Question about Refrigerators
Dometic rm7291l my fridge works on 240 volt but not gas does anyone know what the problem is
5 Suggested Answers
22yooper
  • 828 Answers
SOURCE: Dometic Caravan Fridge 7271
Your refrigerant may have completely separated in the system. Shut of the gas, disconnect the electrical and remove refrigerator from the coach or if you have sufficient room inside set it on a clean area. This operation is what is called burping the system.
1. From the base roll it onto the door and wait five minutes.
2. roll it onto the top and wait five minutes.
3. Roll it on the back and wait five minutes.
4. Return it to the base and wait five minutes.
Reinstall it or test it on electrical. It should show signs of cooling in about 30 minutes in the freezer compartment if the system is not plugged in the boiler.
Posted on May 26, 2008
  • 8 Answers
SOURCE: Dometic RM7291L not effectively cooling on 240V but fine on gas
these are ammonia fridges .no fans. it has a heating element unplug from the circuit board also check board fuses first. ohm the element sounds like it has gone bad.if it on 0 ohms replace it and that will fix it
Posted on Aug 27, 2009
BIKER T
  • 909 Answers
SOURCE: We have a 3 way Dometic fridge in our caravan.
Temperature does play a big part in the efficiency of the fridge. The condenser at the back of the fridge needs cool air flow to allow gas vapour to be converted back into a liquid.again.
Posted on Nov 12, 2009
Testimonial: "Tks Guru, BikerT. To prove that you are right - since the weather/heatwave has gone - a nice cool morning today and I have frozen milk. Cheers, "
dcramer531
  • 1654 Answers
SOURCE: Hi, My dometic RM 2350
More that likely the control board has gone bad or the thermostat quit working. You might have to try and light this on gas several times to finally get it to go, if there is any air in the line it won't light and the air must be purged. This can take several minutes of continious trying to get it to light. When it kicks off switch from gas to off and back to gas again till it lights. Have you checked the thermocouple that lets the control board know that there is fire in the pilot? If this is bad it won;t kick the main gas valve on. You can check these with a volt ohm meter, when there is fire on the thermocoule you will get a small voltage reading in the mil amps portion on the tester, no reading means bad thermocouple.
When you say failed, what all happened, are the lights on the fridge indicating electric or gas working? Is it just not cooling? Have you hecked for power to the control board on the fridge? There should be a wire diagram on the cover for the board on the back of the fridge, check to see if you have power coming in to the unit, if not check your fuses.
Posted on Dec 24, 2010
Dometic fridge not working on 240 volts gas ok and 12 volt ok
The AC heater element is most likely open. Replace it and it will restore AC operation.
Sep 21, 2016 | Dometic Refrigerators
110 volts works but 12 volt does nothing, checked voltage 13.6 v. Any suggestions. Thanks.
RV Refrigerator Stop Working? - RVing - Fun Times Guide
rv-roadtrips.thefuntimesguide.com/2009/09/rv_refrigerator.php
If your refrigerator works on gas, but won't work on electric, you may have a burned out.... Cirtis, We are camping in Montana and our dometic refrigerator decided to stop ......Won't know until you can confirm you have proper voltage to the fridge. ... If you have confirmed both 12 vdc and 110 vac power at the fridge, I would ...
[PDF]Dometic Manual Refrigerator Diagnostic Service Manual
www.nationalserroscotty.org/resources/dometic-service-manual.pdf
Dometic Manual Refrigerators. ... 110 Volt Plug. 2. .... This is Dometic's Manual Refrigeration Diagnosis and Troubleshooting program. In this ... we will discuss the way an absorption cooling unit operates, and the ... gas, 120 volts AC and 12 volts DC .....In this condition we are still boiling ammonia but have no hydrogen for.
Dometic Fridge problems - RV mechanic
Dec 28, 2015 | Dometic CF-050DC CF-50 Waeco CoolFreeze...
I have a dometic fridge model number 8551 and when the gas bottle ran out I changed the gas bottle over and now it won't restart on gas I have cleared the pipes turned the 240 volt off and 12 volt and
check the regulator on top of the bottle ,try lifting the bottle by the regulator to see if the valve is secure on the bottle then if it appears so take the pipe off and see if you have gas coming out ,and if you still cannot get it to work and touring here in spain well iam in alicante call in and will kick it into touch for you .
Dec 25, 2012 | Refrigerators
Three year old Dometic RM 2555, 3 way Frig/freezer has failed on 240VAC however works on Gas. I suspect the PCB is faulty
My rm2555 has just failed on 240 volt. But not 12 volt.
It turned out to be the 240 volt element .
Fairly easy to replace. If you have a multimeter test the resistance, mine was open circuit.
Does yours work on 12volt?
The two heater elements (ie 12v and 240v ) are on the right when viewed from behind with four large wires coming out, plus an earth wire. There are labels on some of the wires. The 12 volt conects into a terminal connector, where as the 240 volt is fitted with spade connectors and is attached to the printed circuit board, under the white plastic cover. The elements are "L" shaped and are just pushed down in down next to each other. The cover seems to unclip fairly easily to enable removal.
Hope this helps.
Mark
Dec 26, 2010 | Dometic Refrigerators
We have a 3 way Dometic fridge in our caravan. Have lived in the van for last 12 months ( grey nomads) have had no probs until trip home this week from Yulara to Victoria. Pulled up at night and freezer...
Nov 12, 2009 | Dometic RM2652 Refrigerator
On the back of the unit, at the bottom, there should be a panel that is removable. Inside should be a fan, the condenser coil, and the compressor. The fan has to be constantly blowing air over the condenser coil, to dissipate the heat (which it is essentially being removed from the refrigerator by the compressor)
When the entire fridge stops cooling, one of three things have happened. The fan isn't removing the heat from the coil, or the compressor isn't compressing the freon, or the freon has somehow leaked out of the system. If it is the fan, you have an easy do it yourself repair. If it is the compressor or the freon, you will probably (but not necessarily) need a professional.
Inside the fridge, there is a coil that is cold instead of hot. A fan must continually blow over that one too, to circulate the air over the cold coils. The fan usually only works when the doors are closed, so be sure to have the door switch pressed to "shut" when checking it.
Check those and post back. And, I know... it really is Dometic.
If the problem is the first one,
Jul 28, 2009 | Dometic RM2620 Refrigerator
Dometic rm 2620 fridge problem
The flame is not hot enough check gas pressure
Jun 22, 2009 | Dometic RM2620 Refrigerator
Rv fridge problems
have a dometic rm2852 fridge . does not switch over from 110 volt to gas automaticlly. it will click but not ignite. can you help?
thanks
Jul 09, 2008 | Dometic RM2652 Refrigerator
May 26, 2008 | Dometic Refrigerators
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
