E machines d440 no desplay
I have a laptop e machines d 440 with no desplay......how can i fix it,tried to reset c mos bt no change
    Top Expert:
  • 12,223 Answers
Restart the computer and HOLD the CTRL or FN +f11 or f12 depend of your mark, go to restore factory default and ready
However if the problem persist, take out the small battery lithium inside measure the voltage +3vdc, if the voltage is lower replace, and clean the contact, and put the battery again, and restart and see what happen all data must be restore,since the battery control the memory RAM.
If the problem persist you have a board video/lcd faulty. go to the repair shop for fix it.
God bless you
Posted on Jul 13, 2013
Testimonial: "forgot to say thank u man"
How do I fix a flashing green power light?
Try resetting, by removing the power and powering up again. If that doesn't work, have you got a working BT line? Have you checked the filter?
Sep 26, 2015 | Computers & Internet
Code c 440
Try press number 0 and 8 meanwhile power ON machine. After 3 sec, release the number. Press 2002 > Start > 0 > Enter. Reboot machine. Good Luck
May 17, 2013 | Toshiba E-Studio 456 Copier
What's your problem?eMachines D440-1047 what processor have y which motherboard have plis
Here you can see the specs:
http://support.gateway.com/emachines/notebook/2010/emachines/emd/emd440/eMD440sp2.shtml
Processor = AMD V Series processor V120 (2.20 GHz, 512 KB L2 cache, DDR3 1066 MHz, 25 W)
Chipset = AMD M880G Chipset
Jun 25, 2012 | E-Machines Computers & Internet
ISATAP#17 not running
you have not described you problem in full detail but even i try to solve it. when laptop is in off condition you have to press R + Turn ON button which makes reset (not restore) your C MOS memory so whatever settings has been changed are automatically resets and your laptop will turns ON so just do it. If further problem occurs then immediately call DELL onsite service.
thank you for giving me this opportunity to solve you problem.
Dec 07, 2011 | Dell Inspiron 1720 Notebook
How would you fix an onboard video card
Basically there are 3 possibilities for on board video card failure
1.Hardware,
2.Software and
3.BIOS control
To fix the problem please follow the below steps
1.First of all unplug the power cord to avoid any shocks
2.First reset C MOS , to reset C MOS. Remove the case side panel and using the instructions provided in the motherboard manual, locate the three jumpers used to clear C MOS. Your motherboard will have a jumper shorting two pins usually labeled normal operation. Remove jumper shorting pins one and two, and replace that same jumper on pins two and three
4.Then plug the power and
Your system will not power up. Remove the Clear C MOS jumper from pins two and three, and replace it on pins one and two. Power up System. The system will require you to enter setup and correct the default settings. If clearing C MOS had no effect, you will not see anything on your screen when you power is back up.
If the above did not work then proceed further,
Enter setup, fix the date and time, and you should be in good shape, as most newer computer systems will automatically detect the rest of your setting.
While software driver errors can be fixed, this is something that can only be dealt with if you have some form of video function. If the screen is black, try clearing C MOS, as described above, and otherwise proceed to the next step.
Now the last step is to replace the video card.
Thanks.
Have great day.
Sep 07, 2010 | Acer Aspire™ T180 PC Desktop
Bios password
Bios password can only be reset by removing the c-mos battery....A c-mos battery is a small battery in motherboard, remove it and then replace it again..dat will reset ur bios password..
Jul 05, 2009 | Dell Latitude ATG D630 Laptop
My N73 is hanging
1 reduce applications installed on phone memory
if the prblm is still there, then
master reset ur cell...
bt before that,
take backup of ur contacts and messages...
then press *#7370#
and then the security code of the cell (12345 by default, if u havent changed it.)
May 01, 2009 | Nokia N73 Cellular Phone
Cd change will not work
Power Antenna Wire hooked up as amp turn on. Switch the blue wires around.
Dec 21, 2008 | Sony XR-M510 Cassette Player
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
