Question about LG Heating & Cooling
LG Lsk244v-3
Will not run at all... Hot or cold mode. Upon start up the display comes on, vents open.. No fan start up, vents shut.. Green light flashes 6 times.....flashes 6 times....etc etc. at this point, the remote is rendered useless until I go out to the fuse box and reset at the breaker. Then it all happens again. I'm an automotive A/C techy so I have some idea with it all..( but not much!). Surely the fault code of 6 green flashes means one thing and one thing only?? I've found plenty of opinions online but there must be one that LG specifies.(whether that counts for anything is another thing, experience wins out over books every time!) can anyone hare their experience with me? My wife is killin me!!
    Top Expert:
  • LG Master
  • 12,223 Answers
You must reset the c.breaker from you panel house, and try again.
If the problem persist, replace the battery from r.control and try again. TURN ON manually, and see what happening. If turn on again, is o.k.
If the problem persist the control board inside is faulty .call some electrician or tech for help
God bless you
Posted on Jul 13, 2013
Therinnaiguy
  • 1420 Answers
SOURCE: LG split system air conditionsr
3 flases indicates a communication error. Have a technician check wiring and connections.
Posted on Aug 30, 2007
bobotfel
  • 236 Answers
SOURCE: green light flashes 3 times will not operate
Its may be the thermistor is defective or out of range or the board itself, the unit will not operate unless the defective part is not replace.
Posted on Mar 09, 2008
  • 1894 Answers
SOURCE: Daikin heat pump, turn it
just try leaving the unit plugged off from the main power for few hours.
then try switching ON.
Posted on Jun 29, 2008
  • 400 Answers
SOURCE: LG Inverter A/C Unit LSJ092V-3
I would first check the condensate drain pipe. This can be done by blowing back into the drainpipe from outside. Not to worry it is not dirty or dangerous. Also make sure that your air filters are clean.
Posted on Mar 05, 2009
kingbrizzle
  • 407 Answers
SOURCE: Carrrier Central heat and air. Model 38CKC042300,
Unfortunately no, this is one of three things.
1. Compressor is worn and is starting to pull to many amps to operate. Can possibly be fixed by putting a hard start kit on the unit, but will have to be done by a technician.
2. Compressor has an internal short and will have to be replaced.
3. Fuses bad or under sized. Max fuse size is stated on information plate on outside unit.
Sorry to hear about your troubles and hope you can get it fixed soon!
Posted on Aug 15, 2010
My electric furnace constantly runs.. no cold or hot air blowing through the vents.. red LED light blinks 4 times saying limit switch open.. how do I fix the problem?
You'll need to replace the fan limit switch. This little switch is what tells your blower when to kick on and when to shut off. It's stuck open.
Mar 05, 2015 | Heating & Cooling
Where is thermostat located on ge dryer,starts hot then it gets cool
Dryer possibly overheating due to plugged vent. They will go into a safe mode and shutdown the heater if not enough airflow. Results in starting hot but ending with a cold load of clothes! Check the belt to ensure the dryer fan is working and that the drum is properly rotating. If OK and the vent is clear then check the thermostat. Depengin on the type (Gas vs electric) there are a number of limit thermostats as well as a main thermostat. Likely you have a a limit switch kicking in to shut off the heater. Normally from lack of airflow (plugged vent, fan broken, etc...) Once unit cools down will start back up but shut down again once the heater comes on. Also check to see if the heating element is shorted to the side of the metal case. Will heat up and be intermittent.
Jun 10, 2014 | Dryers
Keeps shutting down and takes several trys to start again only to shut down later
If the computer is overheating it will shut down to save the hardware from heat damage, the temp is pre set. It may get hot, due to air flow in a minute or and hour. What does the "screen comes up says problem " say? Check the fan and vents for dust and clean, improve air flow around bottom vents and side vents. Perhaps a Laptop Cooler? When the computer shuts down unepectedly, the computer see it as a crash and will load in that option screen. Run a 'Check Disk" on the OS drive buy opening computer in start menu, right click the drive with the OS (C), open properties, Tools, Check now, choose all options, follow instructions, reboot.
Nov 18, 2012 | Computers & Internet
ACER ASPIRE X1200 Unexpected Shutdown
When does it shut down? Are you able to use it at all? Or does it shut down when you are trying to boot it up?
When it shuts down are you able to boot it right back up and start using it? If not, it might be running hot. If you let it sit a while to cool off then try booting and if you are successful, then it is definitely running hot.
Three things that will make a computer run hot.
1. Dust - Dust inside the computer, dust clogging the vents and fans. Dust around the cpu and heat sink. To fix, Remove the power cord, remove the case and take a can of compress air to blow out the dust.
2. A fan is not working. Make sure the fan inside the Power supply and the fan that sits on top of the cpu is working. Normally the system will notify you if the fan is not working. To fix, you will have to replace a fan that is not working.
3. The Thermal Paste around the CPU and Heat Sink has dried up or is too thin to keep the unit cool. To fix, apply a fresh coat of Thermal Paste around the cpu and heat sink.
Maybe you have a virus or infection that is shutting you down if it is not running hot and you are allowed to work on the computer for a while before it shuts down. Boot the System in Safe Mode and see if it shuts down.
Turn off the computer, then hit the power button to turn it back on and immediately start hitting the F8 key repeatedly until you see SAFE MODE. Take the Safe Mode With Networking option (this will give you internet connectivity) and let it boot up. Safe Mode will look different to you, the screen will be darker and the icons bigger, this is normal. Download and install MalwareBytes and run a Quick Scan.
Go to www.google.com and in the search box type: "Download cnet Malwarebytes" (without the quotes). Download and install malwarebytes from the sites download.cnet/malwarebytes. When the site opens up click on the Green Download button on the left. Do not click the Red Download button, that's junk. When it finishes installing the Gui Interface will open up with an offer to Accept a Trial Version or Decline. CLICK DECLINE you want the totally free version. Run a QUICK SCAN. As it scans, if it finds infections the number will be in red. When it finishes scanning, click SHOW RESULTS. A notepad text document will open up showing you the results. You can close the text document and go back to the Gui Interface where you will click REMOVE SELECTED RESULTS. The objects will already be selected for you. When it finishes removing the objects click ok and it will sometimes reboot your machine.
May 24, 2012 | Acer Computers & Internet
On a little load ups turn off with in 3 minutes
Are you getting it to load up to windows completely? If so and it shuts off withing 3 minutes maybe you have a virus or infection.
Try booting up into Safe Mode to see if it shuts off or stays on.
Turn off the computer, then hit the power button to turn it back on and immediately start hitting the F8 key repeatedly until you see SAFE MODE. Take the Safe Mode With Networking option (this will give you internet connectivity) and let it boot up. Safe Mode will look different to you, the screen will be darker and the icons bigger, this is normal. Open your internet browser and download and install MalwareBytes.
If you machine still shuts off after 3 minutes maybe it is running hot.
3 things that cause a computer to run hot.
1. Dust, dust in the vents, dust around the fans, cpu and heatsink.
2. A fan that is not working
3. The Thermal Paste around the Cpu and Heatsink has dried up or is too thin to keep the unit cool.
One sign of a computer overheating is to turn it back on immediately after it shuts off. if it will not power back up and stay on then it is running hot. If you let it sit a while then turn it back on and you are successful, then it was running hot.
Apr 28, 2012 | Computers & Internet
I have a 12/2 (black/white/ground) power source to the leviton 1755 switch. And, I have two (2) 12/2's going to a Broan 100hl (vent, light, heater). Please help wiring switch and Broan; on...
The switch that you have works like 3 seperate switches. most of these switches will have gold screws
on one side and silver screws on the other side, lets say that the left is gold and the right is silver, and
the switch may also have a green screw for ground. your 12/2 with ground is your main hot, you may
want to mark it with a piece of tape, so you know it's the incoming hot. the ground off your hot will tie,
to the green screw on switch and continue and tie to your vent light which should also have a ground
the white coming off the hot is your neutral, it will go straight to your white or whites on your heater.
the black hot wire at your switch will go to each gold terminal on one side of the switch,there are two
ways you can do this, go to one side and just run a jumper, or put one wire on each gold screw and
tie in to your hot-black wire with a wire nut. now for the switch legs, you will need to run from your, switch
to your heater either another pair of 12/2s or a 12/3, each side of the switch that has one silver screw,
it's easier with a 12/3 normally a 12/3 will have a red,black,white,and ground.
top switch red to red on heater,black to black on light and the white blue on the vent,so from your switch
to the heater you would have to run a12/2 you would not use the black only the white and ground.
remember the white-neutral coming from the switch will be tied to all the whites at the vent,light,heater
except for the 10/3. the 10/3 is used stricktly for the switch legs. good luck!
Jul 09, 2011 | Leviton 1755 Triple Rocker Switch Decora
I have an Amana Refrigerator. It is a double door on top and a pull out freezer on the bottom. The freezer is working fine. The refrigerator light comes on but it is not cold and my fresh food is fading...
either the evaporator fan in the damper vent door isnt running to push cold air from the freezer up into the refrige compartment or the damper vent door between the freezer and refrige section is frozen shut and cannot open to allow cold air flow,you need to access the evaporartor coil in the freezer rear wall and check both the fan and door movement
Mar 22, 2011 | Amana Refrigerators
Fan motor does not blow hot or cold air when turned on
your fan motor is located on firewall behind engine towards middle of car under a cover gain acess turn fan on inside car lightly tap back of motor if fan starts running you have a bad fan motor i assume you have already checked your fuses
Mar 16, 2010 | 1999 Cadillac Eldorado
2003 buick lesabre AC problem
You have to find the motor that controls the blend door and open it manually to find out which one is bad there are 3 blend doors on the HV/AC system one will be where the heater core is. The other will be between the vented air and AC? heating system then the third door will operate vents in dash and defrost condition. If you have someone operate them AC system heating system and watch the blend door motors, the one you find not moving will be the one that has the problem. They have vacuum and electrical motors, if it is a acuum motor you can move the door manually with your hand, if it's electric you will have to disconnect the rod by removing the pinch clip off of the rod.
Jul 10, 2009 | 2003 Buick LeSabre
LG PTAC acting strange in heat mode
I believe the problem in lies in the dual stage heat mode setup on the thermostat, but the unit going into defrost does make the unit act kinda strange. Even more so than other types of equipment. I would suggest hiring a licensed HVAC service technician if the problem cannot be resolved by yourself.
Dec 15, 2008 | LG LP120HED Wall/Window Air Conditioner
Heating & Cooling Logo
91 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
