Question about Sharp AR-M207 All-In-One Laser Printer
Showing remove paper from output tray
What is the solution
    Problem Solver:
  • 7 Answers
Hi. youre paper is jam. you have close paper in try.1- opern ther try2-remove paper jam
Posted on Jul 13, 2013
Paper outray is showing closed however its open, in Canon mp287 printer
For Paper Output Tray error
Paper may be jammed. Remove the jammed paper, reload paper properly in the printer, then press the Black or Color button.
or
look for buttons or such things on the part that has blue rectangle below.. check inside if theres piece of paper or any object.
Jan 30, 2015 | Canon Office Equipment & Supplies
How do I remove paper tray
Instructions
Grasp the front of the output tray located beneath the control panel. Remove the output tray by lifting the front of the tray up and pulling the tray out. Set the output tray aside.
Read more: How to Load Paper into an HP Officejet All-in-One Printer ' eHow.com http://www.ehow.com/how_4489317_load-paper-hp-officejet-allinone.html#ixzz2NjlQ4lhl
Mar 16, 2013 | HP Officejet Pro L7580 All-In-One InkJet...
Canon printer mx328 is when i scan it display ''the paper output tray'' what mean and how to clean it. Please help.
Hi
If the Paper Output Tray is closed, open it. The machine resumes scanning.If opening the Paper Output Tray does not resolve the problem, or if the tray was open to begin with, the paper may be jammed. Remove the jammed paper, reload paper properly in the printer, then press the Black or Color button.
Cheer
Jul 12, 2011 | Canon PIXMA MX310 All-In-One Printer
My copier keeps showing an error: remove paper from output tray but there isn't any paper there? How do I proceed?
on the output tray you will see sensor flapper... it can get stuck ed... try to manually lift or down it, it usually gets out of his holder.
Keep me posted,
Hope that help's!
Nov 18, 2010 | Canon imageRUNNER 4570 Copier
What does e073 0003 error mean on canon 1180.
E, 0, 7
FINE Cartridge is not installed in the correct position
E, 0, 3
Paper Output Tray is closed / Paper jam
Summary
If the Paper Output Tray is closed, open it. The machine resumes printing.
E, 0, 3
Summary
Techbelkin please rate me
Nov 03, 2010 | Office Equipment & Supplies
Error e03, but there is no jammed paper
E, 0, 3
Summary
E, 0, 3
Summary
E, 0, 3
Summary
Techbelkin
Nov 03, 2010 | Canon Pixma Mp250 Allinone Inkjet Photo...
Our machine shows E051. so what can i do.
The JAM DUPLEX message appears if you remove a sheet of paper from the face down output tray after only one side has printed.
The paper sizes you can use with the duplex printing function are A4, Letter or Legal.
If the paper adjustment lever for duplex printing is not set correctly for the paper size, paper jams may occur and the printing will be out of position on the page.
Open the back output tray.
Use both hands to slowly pull the jammed paper out of the fuser unit.
Close the back output tray.
If the paper jam cannot be cleared, go to the next step.
Pull the duplex tray and paper tray out of the printer.
Pull the jammed paper out of the printer
Put the duplex tray and paper tray back in the printer.
Click solved and vote if problem is solved. Otherwise post again
Aug 02, 2010 | Office Equipment & Supplies
Paper jam in output tray is displayed but i cannot solve
When it says that it usually means there is a paper scrap in the sensor flag that is under the long gray roller. It is a black plastic tab toward the right side behind the white plastic guides that the paper comes out under. You need a flashlight to see it and you need to be careful not to break the tab.
Apr 29, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Copier stops after 35 copies when using finisher
This is due to the output tray you sre using only having a small capapcity sensor what you should do is set it to come out from the finisher unit to the lower tray as this holds more sheets you can check this by looking at the output tray and when it asks you to remove paper see if the top pages are resting on the paper sensor in the tray. good luck A
Jun 02, 2009 | Canon imageRUNNER 400S Copier
Ricoh AP3800C "Output tray full"
Check the little black piece of plastic that senses the printed page exiting the machine. Our sensor was stuck and I was getting the same message (an similar Ricoh product). When I gently reset the black piece to center, moving freely, printing worked again. I think the sensor got jammed up when we were trying to remove a bad paper misfeed.
Ricoh manuals very confusing on this error message. They refer to standard tray, tray one, etc. without being clear whether it's a paper feed tray or the so-called "standard OUTPUT tray." The output is not really a tray, it's just the depression where your sheet lands after printing. I wrenched on the paper feed trays and their settings for an hour before I figured out they meant OUTPUT.
Feb 27, 2009 | Ricoh Aficio AP3800C Laser Printer
Sharp AR-M207 All-In-One Laser Printer Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
