Question about Acer Computers & Internet
Label format computer on but later after auto off why
    Top Expert:
  • 12,223 Answers
Restart the computer HOLD the keys CTRL or FN +f11 or f12 depen of you mark, and go to restore the factory default, can be fix it.
However if the problem persisT, Run the software diagnostic coming with the computer, or download from you ACER supplier and test it. or get support via ONLINE chat.
God bless you
Posted on Jul 13, 2013
Have a furuno fr240 mark 2 and rafar image return only when changing range. also when given time image slowly returns but later radar dies. what problem can it be?
Of course this could be many things, but it sounds like your auto clutter < labeled by Furuno as AC Sea Auto, is on and out of adjustment. Try turning off auto sea clutter and manually declutter the screen, should help, otherwise, 847-746-0100 will definately help you.
John
Jun 11, 2014 | Furuno 2.2kw 18" Radome
Memory card 1GB volume label
My Computer. Right click Format > Volume Label.
My Computer. Right click Properties > Volume Label.
Start > Run / Search. Type cmd ENTER. Type label x: [name] x being the drive letter.
Nov 05, 2012 | SanDisk 1GB microSD Memory Card
It print half of a label, then stop with the eror light on, can u help me?
Hold in the Feed button for 4-5 seconds, which causes the printer to attempt to "Auto-calibrate." If that doesn't solve it, then slide out the Media Sensor (green plastic bar that sticks out over the labels) about 1 inch from all the way in ("in" = left if looking from front). Then press Feed to clear errors. If still get same error, then look for piece of label or ribbon stuck in that error - ok to blow out with canned air. Then try holding in Feed again for 4-5 seconds to Auto-calibrate again.
Oct 11, 2012 | Datamax M-Class Thermal Printer
Dimensions needed for Crystal Reports Avery - J8159
I believe you'll find all the necessary dimensions listed here:
http://www.red-bean.com/labelnation/label-dimensions.html
Jan 13, 2018 | Avery Computers & Internet
Where is the auto convergence button
Hello
From it menu option, suf through and come to automatic convergence display option and press Ok button on the remote control.
The List & Labels part of the setup lets you edit your channel list and choose or create a
personal six-character label for each channel.
Note: Changing List and Labels can be time consuming. You can change these at a later time by accessing the
Setup menu.
1. Press the left or right arrow to scroll through the available channels and choose the
channel you want to edit.
2. Press the down arrow to highlight the In channel list option. Press the left or right arrow
button to add (the box is checked) or remove (the box is unchecked) the channel from the
list.
3. Press the down arrow to highlight the Channel label option. Press the left or right arrow
button to scroll through the available list of 25 most common labels. The last option in
the list allows you to create your own six-character label for the channel (the first letter of
the label is highlighted).
4. Press the 1 or 2 number button to change the first letter of the label.
5. Press the right arrow to highlight the second letter, then press the 1 or 2 number button
to change the second letter, etc...
6. When you are finished creating your label, press OK. For model D34W20, your TV tunes to
the last channel available in your channel list. For models D40W20 and D52W20 only, the
Auto Convergence menu appears next.
Auto Convergence (for models D40W20 and D52W20 only)
Your TV's picture tubes might have been disturbed during delivery or after you moved the TV,
causing the color in your TV to be out of alignment. The colors adjust by starting auto
convergence.
1. Press OK to begin auto convergence.
2. When the auto convergence is complete, the Red center convergence menu appears. The
cross in the middle of the screen should be yellow. If it is not, use the arrow buttons to
move the red cross to overlap the green cross. Press OK when adjustments are complete.
3. The Blue center convergence menu appears with a cyan cross in the middle of the screen. If
it is not, use the arrow buttons to move the blue cross to overlap the green cross. Press OK
(the TV tunes to the last available channel in the channel list).
Ok
Mar 16, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Cannot format octagon veridisk T118 usb
Try this
Microsoft Windows 95, 98, ME syntax
Formats a disk for use with MS-DOS.
FORMAT drive: [/V[:label]] [/Q] [/F:size] [/B | /S] [/C]
FORMAT drive: [/V[:label]] [/Q] [/T:tracks /N:sectors] [/B | /S] [/C]
FORMAT drive: [/V[:label]] [/Q] [/1] [/4] [/B | /S] [/C]
FORMAT drive: [/Q] [/1] [/4] [/8] [/B | /S] [/C]
/V[:label] Specifies the volume label. /Q Performs a quick format. /F:size Specifies the size of the floppy disk to format (such as 160, 180, 320, 360, 720, 1.2, 1.44, 2.88). /B Allocates space on the formatted disk for system files. /S Copies system files to the formatted disk. /T:tracks Specifies the number of tracks per disk side. /N:sectors Specifies the number of sectors per track. /1 Formats a single side of a floppy disk. /4 Formats a 5.25-inch 360K floppy disk in a high-density drive. /8 Formats eight sectors per track. /C Tests clusters that are currently marked "bad." Microsoft Windows 2000 and Windows XP syntax
Formats a disk for use with Windows 2000.
FORMAT volume [/FS:file-system] [/V:label] [/Q] [/A:size] [/C] [/X]
FORMAT volume [/V:label] [/Q] [/F:size]
FORMAT volume [/V:label] [/Q] [/T:tracks /N:sectors]
FORMAT volume [/V:label] [/Q] [/1] [/4]
FORMAT volume [/Q] [/1] [/4] [/8]
volume Specifies the drive letter (followed by a colon), mount point, or volume name. /FS:filesystem Specifies the type of the file system (FAT, FAT32, or NTFS). /V:label Specifies the volume label. /Q Performs a quick format. /C Files created on the new volume will be compressed by default. /X Forces the volume to dismount first if necessary. All opened handles to the volume would no longer be valid. /A:size Overrides the default allocation unit size. Default settings are strongly recommended for general use.
NTFS supports 512, 1024, 2048, 4096, 8192, 16K, 32K, 64K.
FAT supports 512, 1024, 2048, 4096, 8192, 16K, 32K, 64K, (128K, 256K for sector size > 512 bytes).
FAT32 supports 512, 1024, 2048, 4096, 8192, 16K, 32K, 64K, (128K, 256K for sector size > 512 bytes). Note that the FAT and FAT32 files systems impose the below restrictions on the number of clusters on a volume:
FAT: Number of clusters <= 65526 FAT32: 65526 < Number of clusters < 268435446
Format will immediately stop processing if it decides that the above requirements cannot be met using the specified cluster size.
NTFS compression is not supported for allocation unit sizes above 4096.
/F:size Specifies the size of the floppy disk to format (160,
180, 320, 360, 640, 720, 1.2, 1.23, 1.44, 2.88, or 20.8). /T:tracks Specifies the number of tracks per disk side. /N:sectors Specifies the number of sectors per track. /1 Formats a single side of a floppy disk. /4 Formats a 5.25-inch 360K floppy disk in a high-density drive. /8 Formats eight sectors per track. Microsoft Windows 2000 and Windows XP recovery console syntax
format [drive:] [/q] [/fs:file-system]
drive: Specifies the drive to format. /q Performs a quick format. /fs:file-system Specifies the file system to use (FAT, FAT32, or NTFS) Examples
When using the format command, remember all information on the drive you wish to format will be completely erased.
format a:
Would erase all the contents off a disk. Commonly used on a diskette that has not been formatted or on a diskette you wish to erase.
format a: /q
Quickly erases all the contents of a floppy diskette. Commonly used to quickly erase all information on the diskette.
format c:
This would erase all the contents of your C: hard disk drive. In other words, unless you wish to erase all your computer's information, this command should not be done unless you're planning to start over.
Or
Right click My Computer-->Manage-->then go to Disk Management
and select the to format right-click it and click format. Thats it Your drive will format and You can also choose in which file system you want to format your drive.
For further help or to thank me mail me on my email ejaz89@live.com
Aug 06, 2010 | Computers & Internet
I loaded some pictures in my touchmate neno mp4 player then connected the cord to another computer to send the pictures there. then i deleted the pictures,other songs and videos.somedays later i noticed...
Try to do the following and see if it work..
steps:
1.plug your pen drive in your computer.
2.then open Control panel.
3. open administrative tools.
4.open Computer Management
5. a window label computer management will appear.
6. click disk management
7.locate you pen-drive and select delete partition or format it fat 32 or other format convenient for your usage.
ok
hope this will help
cheers
uttam
Jan 21, 2010 | Audiovox MP4128 MP3 Player
Amt mp3 not working due to formatting.( Look like apple ipod 1 gb
It is alone to format in FAT32 and later in FAT, and tries to transfer musics again.
Apr 21, 2009 | AMT Datasouth Datasouth FASTMARK 4602...
Label text too far down on label, overflows to next label
vista might be a problem,
try this, try to install hp deskjet 990c from add printer in control panel ,
frist select the manufacturer as hp and after that select the model ,
try printing with this printer ok
Mar 20, 2008 | HP Officejet 5610 All-In-One InkJet...
What's volume label
when i go to format my mp3 it say windows can not complete format plz help.
Feb 11, 2008 | Audio Players & Recorders
Computers & Internet Logo
15 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
