Bosch wfg 2460 - Washing Machines
3 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: I have a bosch WFR 2460 washer. Er:15 error code.
You need to check and clean pump filter, normally located behind a removeable plastic cover at bottom front of washer right hand side.
If no filter found there remove rear panel of washer, and clean pump from rear of washer.
Please rate my solution.
Thanks.
Posted on Nov 11, 2009
Testimonial: "Thank you so much. There were some wood splinters and a nail stuck in there! No wonder it wasn't working!"
  • 6277 Answers
SOURCE: can i use just cold
Yes! You will need to purchase a 'Y' piece which is used upside down - the single end is screwed onto the water supply tap and each of the hot and cold water feeds to the machine screw onto each of the double lower 'arms'. The machine opens its 'hot' water valve, receives just the single supply cold water and then has to heat it to the correct temperature. When it wants cold water- for rinses- it opens its cold water valve ..........and gets the same water supply as the hot valve!
'Y' pieces are normally obtained from local hardware stores - certainly in the UK and France!
Good luck,
John C
Posted on Mar 22, 2011
Not draining
This would be your drain pump on this Bosch. Contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service with your model number and we will send the correct pump out right away!
I love Bosch! Thanks, Ella
Nov 16, 2009 | Bosch Axxis+ WFR 2460 Front Load Washer
Thanks.
Nov 11, 2009 | Bosch Logixx WFT 2806 Front Load...
Door handle is loose and door can't be openBosh washer WFR 2460
Remove the top cover, and release the door catch from inside the front of washer.
Thanks.
Oct 30, 2009 | Bosch Axxis+ WFR 2460 Front Load Washer
Bosch 2460 won't spin
only brushes in motor ,he taking the mikey motor only 236.00 from bosch
Jun 30, 2009 | Bosch Axxis+ WFR 2460 Front Load Washer
Bosch Axxis WFR 2460 Front Washer Drum/Cycles Not Working
hi sounds like the motor brushs are worn down,some bosch models you can change them without removing the motor ,but others its best to remove it,they just twist out,and to refit use a small blade flat blade screwdriver to tuck tab in,thanks
Aug 04, 2017 | Bosch Axxis+ WFR 2460 Front Load Washer
Bosch WFR 2460 washer - Drum does not move during wash/spin cycles
possibly the motor brushes.
take back panel off and motor is held in by bolts which undo - also disconnect electrical plug and socket.
check condition of brushes
Oct 16, 2008 | Bosch Axxis+ WFR 2460 Front Load Washer
Beep sound
press the left menu button 4 times to get to the signal menu and press the right menu button until you get to OFF (for bosch maxx 2460)
Aug 15, 2008 | Bosch Axxis+ WFR 2460 Front Load Washer
WFD 2460 washes but no drain or spin
check the filter and check for foreign object stuck in pump impellor
Jul 23, 2008 | Bosch Axxis+ WFR 2460 Front Load Washer
Bosch 2460 washime machine. washed, will not drain r spin
i think thew buzz you hear maybe something stuck in the pump impellor. remove filter and check
Jul 23, 2008 | Bosch Logixx WFT 2806 Front Load...
Bosch WFD 2460 Washig Machine
Hi, It sounds like you have the two water pipes fitting on the wrong connectors on the back of the machine.
IE: The hot water pipe (RED connector) on the cold water inlet on the back of the machine (BLUE connector)
Is should be red to red and blue to blue.
Jan 03, 2008 | Bosch Logixx WFT 2806 Front Load...
Washing Machines Logo
19 people viewed this question
Top Washing Machines Experts
