Question about Microwave Ovens
Df500dit grill door hinge - Microwave Ovens
    Top Expert:
  • Microwave Ovens Master
  • 12,223 Answers
Go to www. repairclinic.com and get it
God bless you
Posted on Jul 13, 2013
Can I buy a new door. Current door is cracked on the corners.
You easily replace the door on most microwave ovens by opening the door all the way up and lifting straight up at the hinges. The door should lift off of the hinge pins. On some microwave ovens, you may have to remove the upper grill cover over the door (if equipped) to accommodate door removal.
NOTE: Some doors have a hinge pin that needs to be removed, or screws holding the door in place at the hinge.
There are several parts sources available that you can may try to purchase replacement parts:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The first three sites on the list also offer helpful exploded view parts listings to aid in parts identification and location. Just type in your model number and locate the parts listing for the door. Some manufacturers only sell the door as a complete assembly. Others may sell individual parts. To save money, you may also try just purchasing the door facing parts that are cracked. If you have any questions, or require additional assistance, please post back with your complete MODEL NUMBER and let me know. I hope this advice is helpful.
Dec 16, 2010 | General Electric Microwave Oven
How do I adjust the door switchs
Remove the grill on top and there will be a screw for the control panel. Once the control panel is tipped down you can see the door switches . Adjustment is a combination of the switch bracket and door hinge adjustment, You should have access to a Rf leak detector to inspect the door anytime the hinges or latches are serviced.
Eric
Jun 02, 2010 | Kenmore 62622 Microwave Oven
Need to Replace door on a sharp R1830 B how would I go about doing this?
On MOST microwave ovens all you have to do is open the door all the way and lift straight up at the hinges. The door simply lifts all the hinge pins. You may have to remove the upper grill cover (if equipped) to accommodate.
NOTE: On some models there is a small hinge pin on the upper hinge that you need to remove first.
If you have questions, please let me know. I hope this helps you.
Oct 08, 2009 | Sharp Microwave Ovens
On the GE JVM 1650 Spacemaker microwave, how do I replace the door?
If replacing the entire door, all that is required is to open the door all the way open and lift straight up on the hinge side of the door. The door will lift off the hinge pins. You may have to remove the upper grill cover (if equipped) on some models for better access. If you have questions, please let me know. I hope this helps you.
Sep 24, 2009 | GE JVM1650 1000 Watts Microwave Oven
We need to change the door on our microwave. We have the new door, but can't find anything in the manual about removing the old door. It is a Frigidaire Gallery series above range microwave. Any...
The door should come off fairly easily. All you have to do on MOST microwave ovens is open the door all the way and lift straight up at the hinges. The door will come off the hinge pins.
On some models, there may be a small hinge pin on the top hinge that you remove, then lift up.
You may have to remove the grill panel above the door (if equipped) to allow for clearance for the door to come off.
If you have questions, please let me know. I hope you find this helpful.
Sep 05, 2009 | Kenmore 62622 Microwave Oven
Need help replacing handle on whirlpool microwave model MH1150XM
Remove two screws on top at front in order to remove plastic front vent grill. Then the door lifts off pin hinges. Lay door flat on surface. Plastic trim snaps off with gentle prying (start at bottom middle and bottom hinge side). Then remove six screws holding notched metal section with door latch. This piece will also snap out (several visible clips holding it around edges). Then remove door handle screws, Replace handle and reverse process to put back together.
Jul 29, 2009 | Whirlpool MH1150XM Convection/Microwave...
Replacing microwave oven door
The door should simply come off by opening it all to way and lifting straight up at the hinges, The door will lift off the hinge pins. On some models you may have to remove the upper grill above the door (if equipped). If you still have questions, please let me know. I hope this helps you.
Jul 02, 2009 | Microwave Ovens
Door is loose, microwave won't cook
The door switch mounts and possibly the door hinges need to be adjusted them tightened.
Unplug the oven, remove the cover if it's a counter top type or remove the grille and control panel if it's an over range type.
Then close the door and watch how the door latch heads on the door mesh with the door lathes and door switches.
Also check the hinges.
If the door latch heads are not activating the upper & lower door switches, then adjustment will be needed.
For many brands, you can find helpful exploded view diagrams and order parts by entering your full model number here.
There is often a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Please reply back with your brand and model number if you need more help.
Aug 17, 2008 | Frigidaire FMV156DC Microwave Oven
KitchenAid KCMS185JSS1 Door Removal
On most new MW ovens, the door will lift off the hinges once the top grille is removed. There are two screws on the top that hold the grille in place.
Mar 12, 2008 | KitchenAid KCMS145J Microwave Oven
Door
The door part# is 4359542 if you need the part number. If you need to know how to replace the door check up by the upper hinge on the inside of the door should be a plastic piece that you can remove so if you lift the door off of its hinges. You may or may not need to remove the grill above the door to raise the door high enough
Oct 31, 2007 | Whirlpool MH7135XE Microwave Oven
Microwave Ovens Logo
15 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
