Question about Samsung Star 3G GT-S5603 (16 GB) Cell Phone
Pc studiodjhahvjjww nhsbh nm jmsbmsf ndbmhsn dsnbsdnbmsbmsnnm snbmsbmndsnmdsnmsgdmjbx bmnmbsd
Iphone4s model no:A1221 fcc id:bcga1221 ic id:579c-a1229Is fack or real
Posted on Jul 13, 2013
Abbreviation for Nm
Nm = Newton metre
nM = nanomolar
nm = nanometre
NM = New Mexico
Jan 27, 2017 | Cars & Trucks
What is the difference between GPON B+ and C+ GPON transceiver?
B+ Module C+ Module Type One-fiber bi-directional optical module, class B+ One-fiber bi-directional optical module, class C+ Operating Wavelength Tx: 1490 nm
Rx: 1310 nm Tx: 1490 nm
Rx: 1310 nm Encapsulation Type SFP SFP Port Rate Tx: 2.49 Gbit/s
Rx: 1.24 Gbit/s Tx: 2.49 Gbit/s
Rx: 1.24 Gbit/s Minimum Output Optical Power 1.50 dBm 3.00 dBm Maximum Output Optical Power 5.00 dBm 7.00 dBm Maximum Receiver Sensitivity -28.00 dBm -32.00 dBm Optical Connector Type SC/PC SC/PC Optical Fiber Type Single-mode Single-mode Reach 20.00 km 20.00 km Overload Optical Power -8.0 dBm -12.0 dBm Extinction Ratio Huawei GPBD Board Thunder link com
Nov 02, 2016 | Computers & Internet
I want to know the torque specifications for a 4D32 mitsubishi engine ?
we have 4g32 cyl head stage 1 70-76 nm stage 2 run for15 mins stage 3 tighten 78-83 nm
main bearings stage1 24-27 nm
stage2 49 -54 nm
big end stage 1 15-17 nm stage 2 31-34 nm I hope this helps from Coloneus
Jun 07, 2016 | Mitsubishi Cars & Trucks
What the torque settling on a 1.8spi vauxhall cavalier 1994
Cylinder head Renew bolts: Yes Tighten: 25 Nm Tighten: 90° Tighten: 90° Tighten: 90° Other engine tightening torques Main bearings Renew bolts/nuts: Yes Main bearings Stage 1: 50 Nm Main bearings Stage 2: 45°-60° Big end bearings Renew bolts/nuts: Yes Big end bearings Stage 1: 35 Nm Big end bearings Stage 2: 45°-60° Oil pump to cylinder block : 6 Nm Sump bolts : 15 Nm Sump drain bolt : 55 Nm Flywheel/driveplate :
  • Use new bolts and tighten as follows:
      • 1,4/1,6 = 35 Nm + 30° + 15°
      • 1,8/2,0 = 65 Nm + 30° + 15°
  • "Pot"-type flywheel = 65 Nm + 30° + 15°
  • Tighten drive plate to 60 Nm.
Clutch pressure plate : 15 Nm Crankshaft pulley/damper centre bolt : Use new bolts. Tighten centre bolt to 130 Nm + 40°-50°
Camshaft sprocket/gear : 45 Nm Camshaft/rocker cover : 8 Nm Inlet manifold to cylinder head : 22 Nm Exhaust manifold to cylinder head : 22 Nm Spark plugs : 25 Nm Lambda sensor (Oxygen) : 30 Nm Chassis tightening torques Front hub :
  • Tighten nut in three stages:
    1. 130 Nm
    2. Slacken off
    3. 20 Nm + 80°-90°.
Steering track rod end : New nuts 60 Nm Brake disc to hub Front: 4 Nm Brake caliper to carrier Front: 30 Nm Brake caliper/carrier to hub Front: 95 Nm Brake caliper/carrier to hub Rear: 80 Nm New bolts ABS sensor Front: 8 Nm ABS sensor Rear: 15 Nm Road wheels : 110 Nm
There you go pretty much covers everything hope that helps
Jan 11, 2015 | Vauxhall Cars & Trucks
Intake torque on top & bottom bolts
Apply sealer to the lower intake manifold bolts prior to installation. On the 5.0L and 5.7L engines, install the bolts and torque in sequence as follows:
Step 1: 71 inch lbs. (8 Nm).
Step 2: 106 inch lbs. (12 Nm).
Step 3: 11 ft. lbs. (15 Nm).
Fig. Lower intake manifold bolt tightening sequence-5.0L and 5.7L engines / zoom image link here
Upper intake manifold mounting bolts/studs, torque in a crisscross pattern as follows:
  1. Step 1: Torque the bolts/studs to 44 inch lbs. (5 Nm).
  2. Step 2: Torque the bolts/studs to 83 inch lbs. (10 Nm).
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day and Merry X-mas.
Dec 23, 2011 | 1999 Chevrolet Tahoe
I have bought a 500G samsung model NM-0808 but can not be recognized in my PC, can you send me a driver then I can install?
Aug 14, 2011 | Samsung Computers & Internet
Need torque specs on axle nuts for dana 50 rear axle
Dana 50 Front Axle
Observe the following torques;
* Left and Right drive axles-to-cross member: 120-150 ft. lbs. (163-203 Nm)
* Axle arm-to-radius arm: 180-240 ft. lbs. (244-325 Nm)
* Coil spring insulator: 30-70 ft. lbs. (41-95 Nm)
* Upper spring retainer: 13-18 ft. lbs. (18-24 Nm)
Dana 60 Front Axle
* Drive shaft-to-flange: 15-20 ft. lbs. (20-27 Nm)
* Track bar nut and bolt: 160-200 ft. lbs. (217-271 Nm)
* Stabilizer link nut: 20-30 ft. lbs. (27-41 Nm)
* Stabilizer barU-bolt: 50-65 ft. lbs. (68-88 Nm)
* Spindle connecting rod-to-knuckle: 70-100 ft. lbs. (95-136 Nm)
* Front spring U-bolt: 95-100 ft. lbs. (115-135)
Feb 19, 2011 | 1986 Ford F 250
What are the torque measurements for the rocker arms and intake manafold?
2.2L Engine & 2.4L Engines
These engines are not equipped with rocker arms. The camshafts directly actuate the valves.
3.1L Engine & 3.4L Engines
When install or connect the check the following:
- Pushrods and the rocker arms. Torque the bolts to 24 ft. lbs. (32 Nm). - Rocker arm cover using a new gasket. Torque the rocker cover bolts to 89 inch lbs. (10 Nm).
- Heater bypass pipe. Torque the screw at the water pump to 106 inch lbs. (12 Nm), the bolt at the cylinder head corner to 18 ft. lbs. (25 Nm) and the nut to 18 ft. lbs. (25 Nm).
About the INTAKE MANIFOLD...
Intake manifold nuts and bolts and tighten to 89 inch lbs. (10 Nm)
- Pushrods and rocker arms. Torque the bolts to 89 inch lbs. (10 Nm) plus an additional 30 degree turn. - Lower intake manifold. Apply sealant to the threads of the bolts and torque the bolts to 115 inch lbs. (13 Nm).
Exploded view of the upper and lower intake-3.1L & 3.4L engines
Fig. Lower intake manifold tightening sequence-3.1L & 3.4L engines
Hope help.
May 04, 2010 | 2000 Pontiac Grand Am GT
Intake torque specs
Upper intake
Stage 1: Tighten to 20 Nm (14 lb-ft).
Stage 2: Tighten to 25 Nm (18 lb-ft).
Lower intake
Stage 1: Tighten to 15 Nm (11 lb-ft).
Stage 2: Tighten to 32 Nm (24 lb-ft).
Rocker Arms
Stage 1: Tighten to 10 Nm (89 lb-in).
May 17, 2009 | 2000 Ford Windstar
Need the correct torque specs for 2004 silverado 1500 calipers
  • Tighten the 2 brake caliper mounting bolts to 108 Nm (80 ft. lbs.) . Caliper Mounting Bracket to Knuckle, Front (15 series) 175 Nm (129 ft. lbs.) Caliper Mounting Bracket to Knuckle, Front (25/35 series) 300 Nm (221 ft. lbs.) Brake Caliper Mounting Bolt Rear (15 series) 42 Nm (31 ft. lbs.) Brake Caliper Mounting Bolt Rear (25/35 series) 108 Nm (80 ft. lbs.) Caliper Mounting Bracket Bolt Rear (JC5/JH5) 200 Nm (148 ft. lbs.) Caliper Mounting Bracket Bolt Rear (JH6) 165 Nm (122 ft. lbs.) Caliper Mounting Bracket Bolt Rear (JH7) 300 Nm (221 ft. lbs.) Caliper Mounting Bracket Bolt Rear (NYS) 200 Nm (148 ft. lbs.)
    hope this helps
  • Mar 28, 2009 | 2004 Chevrolet Silverado
    Samsung Star 3G GT-S5603 (16 GB) Cell Phone Logo
    Top Samsung Cell Phones Experts
    Computer Repairing
    Computer Repairing
    Fotis Papastamatiou
    Bill Long
    Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
