Question about Water Heaters
Electric Pool Heater Tripping Out!
Hi Guys, I have a Purex Islander Electric pool heater. I have recently opened the pool up for the Summer and the heater keeps tripping out. I have checked inside and there are no loose wires. I turn the heater on and the botton two orange lights come on. A few minutes later the "heat" light comes on and the heater trips out! I have tried disconnecting the two wires from the top of the coil, but it still trips out.. I turned down the heat dial to the lowest setting and the two lights were on, then as I turned it up, the "heat" light comes on and off goes the electric.
  • 3 more comments
  • Brad Brown Jul 20, 2013
    look at this:http://www.inyopools.com/spa_parts_islan...
  • Dave Crewe Jul 20, 2013
    Hi Brad, I have this diagram, I just don't know which item is causing the problem!
    The coil which is 5 on the chart and then is either a or b depending on the wattage of the unit that you have. You can either unhook it from the source or check it with a meter for resistance and shorts to ground to see if it is bad.
  • Dave Crewe Jul 21, 2013
    Thanks Brad, I have tested it for continuity and it is fine. What else should I test it for?
  • Brad Brown Jul 21, 2013
    The heater coil is actually a wire surrounded by ceramic powder and enclosed in a tube. Over time the wire can push the powder away and when it gets hot it touches the tube that is metal and causes a short this is hard to test for. If you hook a meter up to the coil and have it set for voltage and turn it on it should read 220 VAC. Then when it shorts out and throws the breaker, switch to ohms and measure the resistance from the coil to the case of the heat which would be ground. If it cools off, it could be ok
  • Water Heaters Master
  • 17,093 Answers
What is the model number of the unit?
Posted on Jul 18, 2013
  • Dave Crewe Jul 18, 2013
    The model number is E-6?
4 Suggested Answers
jubes garage
  • 7 Answers
SOURCE: my ariston electric hot water heater keeps
Tripping off at the water heater or at the breaker box?
Posted on Jan 29, 2010
  • 4348 Answers
SOURCE: I have A hot water electric heater it just keep
Likely your heater element(s) have shorted. pull them and check for problems.
Posted on Aug 20, 2011
  • 5245 Answers
SOURCE: reliant 40 gallon tall electric water heater replaced both thermostats upper and lower elements flushed tank hot water very hot temp turned down lowest possible keeps tripping reset button what else c
Problem has to be bad element or bad thermostat.
Test elements for short to ground through metal tank wall:
http://waterheatertimer.org/How-to-test-water-heater-element.html
Make sure factory-installed insulation and cover are re-installed over new thermostats so they do not misread tank temperature.
If problem does not show with elements, then replace thermostats again.
Posted on Oct 07, 2012
I can not turn my pool heater off, nor I can not control my temperture up or down
Remove the wires from the thermostat and see if it shuts off, if so replace thermostat/aquastat.
Apr 28, 2016 | Pentair Master Temp Pool Heater 400,000...
Rheem marathon tripping breaker
Turn power off. Open covers and inspect for burned parts.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#trip-breaker
Test elements. Marathon takes specific element, and does not use generic element from hardware store.
Oct 27, 2012 | Rheem MSR50245 Marathon Electric Water...
I have a rheem 40 gal electric water heater. The GFI on the tank keeps popping do you know what could be causing this
10-23-12
Your tank has a GFCI circuit breaker?
Maybe you mean ECO reset button located on upper thermostat?
If GFCI circuit breaker is tripping, turn power off, open covers inspect for burned parts, and test elements. Copy following link for troubleshoot walk-thru:
If ECO reset button is tripping, then replace both thermostats, and test elements.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
Oct 22, 2012 | Water Heaters
No power to pool heater
make sure wiring is correct then make sure breaker is on
Oct 08, 2012 | Jandy LXi Pool Heater Lxi-250 Propane
Recently had a water leak on pipeing. fixed pipeing now water heater keeps tripping breaker.
Problems may be unrelated.
Open following link for electric water heater troubleshoot checklist and resources.
http://waterheatertimer.org/Test-electricity-to-water-heater.html
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Apr 05, 2011 | Noritz Water Heaters
80 gal Whirl Pool electric water heater. Does it have 1 thermostat or 2?
There are two ways to tell:
1) See if tank has 2 removable panels on side.
2) Look at label on side of tank for upper and lower element wattage.
http://waterheatertimer.org/Figure-Volts-Amps-Watts-for-water-heater.html
http://waterheatertimer.org/How-water-heater-thermostat-works.html
http://waterheatertimer.org/How-electric-water-heater-works.html
http://waterheatertimer.org/DIY.html
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Feb 14, 2011 | Whirlpool Water Heaters
Shut off electric current from the breaker switch to Rheem electric water heater for the summer on May 2, 2010 since no hot water needed for the summer. In an attempt to turn on the breaker switch to the...
hi, might want check the thermostat switch, and the heating element. the heating might rusted out, if water wasn't drain out over summer thanks.
Sep 28, 2010 | Rheem Water Heaters
My ariston electric hot water heater keeps tripping off
Jan 24, 2010 | Bosch GL4Ti Ariston Pro Ti Electric...
Raypak gas pool heater with error code HL2
Do you have power to the heater?If you do then I would look for a hi limit switch to reset.It might be the pump you have to reset.
Mar 16, 2009 | Bosch 1600H-LP Liquid Propane AquaStar...
Water Heaters Logo
69 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
