Question about Ricoh Aficio 1045 Black and White Copier
Photocopies are not clear even after increasing image intensity.
Photocopies on my Ricoh Aficio 1045 look fade. on increasing the intensity of image, they are still not clear and lines appear on the paper. already have cleaned the drum. I need a diagram with clear naming of parts as i solve the problem.
  • 81 Answers
If you have over approx. 60-100k copies on the machine it sounds like you may need regular maintaince on the machine.
to check how many copies you have press the user tools/counter button and then press counter.
Posted on Jul 21, 2013
bowdo
  • 78 Answers
SOURCE: Ricoh Aficio 1018 photocopier
For the Aficio 1018. SC-320 is laser failure - the polygon mirror motor inside the laser has failed and needs replacing. You will need to contact your nearest service agent for repair.
For your RICOH Aficio 1013F - SC-551 is overheat in standby mode as far as I can tell. The circuitry that controls the fuser section ie manages the heat has problem. Unless its right near a source of heat like a heater or has no circulation around you machine you will need contact a repair agent for this machine also.
Posted on Mar 19, 2008
Bubbabear64
  • 2794 Answers
SOURCE: Error code SC305 for Photocopier Ricoh Aficio 1224c
Its a charge corona cleaning error. Try turning the power off, wait 10 seconds and turn it back on.
If that doesn't reset it, it could be the pcu, toner collected on the mechanism.
If turning it off and back on isn't fixing it, you should get a technician to look at it to see what the trouble is.
Posted on Jun 19, 2008
MY PHOTOCOPIER IS ASKING FOR CODE SC194
Posted on Oct 11, 2008
  • 10 Answers
SOURCE: ricoh aficio 1045 error e990 please help it
Error 990 can be cuased by many things. Most of the time it is related to the Hard Drive. you could try replacing it.
Posted on Nov 05, 2008
  • 18 Answers
SOURCE: Ricoh Aficio 3228C asks for user name and password
What is the user name and password refering to?
if it is the administrator user name and password try
user name - admin
password -
blank password.
good luck
Posted on Jul 03, 2009
Where are the ID/SENSORS in my photocopier ricoh aficio mp 6000
my dear you clean drum unit your trouble codes clear
Jul 16, 2015 | Ricoh Aficio MP 6000
Unable to enter sp mode for ricoh mp4500 machine
The proceedure is to press the following buttons in this order; clear modes, 1,0,7,clear. hold clear button for at least 5 seconds. This should get you in.
Mar 27, 2014 | Ricoh Aficio Mp161 Copier Photocopier Copy...
How clear ricoh Aficio 1045 code sc321
IM RICOH COPIER TECHNICIAN AND I HATE THAT CODE 321, 322. CHECH THE LASER UNIT
Jan 14, 2014 | Ricoh Aficio 450 Copier
Where's laser unit ricoh 1045
when you will open the front door,right under the green handle which is for replacement of the toner bottle you will see a about 5 cm vertical line glass pull it towards you. That is the laser shield glass. Clean it whit dry cloth. that install it again and try to see the image, if the image is still the same. you will need to clean the laser unit.
Dec 06, 2013 | Ricoh Office Equipment & Supplies
RICOH AFICIO 1045. ANY BUTTON AT RIGHT OF THE ...
turn off and unplug remove two screws on top near the glass jn order to remove the control panel slide panel toward your tummy bottm side has wiring harnesses check these connectorsare tight also look fer cracked solder joints on right side for numeric keypad if you know how to soldera pcb new control panel is about 800.00
May 21, 2010 | Ricoh Aficio 1045 Black and White Copier
RICOH AFICIO 401 COPIER- COPIES FADED ON ONE SIDE
Hello sir; You have to replace drum and developer meanwhile you have to clean up image roller, then it will take care the problem.
Nov 06, 2009 | Ricoh Aficio 450 Copier
Ricoh 1045 only printing on 1/2 page
When you put the delveloper did you:
remove the cover to install it.
remove all of the old developer out of the machine.
Did you go into service mode and run sp 2-801.
Jun 30, 2008 | Ricoh Aficio 1035 Copier
Ricoh aficio 200
Ricoh Aficio 200 copier has stopped copying from side tray. Can you help?
jimgoatley@slingshot.co.nz
Feb 17, 2008 | Ricoh Aficio 180 Laser Printer
Ricoh Aficio 1045 Black and White Copier Logo
70 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
