Question about Sony KDS-70R2000 70" SXRD TV
No graphics on the screen GUI
It first started with graphic not showing on the screed, like volume, channel number, menus screen Then week later tv will continuously reboot it self in a loop Picture will come on for minutes then it will switch of and restart it self The lamp is fine Do you thing this might be the Fxe board (digital Board) All the cooling fan works fine
  • Kamal Jul 18, 2013
    i had taken this tv to repair and tv engineer said. it may need Digi board, where is the digital board? it it where PCMCIA CARD goes. if it i can get this
    Champion:
  • 247 Answers
Needs a tech to reprogram the tv ez adjusts, the parameters have to be set to their factory values
Posted on Jul 14, 2013
  • 11 more comments
    thank you for your help so far
  • bobby caesar Jul 18, 2013
    u got to get into the ez ajust main menu and set all the values as per the factory settings go to a tech with the tv model and get all the parameters done for u do not do this if u have no skilled personnel in servicing when all these parameters are set the tv will work like when it was manufactured in special case the tech will use a pc to access some ez sub menu and upgrades
  • Kamal Jul 19, 2013
    Thank you your reply
    I have spoken to couple of service engeers but that do not how to access the service menu from the back of the . Do you know which circuit board is responsiabal for this, I can just replce the whole board. I can send you the link for the service manual if it helps
    I tried to reset using the remote I+5+vol+pow but did not work because the OSD does not work
    Someone said the digital board , which one is this? Is it the FXE free view decoder board
  • bobby caesar Jul 19, 2013
    kamal...on dlp tv the dmd board is located under the light engine casing for digital conversionto analog board its located near the tuner for i believe its the digital board(dmd) under the light engine u need to replace remember u may have to replace the whole light engine cos it comes as a unit with the dmd
  • Kamal Jul 20, 2013
    http://elektrotanya.com/sony_kds-70r2000... Please see this site and have a look at service manual, and let me know the board you think my need replacing, by the way my tv is LED rearprojection tv, funnily I was playing trying the display + vol+5+ pow most of the time it did not work, but on two occasion the tv picture stated on and did not switch off, I
    This mean the tv is working fine it seems to have software issues, My free view digital chanel do not work at all blank screen i do have arial plugged in
    Someone said this may due to digital switchover, this may casuing the tv to reboot any please let me know which board to replace , or may if you can be really help full and give me call so I can talk through,
    Please have a look at the link for service manual thank very much for your time and support http://elektrotanya.com/sony_kds-70r2000...
  • bobby caesar Jul 20, 2013
    kamal...the digital board is the one one labelled digital not DA./digital converter
  • Kamal Jul 22, 2013
    Pleas have a look at link. The only board that says digital is the free view digital FXE board , please help you are the only who has helped me, just to hight lite again that digital Chanel do not work not even a digital snow , blank screen, I
  • 231 Answers
SOURCE: Sony KDF-E42A10 cycling on and off
the best thing to first is to replace lamp ..lamp will also cause this..this will be the cheapest route to go first..Please let me kno and I will give you more info or docs from Sony...
Posted on Dec 14, 2007
welcomejee
  • 10594 Answers
SOURCE: TV powers off after 10 seconds of powering on....
Thats great, Please rate solution.
Posted on May 19, 2009
SOURCE: TV switches itself off after 1 minute standby flahes red to green
there seems to be a possibility that your ballast might defective.. i recommend you replace it. It might not have enough voltage to keep up with the new lamp
Posted on Jul 02, 2009
  • 178 Answers
SOURCE: KDS-R60XBR2 power led blinks 4 times,
There are three fans the one that usually fails is located on top of the optical block and cannot be reached by the owner unless you take the set apart yourself. What is happening is that one of the fans are not spinning fast enough or has stopped altogether. The best solution is to replace all three fans cleaning may not be enough to get a slow fan up to speed, and the tech should blow out the dust in the duct work. This is what the tech coming out will (or should) be doing. Also some fans will have an intermittent startup, and cause this intermittently, so it is a good idea just to replace the fans instead of just cleaning them.
Posted on Sep 02, 2009
ladywinn
  • 5138 Answers
SOURCE: I had the fan issue with the 4 flashing red lights.
If Ballast was not working Lamp would not Light Sony is well known for Bad Light Engines Call or visit Encompass Parts Distr. online 1-800-638-3328
Posted on Dec 16, 2009
My Toshiba Regza TV has no picture but there is sound and I can go through the channels (doesn't show channel number). I cannot show the menus on screen either,is there a fix?
If your model of the TV is a edge-lit LED TV 46L52XX, the problem is the LED back lights strip.
The Board number is SLED 2012SGS46 7032L, Samsung part number is: LJ64-03471A. We have new one cost $38.88 each.
Apr 25, 2017 | Toshiba Televison & Video
What is a GUI installer?
It stands for Graphics User Interface(GUI), i.e. a windows installer.
Mar 17, 2015 | Dell Inspiron Computers & Internet
Philips TV 42pf9976/37 no picture, just grey screen We lost the picture on the TV and it just shows a light grey screen,no wavy lines, fuzziness just plain grey. When you change channels you do get the...
Please try the DVD function to see if you have the same problem. The TV has the backlights working OK and you can also see the Graphic on the screen, you can also see the on screen menu setup right?
Please post back on what you find when you try out the DVD, otherwise you may have bad amin board.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: http://interliquidparts.com/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Oct 13, 2011 | Televison & Video
What does gui means?
GUI is a Graphical User Interface, which is for making "Windowed" Applications.
Nov 01, 2010 | Microsoft Internet Explorer 8
Gui does not come up on screen
Possible causes & solutions, in order of simplicity:
1. Wrong input selected on TV - Reconfirm you have selected the input corresponding to the receiver's MON. OUT connection, e.g., component video, S-video.
2. Wrong output set on receiver - Reconfirm you haven't previously selected an output on the receiver that is unavailable on your TV, e.g., on some receivers, HDMI cannot be used for on-screen display. The front panel may show the setting as a backup for no on-screen display. If not, you may have to reset the receiver to factory defaults -- find out how to do this in the manual.
3. For component video or HDMI only -- Output signal from receiver may be set to a mode that the TV cannot process, e.g. 720p for a TV with only 480i/480p/1080i capability.
4. If the receiver is a high-end model with "Pure Direct" or similar settings that have been selected, the video circuitry and possibly also the OSD may be unavailable. Try switching to a normal setting or another input.
By the way, the usual term for the menus from an AV receiver is "on-screen display (OSD)" -- not "GUI (graphical user interface)," which is more appropriate for computers or cell phones.
Feb 07, 2010 | Denon AVR-4308CI Receiver
Is it the TV or Comcast?
I'VE SEEN QUIT A FEW SAMSUNGS DO THIS AND THE DIGITAL BOARD IS THE PROBLEM YOUR MODEL NUMBER DOES NOT HAVE A DASH HLR4667W AND YOU NEED YOUR VERSION NUMBER AND MAYBE THE BEST THING IS GET THE PART NUMBER OFF THE BOARD.
Apr 17, 2009 | Samsung HL-R4667W Rear Projection...
Multiple issues with tv
Pressing i+ button (bottom left on the original remote) for 5+ seconds worked for me...
Feb 21, 2008 | Philips 32PF5320 32 in. HD-Ready LCD...
RCA VR355 recording problem
Are you sure the reciever is coming through the vcr.? are you hooking it up through a/v on vcr?
if so hook from a/v out from directv to a/v in
jacks on back of vcr. and turn vcr on a/v channel
to record it. you will see the picture as you record it. if the vcr isn't on a/v channel it won't record it
If you use ch 4 or 3 to record it you
hook up directv to cable in on vcr and you
have to turn vcr on that channel and see it coming
through it you have to push a button on satlette
remote to make it come on the vcr on the channel
or it will record snow. and you have to push
another button on vcr remote if you haven't
already to get the vcr on ch 4 or 3 on your tv
or if u got it through a/v turn tv to a/v channnel.
just beacuse you see the picture coming through
your tv doesn't mean it going through your vcr
you could be just seeing it through the tv only.
you will see the vcrs graphics or vcr channel number on your
tv too along with the directv channel if it's hooked
up right. notice the vcr won't record it's own
graphics or channel number on the screen but it will record the directv's graphics. and it won't record the tv's own grapic channel number either.
to make sure it's right you will see 3 graphics on
your tv the own tv's channel number or a/v
the directvs and the vcr's channel number or a/v
on your tv if you see these you know it's hook up
right.
Nov 11, 2007 | RCA VR355 VHS VCR
Sony KDS-70R2000 70" SXRD TV Logo
48 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
