Question about Nokia Lands Phones
Problem imei corrupt and restart after 30seconds
Problem details... (optional)
Imei corrupted
Is that an error you get? Best to contact the point of purchase for options.
Mark
Motorola Support
Apr 16, 2014 | Motorola RAZR Cell Phones
see this steps and fix it. God bless you
Restart iPhone
Sometimes all it takes is a restart for the iPhone to become responsive again. To restart your iPhone when it is unresponsive, press and hold the sleep/wake and home buttons until the Apple logo appears (~10 seconds).
Very low battery
It is possible for an iPhone to become unresponsive if the battery drops to an extremely low level. Plug the iPhone into your computer or wall charger and allow it to charge for at least 20 minutes before using it again.
The IC regulator power supply inside can be Short, go to repair.
IMEI nothing to see with the problem.
Jul 13, 2013 | Nokia Lands Phones
NOKIA 101 SECURITY CODE FORGOT, IMEI-1, 359069046790244, IMEI-2, 359069046790251
NOKIA 101 SECURITY CODE FORGOT, IMEI-1, 359737046783746, IMEI-2, 359737046783753
Oct 27, 2011 | Cell Phones
My nokia 5800 has corrupted imei no wht to do
when i flash my nokia 5800 then imei number is changed and phone will restart after two r three minute .now imei is 12345610654321?. give me good solution plz
Jan 10, 2011 | Nokia 5800 XpressMusic Smartphone
Why can i only watch about 30seconds and then it loads forever... this is for you tube ...i go to watch a video and never able to see the whole thing....watch for up to 30seconds then freeze and loading
1. Watch videos at off peak times, if possible
2. Do not run other programs while watching videos. They slow down computer in general by making use of memory.
3. Add RAM on your computer. More RAM will make easy execution of heavy programs on your system.
4. Get better and speedy internet connection. Talk to your ISP in this regard.
5. Regularly clean windows registry. Windows registry is vital place that stores information for important computing functions. A congested or corrupted windows registry makes computer slow that causes YouTube like freezes. For this, get the best registry cleaner reg in out and optimizer. Use it once in a fortnight for fast computing to avoid YouTube freezes and system slow down.
Dec 22, 2010 | YouTube Videos
It turns alone and have to restart by main svish
type *#06# ,if it display an 123456.......... IMEI .it is an RPL problem and your phone serial number is corrupted
Jun 05, 2010 | Nokia 6288 Cellular Phone
Hi a have to HP dc5800 minitower itgoes in windows logo few econd after i restart the hole pc agaian. Can someone help with this
So after the windows logo shows...the pc restarts? Sounds like it might be bluescreening. Could be bad memory or some other type of hardware issue. Hard to say without more detail but you may want to try booting it into safe mode but repeatidly hitting the F8 key until it gives you the bootup options DOS screen. Choose boot to safe mode and see if it does this successfully. If so...could be a corrupted application or bad third party hardware like a usb device or sound card.
Nov 19, 2009 | Computers & Internet
Win xp log on failed
to avoid this problem you run in safe mode option to your system.to run in safe mode follow the step...
restart the system and then press on start F8 key from keyboard then choose safe mode option...
your windows has corrupted.
so you can also restore the system in previous date.....further detail on live chat
Apr 14, 2009 | Microsoft Windows XP Home Edition
Missing or corrupt
HI,
You canrecovery the MIssing file, by installing the OS
Don't go for installation ,give Repair the option
when you boot up the Lpatop,
press either F2 or Del, this will get you into the cmos settings, navigate to advanced cmos settings and normally at the top line is the boot sequence which will say HDD, press either up/down keys or + - keys to change to cdrom as first boot device, save settings and exit.
Insert you cd rom before the system boots into windows and the option prompting you to press enter to boot from cd will appear for 30seconds.
ok---enter---repair-- in this option it will recover the missing files.
May 19, 2008 | Toshiba Satellite M55-S3512 Notebook
I need lock code number
the default code is 12345,if not,then we can reset your phone code.just follow this simple steps..press and hold the following,power button,no.3,*send button,hold this buttons for about 30seconds...hope it will your problem....
Jan 30, 2008 | Nokia N73 Cellular Phone
Lands Phones Logo
12 people viewed this question
Top Nokia Lands Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
Are you a Nokia Lands Phone Expert? Answer questions, earn points and help others
