What do I do if my AC is over charged - Computers & Internet
  • 7,627 Answers
Not sure I understand your question? Can you clarify?
Posted on Jul 13, 2013
  • kshawnette
    kshawnette Jul 13, 2013
    the ac in my car
HiSense Sero 7 tablet. Why no charge, no power?
About 1,620 results (0.80 seconds) Search Results
    HQRP USB to micro USB Cable / USB Charging Cable for ...
    www.amazon.com > ... > USB Cables
    Amazon.com, Inc.
    Rating: 2.9 - ‎22 reviews
    1A AC Wall Power Charger Adapter Cord for Hisense Sero 7 LT Lite E270BSA .... If you try to use the tablet while it is being charged, no charging will take place.
    HQRP AC Adapter / Battery Charger / micro USB Charging ...
    Amazon.com, Inc.
    Rating: 3.7 - ‎6 reviews
    HQRP USB to micro USB Cable / USB Charging Cable for Hisense Sero 7 LT E270BSA / Hisense... ... HQRP Micro-USB AC Adapter rapidly charges your Cell Phone / Tablet PC ... This one does not. ... Yes No Sending feedback. ... $3.91. 1A ACWall Power Charger Adapter Cord for Hisense Sero 7 LT Lite E270BSA Tablet.
    HQRP AC Adapter Dual microUSB Charging Cable for ...
    www.amazon.com/HQRP-Adapter-microUSB-Chargin...
    Amazon.com, Inc.HQRP AC Adapter Dual microUSB Charging Cable for Hisense Sero 7 LT E270BSA... Do not wait until charging one of your devices to charge the second.
Feb 09, 2016 | Tablets & eReaders
How do i know if my sl600 is charging? I have it pluggedin with the usb cable attached to the ac adapter. and the tiangular shape is orange. Does this mean its charging and how do i know when its complete
I'm glad to provide the information about charging the Camera. You can charge the Camera either using AC adapter or by connecting to the USB port on the Computer. Please make sure that you're not connecting AC adapter to the Camera when connecting to USB port on the computer. You can connect the Camera to the computer for more than 150 minutes(two and half hours) to fully charge the battery.
You can check the status of the LED on the AC Adapter while charging with the AC Adapter.
Thanks for understanding. Please let me know if you require any clarifications
Aug 21, 2011 | Samsung SL600 Digital Camera
Laptop battery is not charging
Hi, this information represents a basic troubleshooting guideline. Refer to your user guide for specific charging and connection instructions. Manuals may be available online in the Support Web site of HP.
Remove the battery from the computer.
Confirm the battery contacts are free of any foreign material that may prevent charging.
Reinsert the battery into the computer.
Verify that the AC adapter cord is properly connected and plugged directly into a known working AC power outlet.
NOTE: If the battery charges correctly when the AC adapter is plugged directly into an AC power outlet, but not when plugged into a power strip or surge protector, the problem is with the power strip or surge protector and not the computer battery or AC adapter.
Verify the correct AC adapter is being used.
Ensure the AC adapter box power light is on. This will be an illuminated green light.
If the AC adapter power light is not on, the AC adapter and power cord will need to be replaced.
Verify the charging indicator is illuminated on the computer.
If the issue still exists, install a different compatible HP battery, if available.
NOTE: If a replacement battery charges and operates correctly, the problem is with the first battery.
If neither the original nor a replacement battery charges, service may be required for the computer.
Dec 21, 2010 | HP 417035-001 - HP Pavilion dv2000 Series...
Appears to not be charging but does produce 110
Anytime external AC is being applied, the unit passes that AC input through to the output, independent of inverter/charger status. If external AC power is available but the unit is not charging (i.e. the Charge light is lit, but the batteries are not charging up as they should), then there is likely a problem with the AC sensing circuit card inside the unit, with a 1/4 amp fuse and/or the AC transformer the most probably culprits. Without external AC, the inverter will function all the way down to 10V, but then will shut off, so as long as your batteries have not been totally depleted,the unit will still be able to produce 110 AC after a brief charge cycle, but it won't for long.
Sep 17, 2010 | Xantrex Technology Heart Freedom 20 12...
Which pins are shorted on AC pressure switch to get the AC compressor to cycle to fill unit with freon?
You should not have to do anything to charge that AC system, except to start the engine and turn on the AC to maximum, then charge the AC system, when there is enough pressure in the system the low pressure switch will trip the AC compressor on and you can continue to fully charge the AC system.
Jun 06, 2010 | 2003 Suzuki Aerio
Air compressor wont come on to to put in 134a
The AC compressor does not have to be running to charge the AC system, and the low pressure switch will even prevent the AC compressor from operating until there is sufficient pressure to operate the AC compressor without damaging it.
Start the engine and turn on the AC, then charge the system with the R-134a and as soon as there is enough pressure built up to trip the low pressure switch off, the AC compressor clutch should then engage and then finish charging the AC system.
May 31, 2010 | 1997 Cadillac DeVille
My ipod nano does not hold charge.
What you can try and do is to charge it ac not dc. Ac would be in the car with a car charger. But if that is how you always charge it that is why it dont keep charge cause an long about of time charging your ipod in the car is bad on ac. The reason im telling you to charge it ac is because the battery is not use to it. Or vice versa.
Nov 18, 2009 | Apple iPod nano
01 grand am, ac compressor clutch not activating completely. What supplies juice to electromagnet?
A low refrigerant charge will cause the ac compressor clutch to not come on and/or partially apply. Check the ac refrigerant charge -- if low charge ac. Then re-evaluate
Aug 02, 2009 | 2001 Pontiac Grand Am SE
AC charging problem
okay if it charges with your DC, and it gives you plomebs with the AC, i would only charge in the car because your AC charger must not be changing the current to volts and you can easily blow it up... you can buy another charger and that should solve your problem
Dec 24, 2007 | Garmin nuvi 350 GPS Receiver
Computers & Internet Logo
David Payne
David Payne
