Question about GE Dishwashers
GE dishwasher inlet valve leaking
There is a steady drip underneath that looks to be coming from around the inlet valve.I turned off the water supply and it's still dripping. Even tried turning off the main supply and it still dripped.I could fit a flat container under it and empty about a cup of water every 1/2 hour. How can it still drip if there is no water supply? Please help, I'm a widow and can't afford a repairman right now, i just want to avoid any more damage to my floor--it's already starting to buckle next to the dishwasher.My email is jmills1907@comcast.net Thank you.
    Top Expert:
  • GE Master
  • 12,223 Answers
See this steps and fix it. God bless you
Dishwasher Not Leveled
This is a very common reason for a leaking dishwasher especially if this was a new installation. The framing in a dishwasher is made up of mostly thin sheet metal, so if it is not sitting flat and level things can get distorted very easily.
Door Seal
This is not very common in most dishwashers. To check this look for rips and distortion of the seal. If it is ripped or distorted you will need to replace.
Dispenser Seal
This is a more common place for a leak to develop. This is easy to check, remove the front panel and carefully inspect around the seal for water dripping or stainage. If any is found replace the dispenser gasket.
Water Inlet Valve
Usually it is the connection to the water inlet valve that ends up leaking. Check this connection ( there is usually some sort of adaptor between the valve and supply hose) for leaks. Check the connection on the back of the water inlet valve also. Ocassionaly a water inlet valve will leak around the solenoid in this case replace water inlet valve.
Drain / Circulating Pump
Some dishwashers have separate drain and circulating pumps Some use one pump to serve both purposes. In either case you will need to check the housings for leaks along with all the connections. Some dishwashers have a seal that leaks down into the pump . This is easy and inexpensive to replace. Follow the tutorial on replacing the pump
Door Latch
The door latch can become loose or misalinged. Check both the striker and the latch. To adjust the latch you will need to remove the front panel and adjust the switch until properly aligned.
Door Hinges
They can cause problems, but this usually only happens from opening a heavy load of dishes on the door. Occassionaly a broken spring or cable occurs. You will need to remove the toe kick and maybe the front panel to inspect.
Posted on Jul 13, 2013
catriver
  • 878 Answers
SOURCE: Leak off pump housing
Sidewinder, sounds like it's leaking from the pump gasket or the water seal assy on the impeller. Check the locking ring to the pump housing and see if you can increse the pressure to the tub. Also check the tightness of the motor fan assy. to the impeller assy. tighten if necessary. Pump gasket part number is 912529. Impeller seal part number is 903494. Catriver..post back.
Posted on Oct 23, 2006
SOURCE: Fisher and Paykel Dishwasher 913T
i need to by new electronic control off fisher&paykel
model 913T please can you tell me how much is it
thak you.
Posted on Jun 08, 2008
  • 1462 Answers
SOURCE: Our asko dishwasher won't stop
you have a leak. only way forward is to take of the panels and look for it
Posted on Oct 01, 2008
huuum
  • 750 Answers
SOURCE: FRIGIDAIRE DISHWASHER FDB1050REC0 LEAKS UNDERNEATH
There are a couple reasons water may be leaking out the door of a dishwasher.
1. The water is most likely coming out the bottom of the door where there is no rubber seal.
2. The rubber seal is around the door jam on top and both sides and not on the bottom. This means if the dishwasher has to much detergent in it the soap suds push only the water higher than the front edge of the wash basin and out the bottom of the door where there is no seal!
3. Fill only the soap cup that can close for the secondary wash. The open cup is a pre-wash and mostly not needed unless the food is baked on.This just wastes money to fill both of them every time.
4. And if you are using liquid detergent you only need half the amount from the powdered soap!
try less soap. Remember to much soap too can cause the water overflow.
5. And the last would be that the drain is clogged and caused a back up large or small and then the overflow!
is there water in the bottom when the wash is done?
Soap is usually the culprit, not that there can't be a leak in an old drain or water supply hose!
Go with the soap idea first!
Let me know how you are!
How old is the washer ?
Please remember to leave a rating before you go!
Thank You ,Huuum
Posted on Oct 03, 2008
gamerfixer07
  • 344 Answers
SOURCE: Dishwasher tub leaks underneath
Hello. Anything is worth trying! But I would recommend epoxy. It works alot better with plastic and rubber items. Most of the leaks I have found in Kenmore machines are at the water pump. You may want to take a peek while it's running, just stay away from the wires!! Thanks!
Posted on Jan 18, 2009
Miele G2020 leaking 2 spots help
please follow this steps and fix it. God bless you
This is a very common reason for a leaking dishwasher especially if this was a new installation. The framing in a dishwasher is made up of mostly thin sheet metal, so if it is not sitting flat and level things can get distorted very easily.f3a0b0dc-c8b0-4678-bccb-f94392039827.gif
Door Seal
Dispenser Seal
Water Inlet Valve
Usually it is the connection to the water inlet valve that ends up leaking. Check this connection ( there is usually some sort of adaptor between the valve and supply hose) for leaks. Check the connection on the back of the water inlet valve also. Ocassionaly a water inlet valve will leak around the solenoid in this case replace the water inlet valve.
Some dishwashers have separate drain and circulating pumps Some use one pump to serve both purposes. In either case you will need to check the housings for leaks along with all the connections. Some dishwashers have a seal that leaks down into the pump . This is easy and inexpensive to replace. Follow the tutorial on replacing the pump.
Door Latch
The door latch can become loose or misalinged. Check both the striker and the latch. To adjust the latch you will need to remove the front panel and adjust switch until properly aligned.
Door Hinges
They can cause problems, but this usually only happens from opening a heavy load of dishes on the door. Occassionaly a broken spring or cable occurs. You will need to remove the tow kick and maybe the front panel to inspect.
Jun 14, 2013 | Miele Dishwashers
GE Profile Dishwasher leaking from the bottom
If your dishwasher is Leaking check the following
Door Seal
Dispenser Seal
This is a more common place for a leak to develop. This is easy to check, remove the front panel and carefully inspect around the seal for water dripping or stainage. If any is found replace the dispensergasket.
Water Inlet Valve
Usually it is the connection to the water inlet valve that ends up leaking. Check this connection ( there is usually some sort of adaptor between the valve and supply hose) for leaks. Check the connection on the back of the water inlet valve also. Ocassionaly a water inlet valve will leak around the solenoid in this case reokace inlet valve
Some dishwashers have separate drain and circulating pump. Some use one pump to serve both purposes. In either case you will need to check the housings for leaks along with all the connections. Some dishwashers have a seal that leaks down into the pump . This is easy and inexpensive to replace.
Door Latch
Door Hinges
Use the VOM. God bless you
Apr 05, 2013 | GE 24 in. Profile PDW7800 Built-in...
Dishwasher leaks after I cleaned the air pump
This is a very common reason for a leaking dishwasher especially if this was a new installation. The framing in a dishwasher is made up of mostly thin sheet metal, so if it is not sitting flat and level things can get distorted very easily. Watch the video on leveling your dishwasher
Door Seal
Dispenser Seal
Water Inlet Valve
Usually it is the connection to the water inlet valve that ends up leaking. Check this connection ( there is usually some sort of adaptor between the valve and supply hose) for leaks. Check the connection on the back of the water inlet valve also. Ocassionaly a water inlet valve will leak around the solenoid in this case replace the inlet valve water
Door Latch
The door latched can become loose or misalinged. Check both the striker and the latch. To adjust the latch you will need to remove the front panel and adjust switch until properly aligned.
Door Hinges
Use the VOM, God bless you76c7517c-e034-47da-bf6c-02b58ecb7551.jpg6274586f-de4d-45f0-bbab-ada21592e251.gif
Apr 05, 2013 | GE Profile PDW8400J Built-in Dishwasher
I have a side by side GE refrigerator and the water dispenser is leaking quite a bit. It looks like is leaks where the water is dispensed.
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
Oct 31, 2009 | GE Profile PSW26P Stainless Steel Side by...
Water leaking out of ice maker area
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Oct 16, 2009 | GE Refrigerators
TFC27ZFS GE frig will dispense water then continue to leak water and doesn't stop?
Sep 24, 2009 | Refrigerators
Ice maker leaking inside freezer compartment, water dripping down from unit
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
Sep 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
IWater Leak from LG12225FD Washing machine
may be pump...hose seal... in outer tub...cracked inlet valve cracked hose inlet to tub
Aug 17, 2009 | Washing Machines
Leaking dishwasher
If your dishwasher leaks, check these:Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
1. Lower rack
2. Spray arm
3. Spray arm support
4. Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
thanks for using FixYa
Feb 05, 2009 | Frigidaire 24 in. PLD2850 Built-in...
We have a GE Dishwasher Model # GSD 2000 Z02AD - water leaks
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
1. Lower rack
2. Spray arm
Door gasket or seal
Water-inlet valve
Hoses
Jan 06, 2009 | GE 24 in. GSD2230Z Built-in Dishwasher
Dishwashers Logo
127 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
