Question about Wahl 9918-600 Beard Trimmer
Charging time How long do I have to charge my trimmer once it's fully dead?
How do i know a charging panasonic ER206 trimmer finished charging?
There is no full battery indicator. If you charge if for the length of time stated in the user manual, that will fully charge the battery
Nov 18, 2016 | Panasonic Health & Beauty
Why does my Black Decker 12V cordless trimmer would not start
battery is probably dead... it may read fully charged but it cannot support the "load"... if you're only going to use something of that nature once. you really don't need it.
Jul 27, 2014 | Black & Decker String Trimmer Cordless 12"...
Chaging batter
The voltmeter test provides a general indicatorof battery condition. Check the voltage of the battery to verify that it is in a 100% fully charged condition. If the open circuit (disconnected) voltage reading is below 12.6V, charge the battery and then recheck the voltage after the battery has set for one to two hours. If the voltage reading is 12.8V or above, perform the load test described below.
The load test measures battery performance under full current load and is the best indicator of battery condition. Load testing a battery tat is not FULLY CHARGED i.e. at 12.8 VDC can permanently damage it. Fully charge it first and then let it stand for at least an hour before the load test is done. You also need a load tester. AND you should know how to perform a load test. Often the best way to load test a battery will be to take it to a battery shop and have it done there.
VOLTAGE (OCV) STATE OF CHARGE FOR AGM BATTERIES IS:
12.8 VDC = 100%
12.6 VDC = 75%
12.3 VDC = 50%
12.0 VDC = 25%
11.8 VDC = 0%
COLD CRANKING AMPERAGE (CCA) for an XLH battery is 270
19 AMP HOUR BATTERY =
BATTERY STATE OF CHARGE = 12.8 VDC = 100% Charge; Rate of Charge = N/A
BATTERY STATE OF CHARGE = 12.6 VDC = 75% Charge; Rate of Charge @ 3 AMP = 1.75 hours @ 6 AMP = 50 minutes @ 10 AMP = 30 minutes @ 20 AMP = 15 minutes
BATTERY STATE OF CHARGE = 12.3 VDC = 50% Charge; Rate of Charge @ 3 AMP = 3.5 hours @ 6 AMP = 1.75 hours @!10 AMP = 1 hour @ 20 AMP = 30 minutes
BATTERY STATE OF CHARGE = 12.0 VDC = 25% Charge; Rate of Charge @ 3 AMP = 5 hours @ 6 AMP = 2.5 hours @ 10 AMP = 1.5 hours @ 20 AMP = 45 minutes
BATTERY STATE OF CHARGE = 11.8 VDC = 0% Charge; Rate of Charge @ 3 AMP = 6 hours, 40 minutes @ 6 AMP = 3 hours, 20 minutes @ 10 AMP = 2 hours @ 20 AMP = 1 hour
The figures listed above assume that the battery is charging at room temperature. If warmer than room temperature, use a slightly shorter charging time. If colder, use a slightly longer charging time.
The use of constant current chargers to charge maintenance-free batteries is not recommended. Any overcharge
will cause dry-out and premature battery failure. If a constant current charger is the only type available, do not exceed the charge times listed above and do not continue charging the battery if it gets hot. When charging, never exceed 15 volts for more than 30 minutes.
If the battery gets hotter than 110 degrees F. (43 degrees C) during charging, discontinue charger and allow the battery to cool. Overheating may result in plate distortion, internal shorting, dry out and/or other damage.
COLD CRANKING AMPERAGE (CCA) for a 2001 XLH battery is 270
Apr 22, 2014 | Harley Davidson XL 1200 S Sportster Sport...
Blueparrrot B250 is 1 year old & it went dead so I
how do you know it is fully charged? i think it may be dead battery
Nov 06, 2012 | Computers & Internet
Black &Deckeer Fire Storm 14.4 V battery does not charge charge light is not on.
You are able to open the battery, very carefully, the joint is normally welded, some times screwed together, you will find one of the cells that is dead. You can usualy find cells of the same size (physical as well as Voltage and Amp) just replace the dead cell and seal it all up again.
Sep 27, 2012 | Garden
I have a starting/charging issue in my 2008 Raider that mechanics can't simulate. They have checked for load issues and found none. Please advise.
first,, take the battery out of the vehicle and have that Load tested on its own, sometimes the battery will say 12 volts and still have a dead cell, which means its not getting the amps required ,, and will give the effect that the charging system is failing, make sure all battery connections are clean and tight . Once you have a known fully charged battery ,, install it, start the vehicle,, check the posts again with a meter,, you should get a reading of 13.5 - 14.5 volts showing, if not your alternator isn't charging the system
Aug 31, 2011 | 2008 Mitsubishi Raider
My trimmer wont start. thought it was battery put a new one in worked for a few minutes and then stopped working
your batteries aren't charging fully, check them fully charged with a volt meter,, fully charged they should have a reading of 18.5 volts, if not they are not charging, and either the batteries have used up their life, or your charger is on its way out
Jul 15, 2011 | Worx GT WG150 10 in. 18 Volt Cordless...
Wahl 9918-600 Beard Trimmer Logo
29 people viewed this question
Top Wahl Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Anglia Clipper...
Falling star
Are you a Wahl Health and Beauty Expert? Answer questions, earn points and help others
