Question about Microwave Ovens
Breville microwave bre731sse user manual
Everything seems to be in order but not just heating up... and it giving a sign /i\.i.e(i signal inside a triangle)
    Top Expert:
  • Microwave Ovens Master
  • 12,223 Answers
See this steps and fix it. God bless you
  1. Check the power diodeThis electronic component is responsible for transmitting current in one direction. If the diode becomes defective it will cause your microwave to not heat. Test the diode and replace it if necessary.
  2. High voltage capacitorResponsible for storing electricity, this part is a key component in any microwave. Remove, discharge, and test the capacitor to determine if it requires replacement.
  3. Damaged magnetronResponsible for generating waves and producing heat. When your microwave is no longer heating properly, replacement will be required.
  4. Thermal CutoffsExamine the thermal cutoffs on both the magnetron and the oven itself. Take off one of the leads and using a volt-ohm meter on RX1, check the terminals. If you get a result other than zero, replace the thermal cutoffs.
breville microwave bre731sse user manual - af2e2505-b73f-4caf-a82e-2499425afa2c.gif
Posted on Jul 13, 2013
3 Suggested Answers
SOURCE: User manual BRE799GMSSE
i have a microwave Breville.Ia working but is not heating the food.What is the problem?What should i do?
Posted on Mar 29, 2008
  • 715 Answers
SOURCE: eVERYTHING SEEMS TO WORK BUTG THE MICROWAVE DOES
sounds like the magnatron has gone out
Posted on Nov 07, 2009
I need a replacement turntable for my brevile combination microwave model brcm2516 where can I get one
First4Spares Glass Turntable Plate For Breville Microwave Ovens ...
https://www.amazon.com/First4Spares-Glass-Turntable-Breville-Microwave/.../B007B...
Shop First4spares at the Amazon Small Appliance Parts & Accessories store. Free Shipping on eligible ... BREVILLE MICROWAVE TURNTABLE Glass Plate 245mm 9.5". $29.99. Next ... Container for Microwave Oven · Add to Cart · Add to ...
Amazon.com: BREVILLE MICROWAVE TURNTABLE Glass Plate ...
https://www.amazon.com/BREVILLE-MICROWAVE-TURNTABLE-Glass.../B00COP... Quality replacement glass turntable for your Breville microwave. ... Small Appliance Parts & Accessories > Microwave Oven Parts & Accessories > Turntables
Breville Shop ' Partmaster
www.partmaster.co.uk/breville/microwave/catalogue.pl?shop=breville&path... Find your Breville products and repair your appliance yourself for less. ... Connects the microwave motor to the glass turntable Suitable for select microwave ...
Breville Canada
https://breville.ca/ Breville designs and engineers small kitchen countertop appliances to deliver commercial quality performance that look great and are easy to use.
Breville Microwave Parts & Accessories ' eBay
https://www.ebay.co.uk > ... > Breville Microwave Parts & Accessories BREVILLE Microwave Glass Turntable Plate Roller Ring Support Stand 3 Wheel ... Turntable Turn Table
Plate MOTOR for BREVILLE Microwave Oven ...
Breville Parts -Google Search
Jul 03, 2017 | Microwave Ovens
My kitchenaid microwave will not heat in microwave mode. In fact the turntable starts and stops and the display blinks intermittenly. In convection oven mode everything works fine - It heats, turntabl
The magnetron is the main part that gives out microwaves to heat the food. As the convection bit is working this points towards the microwave bits.
The magnetron has a main diode, fuse and transformer to run the microwave bit, any of these could be faulty. A word of warning though, there are extremely high voltages inside microwaves, even when unplugged in the main capacitor. Also to repair this section you will need to be a fully qualified engineer to even order parts for this.
Find a microwave technician who can repair for you
Nov 04, 2014 | Microwave Ovens
I have bought a second hand breville fan assisted breadmaster, but it has no manual - can you help please?
Assuming its a BR1 try this: http://safemanuals.com/user-guide-instructions-owner-manual/BREVILLE/BREVILLE%20PART%201-3-_E
hope this helps!
Jul 24, 2011 | Microwave Ovens
My Breville BRE799GMSSE microwave will not heat anything
If you want to fix it yourself you'll need some understanding about what you're going to do.
If absolutely everything is working and food stays cold, there's only one problem MAGNETHRON. You'll need to dissassemble the microvave itself, remove the magnethron an to replace it with the same type.
Be advised Tthat this might be expensive. In some cases magnethron costs more than new microwave oven (in Europe).
Jun 21, 2009 | Microwave Ovens
Kenmore Microwave Won't Heat Food
The service manual is here.
Unless there's a bad connection at a magnetron terminal, I would say you have a failing magnetron.
It is part number 2B71165R and you can get it from the Pros here for $68.59 (subject to change).
For more free DIY and other help & advice, feel free to contact me via my site.
William E. Miller, AS-EET
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 15, 2017 | Microwave Ovens
Everything works but no heating?
With inside light and turntable on, louder sound, and no heat, this is usually a shorted high voltage rectifier diode or a bad magnetron.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
http://www.gallawa.com/microtech/mag_test.html
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Aug 14, 2008 | Jenn-Air JMV8196 Microwave Oven
Feb 25, 2008 | Microwave Ovens
Microwave Ovens Logo
96 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
