mixer
After 5 or 6 copies taken an error E000070-0202 and E000070-0101 will occured. what is the problem
E070 there is an error in the detection of ITB home position
00xx The home position of the intermediate transfer belt is not detected within
a specific period of time .
The ITB HP sensor is faulty.
Turn off the main power, and check the DC controller PCB and the
ITB HP sensor; then, turn on the main power.
01xx The period of time between when the home position of the intermediate
transfer belt is detected and the next home position is detected is longer
than specified .
The presence of a tear may have caused the sensor to wrongly identify it
as indicating the home position.
Turn off the main power, and check the drive of the intermediate
transfer belt; then, turn on the main power.
02xx The period of time between when the home position of the intermediate
transfer belt is detected and when the next home position is detected is
shorter than specified .
The intermediate transfer belt slips on the drive roller, causing a delay in
the timing at which the home position is detected.
Turn off the main power, and check the surface of the intermediate
transfer belt for a tear; then, turn on the main power.
03xx The detection of the home position of the intermediate transfer belt has
failed once.
ITB home position sensor B and ITB home position sensor A must occur
alternately; however, the same state has been detected continuously.
ITB HP sensor; then turn on the main power.
Jun 30, 2010 | Canon imageRUNNER C5800 Copier
Canon iR 3100 CN Fehlercode 000602-0202
Hdd error - call service!!!!
But if you want do something on your own:
A:1) Make the following selections, and enter '1': COPIER>FUNCTION>SYSTEM>CHK-TYPE.
2) Make the following selections, and press the OK key to perform: COPIER>FUNCTION>SYSTEM>HDCHECK*.
3) When done, turn off and then on the main power.
B:
1) Find the appropriate CHK-TYPE from the table 'HDD Format' ; then, make the followingselections, and type: COPIER>FUNCTION>SYSTEM>CHK-TYPE.
2) Make the following selections, and press the OK key to perform: COPIER>FUNCTION>SYSTEM>HD-CLEAR.
C:
1)** Start up the machine in normal mode (i.e., turn on the main power while pressing the 1 and 7 keys ; then, make the following selections, and press the OK key:
COPIER>FUNCTION>SYSTEM>DOWNLOAD).
2) Perform formatting of DOSDEV4 using the Service Support Tool.
D:
1) Replace the main controller (main) board.
2) Remove the image memory (SDRAM) and the boot ROM from the previous board, and attach them on the new board.
E:
1)** Start up the machine in safe mode (i.e., turn on the power while pressing the 2 and 8 keys).
2) Format the HDD (ALL) using the Service Support Tool, and download the system software (SYSTEM, LANG, RUI).
F:
1)** Replace the HDD, and start up the machine in safe mode (i.e., turn on the main power while pressing the 2 and 8 keys).
G:1) Make the following selections, and enter '1': COPIER>FUNCTION>SYSTEM>CHK-TYPE.
H:
1) Turn off the main power; then, turn on the main power while pressing the 1 and 9 keys (so that the machine will automatically start its remedial program*, turning
the control panel solid black).
2) When done (i.e., when the control panel turns white), turn off and then on the main power.
If the machine does not run its remedial program in response to the foregoing step, go to E.
I:
1) Find the appropriate CHK-TYPE in the table "HDD Format"; then, make the following selections and enter CHK-TYPE.
2) Make the selections, and press the OK key to perform: COPIER>FUNCTION>SYSTEM>HD-CHECK*.
J:
1) Make the following selections, and enter '4': OPIER>FUNCTION>SYSTEM>CHK-TYPE.
2) Make the following selections, and press the OK key to perform: COPIER>FUNCTION>SYSTEM>HD-CHECK (1 to 5 min).
* Takes about 30 to 50 min.
** As necessary, ask the user to use the RUI to collect address book data, transfer settings, and user mode settings.
May 09, 2010 | Canon iRC3100 Printer
My main screen Doesn't Turn On
There is a power switch on both units. The second screen will get power if the power switch is turned off on the main unit.
Apr 12, 2010 | TruTech LMD-5702RT Portable DVD Player
Lg 52 in lcd turns off then back on when your
The problem lies either in the power supply or the main board. But most probably it lies in the main board. These boards communicate in switching on the television sequentially. The power supply sends a signal to the main board when AC power is supplied and puts the television on stand-by. When the TV is turned on, the main board sends a switched command to the power supply to deliver it's output for audio and video processing. At the same time it turns on a supply voltage for the backlights.
What probably happened is, the signal sent by the main board to the power supply is being switched on intermittently and causing the turning on and off of your television.
  1. Remove the back cover of the television to check the power supply and the main board. The power supply is the one with transformers on it and located at the center while the main board is the one where inputs are being connected to and located at the lower right back of the television.
  2. Check the power supply for any swollen capacitor.
  3. Turn on the television and check if the LED on the main board flashes as the TV turns on and off.
Please inform me what will you find above and if you can do electronic repairs. Just tell me if you need guidance in replacing parts for your TV.
Jan 03, 2010 | LG Televison & Video
The printer has stopped functioning all together.
C3851: Abnormal Low Temp. (Heater)
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the Main Power Switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
Mar 31, 2009 | Konica Minolta bizhub C250 All-In-One...
jasbo
jasbo
