Question about Drills
Parkside drill sds hammer lost its ball bearing and retaining clip.i found the ball bearing and tried wire to retain it.no good.anyone know how to retain the ball bearing to stop having th pull the dr
Red parkside typ:pebh 1000 bj 2004
  • 52 Answers
SOURCE: How to replace the hammer and striker
Sorry I couldn't be of more help. I've looked at about every DV 20 version parts list and cannot find a part 16 that would create any difficulty in removing. All are either gears, pins, or the plate that goes under the switch. from the way you are describing it it sounds like the only possibility would be the Model DV 20VB which has a spindle which has to be unscrewed from the drill chuck it is held in by a retaining clip that you would need retaining ring pliers to remove.
Posted on Feb 11, 2010
  • 919 Answers
SOURCE: Broken battery retainer clip (red) on Olympus C-7000 Camera
You may want to call Olympus Customer Service and see if you can order this part from their parts department. Their telephone number is 800-622-6372 option 2 and then option 3.
Posted on Mar 09, 2009
  • 532 Answers
SOURCE: where to buy 1996 f150 front bearing retaining clip
try a salvge yard or at Ford dealership,be careful that from 92-96 they have changed alot,between light duty an heavy duty,and the difference in years as well.But i think you will be ok with used from 94-96,and i think that the heavy duty has a ratchet nut verses just a nut to hold the hub on
Posted on May 08, 2009
  • 1111 Answers
SOURCE: How to remove the bearing and seals from rear axle on 1996 toyota
not positive on this model, but most axle bearings are pressed on
Posted on Jun 20, 2009
bonedivers
  • 1140 Answers
SOURCE: Lost daughter's retainer in washing maching, how do I open it up?
Have to unbolt agitator to remove.
Posted on Jul 27, 2009
I have a cougar 1100w hammer drill and the chuck has fell out i have put it back together but theres nothink there to hold the drill in.
Maybe the (spindle) sleeve is worn has no driving conduction anymore but maybe only the locking ball for the sds or thats allready lost too.
compare it to a new spindle to see whats missing in most cases its not worth to do repairs
Cougar 1100W Rotary Hammer Drill in Lowestoft Suffolk Gumtree
Aug 06, 2016 | Hammer Drills
Snapped sds plus drill bit off in chuck. how do i take it apart to get it out i have taken chuck covers off but cant get hold of broken bit with long nose pliers
dont know the exact model you have but if there is a retaining ring on the spindle I would remove it and the corresponding parts and then you can put a small screwdriver in the slot on the side to start moving the bit. If you need more help give me the model number and I will see what I can do
Jan 18, 2011 | Bosch Drills
Will this drive half inch rebar through 12 or more inches of landscape timber in a retaining wall?
Yes, but I usually drill a hole just a bit smaller then the rod so that the rod does not split the landscape timbers....
You can buy ship auger bits up to 12" long and they drill through the landscape timber fairly well...
heatman101
Nov 22, 2010 | Bosch HS1924 Sds - Max Hammer Steel Ground...
I have a Makita HR2450 hammer drill with an SDS chuck. It no longer holds the bits tightly and I can now push them in and pull them out without needing to use the release mechanism. How do I remove the...
go to Makitatools.com and type in your model number for a breakdown. What I would do is first remove the dust shield and under that you will find a retaining ring, remove it without spreading it too much, then remove the collar and under that you will find a washer and another retaining washer, push down and remove the steel ball. clean the area, it could be full of dirt and not locking properly. Let me know if you need more assistance
Sep 12, 2010 | Makita Drills
Bit will not come out of the end of the hammer drill.
If the chuck will loosen and the bit still won't come out try tapping firmly on the tip of the bit with a scrap of wood while the chuck is loose. There are a couple ball bearings in the chuck that stick sometimes.
Feb 15, 2010 | Bosch SDS-plus BULLDOG Xtreme Rotary...
Feb 11, 2010 | Hitachi Drills
Connnect drill to keyless chuck bosch 36vfl1
Push or pull the business end toward the body while gently pressing and rotating the bit into it. The chuck will snap back up to retain the bit when you have it lined up right.
Sep 19, 2009 | Bosch 36V 1" Sds - Plus Rotary Hammer
Sds drill stuck in chuck
tap it lightly with a ball pin hammer, if that dosnt shake it out try opening it and useing something to push it through
May 04, 2009 | Drills
Broken shaft 3/8 milwaukee hammer drill mod #5392-1
Yes it does. The collar mechanism and retaining ring come off and under all that is a sleeve with steel ball bearings, what I am saying is it would be better to take to a repair shop. I worked on this tool for years and they are decent to use, but repairing that without proper equiptment is not fun. Let me know your area and I will try and find a repair center for you.
Mar 13, 2009 | Milwaukee Drills
Drills Logo
78 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
