Hi all I have ricoh af 2045 giving sc 823 plz help with ???
    Problem Solver:
  • 8 Answers
Check exposure lamp cable a nd lamp if not then reset your machine
Posted on Apr 25, 2014
santosj27
  • 263 Answers
SOURCE: IN RICOH AF 2045 SC
This error code could be related to a Physical problem (machine) or Network Problem.
Physical problem:
Try to clean the ID sensor.
Probably you will also need to clean or replace the Drum Unit.
Network problem:
Upgrade your firmware.
(If you do not have technical skills a advise you to call your provider)
See you!
Posted on Jun 06, 2011
Cogz
  • 1326 Answers
SOURCE: ricoh 2045 sc 990 when i fix printer its appear
Did the donner copier have a finisher on it? The code means a miss comunication with the finisher. There is a HD that is used with a finisher. The meter count can not be changed that I know of......The reason it shows 000000 is that the battery was disconnected from the eprom.
Posted on Mar 15, 2009
SOURCE: in rioch 2045bprinter problem
Do you mean that when you install the printer unit you get the error message, and if you remove it it is ok?
"SC990" is a software error. Are you sure it is the proper board? There is a similar model (2045E). Installing that by mistake might make it go into the error...just guessing.
Anyway, the error is a 'software performance error", which could be the hard drive -try unplugging it when you install the printer board to see if it goes away in order isolate the problem.
Posted on Mar 16, 2009
  • 2072 Answers
SOURCE: plz tell me code solution Ricoh Aficio 2045 is
That is an error in the yellow drum charging unit.
You can have an arching yellow charge, a bad contact, etc.
It is the high voltage portion of the yellow drum unit.
Posted on Nov 12, 2010
SOURCE: i have problem in Ricoh AF 2045 SC 990 pl z help
this is software performance error.but this in most cases will appear on life over of either drum or developer.
Posted on Aug 10, 2011
I have an sc 326 error code in my ricoh aficio 2045 copier
If you wish to get some details; check the site linked here. Pull up older posts....
Jun 19, 2016 | Ricoh Aficio 2045e 2035e Copier...
Hai ....am vivek .please help me dears...i have RICOH Aficio 2045 ...it will appears sc 990. What's the solution for this error?? Plz help me ...
SC 990 is software performance error. This means The software attempted to perform an unexpected operation.
Possible causes:
1. Software defective
2.Internal parameter incorrect
3.Insufficient working memory
4.When SC occurs, the file name, address and data will be stored in NV RAM this information can be checked by using SP 7403. Note the above data and situation in which this SC occurs. Then report the data and conditions to your technical control center.
Apr 23, 2013 | Office Equipment & Supplies
kindly change the developer unit and clear the error.
the machine will respond
thank you and all the best
May 20, 2012 | Ricoh Aficio 2045e 2035e Copier...
My printer ricoh 2045 show an error sc 302,not print image correct
i have an error on my printer sc 302 how i can clear it easily .printer is ricoh 3045
Aug 11, 2011 | Ricoh Computers & Internet
I have problem in Ricoh AF 2045 SC 990 pl z help me out from it
Jul 26, 2011 | Ricoh Aficio 2035 Copier
IN RICOH AF 2045 SC 990
Physical problem:
Network problem:
See you!
Jun 06, 2011 | Ricoh Aficio 2035 Copier
Plz tell me code solution Ricoh Aficio 2045 is problem sc 303 code
Nov 10, 2010 | Ricoh Office Equipment & Supplies
Sc990
sc 990 relates to the nv ram chip on the main board also check the values of the lazer unit are correct and not changed
Jun 16, 2010 | Ricoh Aficio 450 Copier
Ricoh 2045 sc 990 when i fix printer its appear
Mar 14, 2009 | Ricoh Aficio 450 Copier
153 people viewed this question
k24674
jasbo
jasbo
